» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 64 online users.
» 0 Member(s) | 45 Guest(s)
Amazonbot, Baidu, Bytespider, Crawl, PetalBot, Semrush, bot, owler
kc868-a6 analog input
11 hours ago
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Firmware + I2C + Button
Posted by: MarcinG - 07-21-2024, 08:22 AM - Forum: KC868-A16 - Replies (3)
I have a few issues:
  1. When I install firmware versions newer than v.1.0.24, I can't set Bind Output, Function, On, Off and Toggle in the input settings. It simply doesn't exist (screenshot 1). This is v.2.2.4 (screenshot 2). In older firmware versions, this problem does not occur (screenshot 3). This is v.1.0.24 (screenshot 4). I'm not sure if this is an issue on my end or if these functions have been removed?
  2. Will the I2C sensor support function be added in future firmware updates? I prefer the official firmware over ESPHome, and I would like to be able to connect and operate the BME280 sensor with the official firmware just like the ONEWire DS18B20 sensor (in newer firmware versions).
  3. Is it possible to create a "virtual" button? I'm thinking of a situation like this: In my office, I have a main light connected to the output on the KC868-A16 (the button controlling this light is connected to the input) and an LED strip connected to Home Assistant via Zigbee communication. I would like to toggle the main light with a single click, toggle the LED strip with a double click, and turn off both lights with a hold on. Is this possible? It is possible to pull out the topic in Home Assistant to do automation on double click? Or maybe this can be done in the new firmware version, for example, in the input tab, where you specify which input will control which output, will be able to provide entities from Home Assistant?
Best regards,
  KC868-AI TCP COMUNICATION PROTOCOL
Posted by: Dm81 - 07-21-2024, 07:03 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Good Morning
I didn't find KC868-AI comunication protocol in "Software & Document" menù on your website, please, is it possible to see it;
Is this board has TCP server like KC868-H16B or KC868-COLB?
thank you
  KinCony ALR ESP32-S3 LoRa SX1278 Gateway released
Posted by: admin - 07-21-2024, 05:18 AM - Forum: News - Replies (6)
We have designed ESP32 LoRa SX1278 Gateway - KinCony ALR. It support install into waterproof box. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with relay,SSD1306 LCD, 4 channel analog input, digital input, i2c bus extender, 1-wire GPIO, SX1278 LoRa module, DIP switch set for LoRa address.It can use for smart home IoT project use by home assistant. ESP32-S3 also support arduino IDE / MicroPython / ESP-IDF development tool.
[Image: ESP32-LoRa-1.jpg]
[Image: ALR_diagram.jpg]
Hardware resource:
Power supply: DC9-24V
USB-C: download firmware
Buttons: ESP32 Reset and Download
SX1278 LoRa module
Relay: MAX Load AC250v10A COM,NO,NC
SSD1306 i2c LCD
8bit DIP switch: set LoRa device address
Analog Input: 4 channel dc 0-5v signal
1-wire: 1 channel
digital input: 1 channel (dry contact signal)
I2C bus: 1
  Arduino demo source code for LoRa "Receiver"
Posted by: admin - 07-21-2024, 05:11 AM - Forum: KinCony ALR - Replies (7)
#include <LoRa.h>
#include <SPI.h>
#include <Wire.h>
#include <Bonezegei_SSD1306.h>
Bonezegei_SSD1306 oled(128, 64);
#define ss 41
#define rst 2
#define dio0 40
#include "Arduino.h"
#define ANALOG_A1   4
#define ANALOG_A2   6
#define ANALOG_A3   5
#define ANALOG_A4   7
const int Relay1 = 48;
const int K1 = 47;
const int K2 = 21;
const int K3 = 14;
const int K4 = 13;
const int K5 = 12;
const int K6 = 11;
const int K7 = 10;
const int K8 = 9;
const int IO0 = 0;  //GPIO0
const int DI1 = 16;  //DI
const int DI2 = 15;  //1-wire
  SPI.begin(42, 43, 44, 41);  //SPI.begin(PIN_SPI_SCK, PIN_SPI_MISO, PIN_SPI_MOSI, -1);   last one is SS not used, use -1
  Wire.begin(39, 38);
  oled.begin();
  oled.clear();
//  oled.drawText(1, 0, "Arial8", oled.Font_Arial8);
  oled.drawText(1, 0, "KinCony", oled.Font_Arial14);
//  oled.drawText(1, 24, "Arial12", oled.Font_Arial12);
//  oled.drawText(1, 40, "Arial14", oled.Font_Arial14);
  oled.draw();  //update the screen
  Serial.println("begin");
  LoRa.setPins(ss, rst, dio0);    //setup LoRa transceiver module
  while (!LoRa.begin(433E6))     //433E6 - Asia, 866E6 - Europe, 915E6 - North America
    Serial.println(".");
    delay(500);
  LoRa.setSyncWord(0xA5);
  Serial.println("LoRa Initializing OK!");
  pinMode(Relay1,OUTPUT);
  pinMode(K1,INPUT);
  pinMode(K2,INPUT);
  pinMode(K3,INPUT);
  pinMode(K4,INPUT);
  pinMode(K5,INPUT);
  pinMode(K6,INPUT);
  pinMode(K7,INPUT);
  pinMode(K8,INPUT);
  pinMode(DI1,INPUT);
  pinMode(DI2,INPUT);
  pinMode(IO0,INPUT);
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  digitalWrite(Relay1, HIGH);
uint8_t valk1 = digitalRead(K1);
uint8_t valk2 = digitalRead(K2);
uint8_t valk3 = digitalRead(K3);
uint8_t valk4 = digitalRead(K4);
uint8_t valk5 = digitalRead(K5);
uint8_t valk6 = digitalRead(K6);
uint8_t valk7 = digitalRead(K7);
uint8_t valk8 = digitalRead(K8);
uint8_t valdi1 = digitalRead(DI1);
uint8_t valdi2 = digitalRead(DI2);
uint8_t valIO0 = digitalRead(IO0);
if (valdi1==LOW) digitalWrite(Relay1, HIGH); else digitalWrite(Relay1, LOW);
if (digitalRead(DI2)==LOW)Serial.println("input2 down");
if (digitalRead(IO0)==LOW)Serial.println("DL Button down");
if (digitalRead(K1)==LOW)Serial.println("K1 down");
if (digitalRead(K2)==LOW)Serial.println("K2 down");
if (digitalRead(K3)==LOW)Serial.println("K3 down");
if (digitalRead(K4)==LOW)Serial.println("K4 down");
if (digitalRead(K5)==LOW)Serial.println("K5 down");
if (digitalRead(K6)==LOW)Serial.println("K6 down");
if (digitalRead(K7)==LOW)Serial.println("K7 down");
if (digitalRead(K8)==LOW)Serial.println("K8 down");
  if (analogRead(ANALOG_A1)>0) Serial.printf("Current Reading A1 on Pin(%d)=%d\n",ANALOG_A1,analogRead(ANALOG_A1));
  if (analogRead(ANALOG_A2)>0) Serial.printf("Current Reading A2 on Pin(%d)=%d\n",ANALOG_A2,analogRead(ANALOG_A2));
  if (analogRead(ANALOG_A3)>0) Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));
  if (analogRead(ANALOG_A4)>0) Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));
  int packetSize = LoRa.parsePacket();    // try to parse packet
  if (packetSize)
    Serial.print("Received packet '");
    while (LoRa.available())              // read packet
      String LoRaData = LoRa.readString();
      Serial.print(LoRaData);
      oled.begin();
      oled.clear();
      oled.drawText(1, 0, LoRaData.c_str(), oled.Font_Arial14);
      String temp=String(LoRa.packetRssi());
      oled.drawText(1, 40, temp.c_str(), oled.Font_Arial14);
    Serial.print("' with RSSI ");         // print RSSI of packet
    Serial.println(LoRa.packetRssi());
before use this code, need to install LoRa SX1278 arduino library firstly.
  Arduino demo source code for LoRa "SENDER"
Posted by: admin - 07-21-2024, 05:10 AM - Forum: KinCony ALR - No Replies
#include <LoRa.h>
#include <SPI.h>
#define ss 41
#define rst 2
#define dio0 40
int counter = 0;
  Serial.println("LoRa Sender");
    delay(500);
  Serial.print("Sending packet: ");
  Serial.println(counter);
  LoRa.beginPacket();   //Send LoRa packet to receiver
  LoRa.print("KinCony LoRa");
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  delay(2000);
  KinCony ALR ESP32 I/O pin define
Posted by: admin - 07-21-2024, 05:07 AM - Forum: KinCony ALR - Replies (6)
ANALOG_A1  4
ANALOG_A2  6
ANALOG_A3  5
ANALOG_A4  7
1-wire: 15
digital input:16
DIP switch: use for set LoRa address
DIP-K1:47
DIP-K2:21
DIP-K3:14
DIP-K4:13
DIP-K5:12
DIP-K6:11
DIP-K7:10
DIP-K8:9
relay:48
IIC SDA:39
IIC SCL:38
SPI_Bus: (For SX1278 LoRA)
CS: 41
MOSI: 44
MISO: 43
SCK: 42
RST:2
DIO0:40
  how to use KinCony Server16/Server-Mini work with Tuya app
Posted by: admin - 07-21-2024, 12:19 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
1. add Kincony Tuya Mqtt component to home assistant by HACS
https://github.com/hzkincony/hass-tuya-mqtt
2. edit configuration.yaml add the code as sample code:
here is whole configuration.yaml download:
.txt   Server16-Tuya-HA.txt (Size: 6.16 KB / Downloads: 381)
you need to buy Tuya license for Server16 or Server-Mini from KinCony. how to order Tuya license, see here: https://www.kincony.com/forum/showthread.php?tid=2544
after you bought Tuya license, replace these 3 lines with yourself:
  device_id: xxxxxxxxxxxxxxxxxxxxx
  device_secret: xxxxxxxxxxxxxxxxxxx
  region: xx
"bind_id" for switch and binary_sensor, you need search in home assistant -- "Developer tools"--"STATES", input your entity name, then find the ID name.
3. use Tuya application or smart life application to scan QRcode(we will give you) add device.
4. you can test turn on/off relay and short digital input port.
here are test photo for turn on relay1,2.
here are test photo for short digital input1 with GND.
now you can not only use home assistant control device in local network, but also remote control device by internet via tuya application.
  yaml detail for DI on modbus controller
Posted by: Savino - 07-20-2024, 07:45 PM - Forum: KC868-A6 - Replies (2)
where I could find yaml file with details to add digital inputs of kc868-a6 board to modbus-controller?
I have already info to add relay, as following:
- platform: modbus_controller
  address: 0 # 0: relay1  1: relay 2 .........
  register_type: coil
  bitmask: 1
I need something similar to add digital inputs to the RS485.
Wink MQTT M16v2
Posted by: jojorahu - 07-20-2024, 04:17 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Hello
This Arduino sketch can read the 16 channels of the clamps, read the temperature and humidity sensor and send the data to a mqtt broker
att
Jose Joaquin Ramirez
.txt   KC868_M16_MQTT_8ch_demo.ino.txt (Size: 7.49 KB / Downloads: 713)
Wink E16P POE Support
Posted by: nickcan - 07-19-2024, 07:08 AM - Forum: KC868-E16S/E16P - Replies (5)
I was referring to the E16P POE design and found that B1601S does not support POE. So how does it work?
