» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 821 online users.
» 0 Member(s) | 798 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bytespider, Crawl, Google, PetalBot, Semrush, bot
kc868-a6 analog input
Today, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  KC868-E8T added Tuya module yaml file for ESPHome
Posted by: admin - 06-05-2024, 04:32 AM - Forum: KC868-E8T - No Replies
  friendly_name: e8t-tuya
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  platform: ESP32
  on_boot:  #Power chip BL0939 initialization
    priority: 600
    then:
      - uart.write:
          data: [0xA5, 0x39, 0x42, 0x00, 0x00, 0xDF]
      - delay: 1ms
      - uart.write:
          data: [0xA5, 0x38, 0x3C, 0x00, 0x00, 0xE6]
      - delay: 1ms
      - uart.write:
      - delay: 1ms
      - uart.write:
          data: [0xA5, 0x3A, 0x01, 0x00, 0x00, 0x1F]
      - delay: 1ms
      - uart.write:
          data: [0xA5, 0x39, 0x00, 0x00, 0x00, 0x21]
external_components:
  - source:
      type: git
      ref: v1.1.0
  - id: uart_1
    tx_pin: GPIO12
    rx_pin: GPIO39
    baud_rate: 4800
    parity: NONE
    stop_bits: 2
  # - id: uart_2
  #   tx_pin: GPIO33
  #   rx_pin: GPIO36
  #   baud_rate: 4800
  #   parity: NONE
  #   stop_bits: 2
  - id: tuya_mcu_uart
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: d8vwzka9smrcjznp
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  # baud_rate: 0
ota:
  password: "d83d604e4f0ae287fb041dbaf31524d9"
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - platform: bl0939
    uart_id: uart_1
    update_interval: 10s
    voltage:
    current_1:
      name: 'BL0939A Current 1'
    current_2:
      name: 'BL0939A Current 2'
    active_power_1:
      name: 'BL0939A Active Power 1'
    active_power_2:
      name: 'BL0939A Active Power 2'
    energy_1:
      name: 'BL0939A Energy 1'
    energy_2:
      name: 'BL0939A Energy 2'
    energy_total:
      name: 'BL0939A Energy Total'
  # - platform: bl0939
  #   uart_id: uart_2
  #   update_interval: 10s
  #   voltage:
  #     name: 'BL0939B Voltage'
  #   current_1:
  #     name: 'BL0939B Current 1'
  #   current_2:
  #     name: 'BL0939B Current 2'
  #   active_power_1:
  #     name: 'BL0939B Active Power 1'
  #   active_power_2:
  #     name: 'BL0939B Active Power 2'
  #   energy_1:
  #     name: 'BL0939B Energy 1'
  #   energy_2:
  #     name: 'BL0939B Energy 2'
  #   energy_total:
  #     name: 'BL0939B Energy Total'
  sda: 4
  scl: 5
# Individual outputs
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "e8t_output1"
    dp_id: 2
    internal: true
    bind_switch_id: "e8t_output2"
    dp_id: 3
    internal: true
    bind_switch_id: "e8t_output3"
    dp_id: 4
    internal: true
    bind_switch_id: "e8t_output4"
    dp_id: 5
    internal: true
    bind_switch_id: "e8t_output5"
    dp_id: 6
    internal: true
    bind_switch_id: "e8t_output6"
    dp_id: 123
    internal: true
    bind_switch_id: "e8t_output7"
    dp_id: 124
    internal: true
    bind_switch_id: "e8t_output8"
    dp_id: 122
    bind_binary_sensor_id: e8t_input1
    internal: true
    dp_id: 121
    bind_binary_sensor_id: e8t_input2
    internal: true
    dp_id: 120
    bind_binary_sensor_id: e8t_input3
    internal: true
    dp_id: 119
    bind_binary_sensor_id: e8t_input4
    internal: true
    dp_id: 118
    bind_binary_sensor_id: e8t_input5
    internal: true
    dp_id: 117
    bind_binary_sensor_id: e8t_input6
    internal: true
    dp_id: 116
    bind_binary_sensor_id: e8t_input7
    internal: true
    dp_id: 115
    bind_binary_sensor_id: e8t_input8
    internal: true
web_server:
  port: 80
download yaml file:
.txt   KC868-E8T-HA-Tuya.txt (Size: 8.39 KB / Downloads: 590)
  KC868-E16T added Tuya module yaml file for ESPHome
Posted by: admin - 06-05-2024, 02:16 AM - Forum: KC868-E16T - Replies (8)
  platform: ESP32
  platformio_options:
      - "-DWIFI_CONTROL_SELF_MODE=0"
  - source:
      type: git
      ref: v1.1.0
  tx_pin: 33
  rx_pin: 14
  baud_rate: 9600
tuya_wifi_mcu:
  product_id: tfj1dtlneyxp5uya
  wifi_reset_pin: 5
  wifi_led_pin: 12
  sda: 16
  scl: 15
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
    address: 0x21
    address: 0x25
    dp_id: 1
    internal: true
    bind_switch_id: "e16t_output1"
    dp_id: 2
    internal: true
    bind_switch_id: "e16t_output2"
    dp_id: 3
    internal: true
    bind_switch_id: "e16t_output3"
    dp_id: 4
    internal: true
    bind_switch_id: "e16t_output4"
    dp_id: 5
    internal: true
    bind_switch_id: "e16t_output5"
    dp_id: 6
    internal: true
    bind_switch_id: "e16t_output6"
    dp_id: 101
    internal: true
    bind_switch_id: "e16t_output7"
    dp_id: 102
    internal: true
    bind_switch_id: "e16t_output8"
      pcf8574: pcf8574_hub_out_2
    dp_id: 103
    internal: true
    bind_switch_id: "e16t_output9"
    dp_id: 104
    internal: true
    bind_switch_id: "e16t_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "e16t_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "e16t_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "e16t_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "e16t_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "e16t_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "e16t_output16"
    name: e16t DI01 Tuya
    dp_id: 111
    bind_binary_sensor_id: e16t_input1
    internal: true
    name: e16t DI02 Tuya
    dp_id: 112
    bind_binary_sensor_id: e16t_input2
    internal: true
    name: e16t DI03 Tuya
    dp_id: 113
    bind_binary_sensor_id: e16t_input3
    internal: true
    name: e16t DI04 Tuya
    dp_id: 114
    bind_binary_sensor_id: e16t_input4
    internal: true
    name: e16t DI05 Tuya
    dp_id: 115
    bind_binary_sensor_id: e16t_input5
    internal: true
    name: e16t DI06 Tuya
    dp_id: 116
    bind_binary_sensor_id: e16t_input6
    internal: true
    name: e16t DI07 Tuya
    dp_id: 117
    bind_binary_sensor_id: e16t_input7
    internal: true
    name: e16t DI08 Tuya
    dp_id: 118
    bind_binary_sensor_id: e16t_input8
    internal: true
      pcf8574: pcf8574_hub_in_2
    name: e16t DI09 Tuya
    dp_id: 119
    bind_binary_sensor_id: e16t_input9
    internal: true
    name: e16t DI10 Tuya
    dp_id: 120
    bind_binary_sensor_id: e16t_input10
    internal: true
    name: e16t DI11 Tuya
    dp_id: 121
    bind_binary_sensor_id: e16t_input11
    internal: true
    name: e16t DI12 Tuya
    dp_id: 122
    bind_binary_sensor_id: e16t_input12
    internal: true
    name: e16t DI13 Tuya
    dp_id: 123
    bind_binary_sensor_id: e16t_input13
    internal: true
    name: e16t DI14 Tuya
    dp_id: 124
    bind_binary_sensor_id: e16t_input14
    internal: true
    name: e16t DI15 Tuya
    dp_id: 125
    bind_binary_sensor_id: e16t_input15
    internal: true
    name: e16t DI16 Tuya
    dp_id: 126
    bind_binary_sensor_id: e16t_input16
    internal: true
download yaml file:
.txt   E16T-HA-Tuya.txt (Size: 11.91 KB / Downloads: 695)
Question ESP32-S3 and DI8
Posted by: AVS412 - 06-03-2024, 06:58 PM - Forum: News - Replies (1)
I am unable to merge the yaml files for the ESP32-S3 Core Board and the I2C IO Expander inoput board DI8.
I merged them, and I think the SCL and SDA lines are set up correctly (GPIO38 and GPIO39). When compiling, I get an error in ESP-HOME every time.
I get the error below:
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
Linking .pioenvs/controller_avs412/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x70): undefined reference to `vtable for esphome::i2c::IDFI2CBus'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x74): undefined reference to `vtable for esphome::i2c::IDFI2CBus'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x94): undefined reference to `vtable for esphome::pcf8574::PCF8574Component'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x1f4): undefined reference to `vtable for esphome::pcf8574::PCF8574GPIOPin'
collect2: error: ld returned 1 exit status
*** [.pioenvs/controller_avs412/firmware.elf] Error 1
========================= [FAILED] Took 11.95 seconds =========================
Can anyone tell you what's going wrong?
Thank you.
# Diversen I/O Modules.
# IP range gereserveerd van 192.168.200.101 t/m 192.168.200.109
  friendly_name: CONTROLLER_AVS412
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
# Instellen I/O voor de RJ45 poort
  type: W5500
  clk_pin: GPIO43
  mosi_pin: GPIO44
  miso_pin: GPIO42
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
# Instellen statisch IP adres
  manual_ip:
    static_ip: 192.168.200.101
    gateway: 192.168.200.1
    subnet: 255.255.255.0
  encryption:
    key: "pKeAagi+vmlVVS45THS6padK2DpyOx+KYxlztZsxvQo="
ota:
  sda: GPIO39
  scl: GPIO38
# id: bus_a
    address: 0x20    #replace by your PCF8574 address
# Activeren Web server.
web_server:
  port: 80
#  Instellen seriele communicatiepoort voor RS485
  - id: uart_485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 15
#  Instellen seriele communicatiepoort voor de 4G communicatiemodule
  - id: uart_sim7600
    baud_rate: 115200
    debug:
      direction: BOTH
      after:
        timeout: 10ms
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
    tx_pin: 18
    rx_pin: 17
# Software schakelaars voor RS485 en de 4G module aan/ uit te zetten
  - platform: uart
    uart_id: uart_485
  - platform: uart
    uart_id: uart_sim7600
    data: "AT+CGSN\r\n" # read 4G SIM7600 ID
# In- en uitgangen instellen
      number: 8
      number: 40
  #- platform: gpio
  #  name: "ESP_CPU01_AVS412 SDA"
  #  pin:
  #    number: 39
  #    inverted: true
  #    mode:
  #      input: true
  #      pullup: true
  #- platform: gpio
  #  name: "ESP_CPU01_AVS412 SCL"
  #  pin:
  #    number: 38
  #    inverted: true
  #    mode:
  #      input: true
  #      pullup: true
      number: 10
      mode:
        input: true
        pullup: true
      number: 11
      mode:
        input: true
        pullup: true
      number: 12
      mode:
        input: true
        pullup: true
      number: 13
      mode:
        input: true
        pullup: true
      number: 14
      mode:
        input: true
        pullup: true
      number: 21
      mode:
        input: true
        pullup: true
      number: 47
      mode:
        input: true
        pullup: true
      number: 48
      mode:
        input: true
        pullup: true
  - platform: adc
    pin: 4
    name: "CONTROLLER_AVS412 IO04 Current"
    update_interval: 2s
    unit_of_measurement: V
    attenuation: 11db
    filters:
      - multiply: 5
  - platform: adc
    pin: 5
    name: "CONTROLLER_AVS412 IO05 Current"
    update_interval: 2s
    attenuation: 11db
    filters:
      - multiply: 5
  - platform: adc
    pin: 6
    name: "CONTROLLER_AVS412 IO06 Current"
    update_interval: 2s
    attenuation: 11db
    filters:
      - multiply: 5
  - platform: adc
    pin: 7
    name: "CONTROLLER_AVS412 IO07 Current"
    update_interval: 2s
    attenuation: 11db
    filters:
      - multiply: 5
  KC868-A16 : RF is not displayed on screen Monitor
Posted by: Brouk - 06-03-2024, 11:37 AM - Forum: KC868-A16 - Replies (1)
I uploaded the KCS_KC868-A16V2.2.2.bin file to the A16 module. There is RF 433MHz receiver/transmitter in the module. Modul have used/learned 4 signals from my key remote controler.
How can I start displaying the RF inputs on the Monitor screen?
  Tuya adapter V2 arduino source code - control KinCony KC868-Hx series relay board
Posted by: admin - 06-03-2024, 12:28 AM - Forum: KC868-ATC / Tuya adapter V2 - Replies (7)
these BIN file firmware and arduino source code work for KinCony KC868-Hx series relay board:
KC868-H32, KC868-H32L, KC868-H32W, KC868-H32BS, KC868-H32B
KC868-H16, KC868-H16W, KC868-H16B
KC868-H8, KC868-H8W, KC868-H8B
you not need connect any cable between Tuya adapter v2 and relay board. Because of it use by TCP connection, it use network.
fimrware download:
.zip   H8x_0x0.zip (Size: 478.35 KB / Downloads: 960)
.zip   H16x_0x0.zip (Size: 478.44 KB / Downloads: 962)
.zip   H32x_0x0.zip (Size: 478.7 KB / Downloads: 965)
download file and unzip, then download BIN file by ESP DOWNLOAD TOOL, write code at 0x0 address.
ESP DOWNLOAD TOOL download link:
https://www.kincony.com/wp-content/uploa..._3.9.2.zip
if you want modify arduino source code, which relay board model to use, just uncomment the model command line.
first time run code, you need to set relay board's IP address, port, your router's ssid and password for Tuya adapter v2 by usb-serial port.
just send command as this: SSID:KinCony,PSW:a12345678,192.168.3.141,4196
serial port baud rate: 115200bps
serial port debug tool download:
.zip   UartAssist.zip (Size: 468.4 KB / Downloads: 1052)
here is arduino source code:
// USB set command     SSID:XXXXX,PSW:XXXXX,X.X.X.X,YYYY
// X.X.X.X is relay board IP address,  YYYY is relay board port.  SSID and PSW is your router's ssid and password
// for example         SSID:KinCony,PSW:a12345678,192.168.3.141,4196
// make sure your H8,H16,H32 relay board work with "TCP Server" mode.
#include <Arduino.h>
#include <TuyaWifi.h>
#include <Preferences.h>
#include "HardwareSerial.h"
///ADD TCP CLIENT FOR TUYA ADAPT
//#include <WiFiUdp.h>
#include <WiFi.h>
#include <WiFiClient.h>
//uncomment the relay board model you are using
//#define KINCONY_H8X    ////
//#define KINCONY_H16X    ////
#define KINCONY_H32X    ////
#if defined(KINCONY_H8X)
#define RLY_NUMS  8
#elif defined(KINCONY_H16X)
#define RLY_NUMS  16
#elif defined(KINCONY_H32X)
#define RLY_NUMS  32
#endif
//---------RS485 setting
#define DEBUG   1
#define SERIAL_BAUD   9600
#define RX_PIN    32
#define TX_PIN    33
#define ADAPT485_NUM  2
#define SLAVE_ADDR  1
#define READ_ADDR  0
#define READ_NUM   32
////SERIAL COMMAND IS
////SSID,
char ssid_buf[30] = {0};
char password_buf[20] = {0};
char server_ip[20] = {0};
uint16_t server_port = 4096;
uint8_t str[]={"client_me"};
//uint8_t Rece[256]={0};
uint8_t Send[128]={0};
Preferences prefs;
//IPAddress staticIP(192, 168, 10, 12);
//IPAddress gateway(192, 168, 10, 1);
//IPAddress subnet(255, 255, 255, 0);
//IPAddress dns(192, 168, 10,1);
WiFiClient client;
typedef enum{INIT_STATUS=0,RDY_STATUS,CONNECT_STATUS,TCP_COMM,STOP_STATUS,}STATUS_MACHINE;
static int statusMachine = INIT_STATUS;
static void InitWifi(void)
  //WiFi.mode(WIFI_STA);
  //WiFi.setSleep(false); // disable STA mode wifi sleep mode
  /*if(WiFi.config(staticIP, gateway, subnet, dns, dns)==false)
    Serial1.println("Configuration failed.");
  /*IPAddress ip = WiFi.localIP();
  Serial1.print("IP address: ");
  Serial1.println(WiFi.localIP()); */
  Serial1.print("rcv SSID is: ");
  Serial1.println(ssid_buf);
  Serial1.print("rcv PSW is: ");
  Serial1.println(password_buf);
  Serial1.print("rcv server ip is: ");
  Serial1.println(server_ip);
  Serial1.print("rcv server port is: ");
  Serial1.println(server_port);
  WiFi.begin(ssid_buf, password_buf);//link wifi hotspot
  Serial1.println("WiFi try to connect~");
  statusMachine = RDY_STATUS;
static bool bFlagConnWifi = false;
static bool bFlagConnTcp = false;
static String serial_cmd_rcv = "";
static String tcp_cmd_rcv = "";
static char command_str_arr[30]={0};
bool rt_coils_status[RLY_NUMS] = {0};
void dp_update_all(void);
////online check for wifi&tcp connections for 500ms
static void SetRlyByChannel(uint8_t ch,bool value)
  memset(command_str_arr,0,sizeof(command_str_arr));
  sprintf(command_str_arr,"RELAY-SET-255,%d,%d",ch+1,value?1:0);
  return;
static void ReadAllRlyStatus()
  memcpy(command_str_arr,(char*)"RELAY-STATE-255",15);
  return;
static void WifiConnect(void)
  if (WiFi.status() != WL_CONNECTED) //wait wifi connection success
    Serial1.print(".");
    //WiFi.begin(ssid_buf, password_buf);//link wifi hotspot
    //Serial1.println("WiFi try to connect~");
    bFlagConnWifi = bFlagConnTcp = false;
    return ;
  bFlagConnWifi = true;
  statusMachine = CONNECT_STATUS;
  Serial1.println("WiFi connected");
static void TcpServerConn(void)
  if(WiFi.status() != WL_CONNECTED)
    if(bFlagConnTcp) client.stop();
    Serial1.println("WiFi exception 0");
    return;
  if (!bFlagConnTcp)//begin connect to tcp server///if (client.connected() != 0)
      if (!client.connect(server_ip, server_port,2000))
          Serial1.println("try to connect host....");
          //delay(5);
      else
        bFlagConnTcp = true;
        statusMachine = TCP_COMM;
        Serial1.println("TCP connected Succeed");
static void SendPeriodCheckCommand(void)
    Serial1.println("WiFi exception 1");
    return;
  if(client.connected())
  Serial1.println("send period check cmd~");
  ReadAllRlyStatus();
  //SetRlyByChannel();
  client.write(command_str_arr,strlen(command_str_arr));
static void GetCoilStatus(String data)
{///ACK STANDARD FORMAT IS "RELAY-STATE-255,D1,D0,OK" ///16x
////ACK STANDARD FORMAT IS "RELAY-STATE-255,D0,OK"  ///8x
////ACK STANDARD FORMAT IS "RELAY-STATE-255,D3,D2,D1,D0,OK" ///32x
   String rcv_data = data;
   if(rcv_data.substring(15,16) != "," ) return;
   uint8_t rlys_arr[4] = {0};
   uint32_t rly_status = 0;
   rcv_data = rcv_data.substring(16);
   //Serial1.println("Remain strs1:" + rcv_data);
   int index_find = rcv_data.indexOf(',');
   rlys_arr[0] = atoi(rcv_data.substring(0,index_find).c_str());
   #if defined(KINCONY_H16X) || defined(KINCONY_H32X)
   rcv_data = rcv_data.substring(index_find+1);
   //Serial1.println("Remain strs2:" + rcv_data);
   rlys_arr[1] = atoi(rcv_data.substring(0,index_find).c_str());
   #endif
   #if defined(KINCONY_H32X)
   rlys_arr[2] = atoi(rcv_data.substring(0,index_find).c_str());
   rlys_arr[3] = atoi(rcv_data.substring(0,index_find).c_str());
   #endif
  rly_status = rlys_arr[0];
  rly_status = (rlys_arr[0]<<8 ) | rlys_arr[1];
   #else
  rly_status = (rlys_arr[3]<<24 ) | (rlys_arr[2]<<16 )| (rlys_arr[1]<<8 )| (rlys_arr[0] );
   #endif
   Serial1.print("rly_status = 0x");
   Serial1.println(rly_status,HEX);
   for(int i=0;i<RLY_NUMS;i++)
     rt_coils_status[i] = (rly_status&(1<<i))?true:false;
static char rece_tcp_buf[100] = {0};
static bool CheckClientRcv(void)
  uint8_t i=0;
  if(client.available() == 0) return false;
  memset(rece_tcp_buf,0,sizeof(rece_tcp_buf));
  tcp_cmd_rcv = "";
   while (client.available()>0)  //whether received data from server
       rece_tcp_buf[i++] = client.read();//receive data from server
    //tcp_cmd_rcv += client.read();//store data from server
    delay(1);
   tcp_cmd_rcv = String(rece_tcp_buf);
   Serial1.print("Ack:");
   Serial1.println(tcp_cmd_rcv.c_str());
   if (tcp_cmd_rcv.length() < 22 ||
      tcp_cmd_rcv.substring(0,15) != "RELAY-STATE-255" )  {tcp_cmd_rcv="";return false;}
  //Serial1.println("OKAY COILS VALUE");
  GetCoilStatus(tcp_cmd_rcv);
  tcp_cmd_rcv="";
  return true;
static bool ProtocolDeal(const char* buf)
  char deal_str[100] = {0};
  char tmp[30];
  char *pos,*pos1,*pos2,*pos3;
  memcpy(deal_str,buf,strlen(buf));
  Serial1.println("check1");
  if ((pos = strchr(deal_str,','))!=0)    //find','
    *pos = '\0';    //","replace with ‘\0’
    pos++;
    pos1 = pos;
    memset(tmp,0,30);
    //memcpy(tmp,buf,strlen(buf));
    strcpy(tmp,deal_str);
    if(tmp[0]=='S' && tmp[1]=='S' && tmp[2]=='I' && tmp[3]=='D' &&
      tmp[4]==':')
      memset(ssid_buf,0,sizeof(ssid_buf));
      memcpy(ssid_buf,&tmp[5],strlen(tmp)-5);
      Serial1.println("rcv ssid ok.");
  else
      Serial1.println("end1");
      return  false;
  Serial1.println("check2");
  if ((pos = strchr(pos1,','))!=0)    //find','
    *pos = '\0';    //","replace with‘\0’
    pos++;
    pos2 = pos;
    memset(tmp,0,30);
    //memcpy(tmp,pos1,strlen(pos1));
    strcpy(tmp,pos1);
    if(tmp[0]=='P' && tmp[1]=='S' && tmp[2]=='W' && tmp[3]==':' )
      memset(password_buf,0,sizeof(password_buf));
      memcpy(password_buf,&tmp[4],strlen(tmp)-4);
      Serial1.println("rcv psw ok.");
  else{
    return false;
    Serial1.println("end2");}
  Serial1.println("check3");
  if ((pos = strchr(pos2,','))!=0)    //find','  IP:XXXX,PORT:XXXX
    pos++;
    pos3 = pos;
    memset(server_ip,0,sizeof(server_ip));
    memcpy(server_ip,pos2,strlen(pos2));
    server_port = atoi(pos3);
    /*bFlagConnWifi = bFlagConnTcp = false;
      client.stop();
    if (WiFi.status() == WL_CONNECTED) //等待WiFi热点连接成功
      Serial1.print("stop wifi second.");
      WiFi.disconnect();
      delay(3000);
    ///Preferences param here...
    prefs.begin("myns_netcfg");
    prefs.putString("ns_ssid",ssid_buf);
    prefs.putString("ns_psw",password_buf);
    prefs.putString("ns_ip",server_ip);
    prefs.putUShort("ns_port",server_port);
    prefs.end();
    ESP.restart();
  else
    return false;
    Serial1.println("end3");
static void GetSerialCmd()
{ ////format: SSID:REALTIME2SENS-2.4G,PSW:12345678,IP:192.168.1.100,PORT:4196
  if(Serial1.available() == 0) return;
  while (Serial1.available() > 0)
    serial_cmd_rcv += char(Serial1.read());
    delay(1);
  Serial1.println(serial_cmd_rcv);
  if (serial_cmd_rcv.length() < 36 ||
      serial_cmd_rcv.substring(0,4) != "SSID" )  {serial_cmd_rcv="";return;}
  ProtocolDeal(serial_cmd_rcv.c_str());
/* Current device DP values */
HardwareSerial My485Serial(ADAPT485_NUM);
//---RS485 setting end----
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 25;
/* Data point define */
typedef enum
  DPID_SWITCH01 = 1,
  DPID_SWITCH02,DPID_SWITCH03,
  DPID_SWITCH04,DPID_SWITCH05,DPID_SWITCH06,
  DPID_SWITCH07 = 101,
  DPID_SWITCH08,DPID_SWITCH09,DPID_SWITCH10,
  DPID_SWITCH11,DPID_SWITCH12,DPID_SWITCH13,
  DPID_SWITCH14,DPID_SWITCH15,DPID_SWITCH16,
  DPID_SWITCH17,DPID_SWITCH18,DPID_SWITCH19,
  DPID_SWITCH20,DPID_SWITCH21,DPID_SWITCH22,
  DPID_SWITCH23,DPID_SWITCH24,DPID_SWITCH25,
  DPID_SWITCH26,DPID_SWITCH27,DPID_SWITCH28,
  DPID_SWITCH29,DPID_SWITCH30,DPID_SWITCH31,
  DPID_SWITCH32,
}HXBS_DPID_DEF;
#define LED_WiFi  26
//#define LED_User  33
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_String, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH01, DP_TYPE_BOOL},{DPID_SWITCH02, DP_TYPE_BOOL},
  {DPID_SWITCH03, DP_TYPE_BOOL},{DPID_SWITCH04, DP_TYPE_BOOL},
  {DPID_SWITCH05, DP_TYPE_BOOL},{DPID_SWITCH06, DP_TYPE_BOOL},
  {DPID_SWITCH07, DP_TYPE_BOOL},{DPID_SWITCH08, DP_TYPE_BOOL},
  {DPID_SWITCH09, DP_TYPE_BOOL},{DPID_SWITCH10, DP_TYPE_BOOL},
  {DPID_SWITCH11, DP_TYPE_BOOL},{DPID_SWITCH12, DP_TYPE_BOOL},
  {DPID_SWITCH13, DP_TYPE_BOOL},{DPID_SWITCH14, DP_TYPE_BOOL},
  {DPID_SWITCH15, DP_TYPE_BOOL},{DPID_SWITCH16, DP_TYPE_BOOL},
unsigned char pid[] = {"7en1hzfnjtvprt35"}; ////change pid here....
#elif defined(KINCONY_H8X)
unsigned char pid[] = {"zyauvyer5insa2ne"}; ////change pid here....
  {DPID_SWITCH17, DP_TYPE_BOOL},{DPID_SWITCH18, DP_TYPE_BOOL},
  {DPID_SWITCH19, DP_TYPE_BOOL},{DPID_SWITCH20, DP_TYPE_BOOL},
  {DPID_SWITCH21, DP_TYPE_BOOL},{DPID_SWITCH22, DP_TYPE_BOOL},
  {DPID_SWITCH23, DP_TYPE_BOOL},{DPID_SWITCH24, DP_TYPE_BOOL},
  {DPID_SWITCH25, DP_TYPE_BOOL},{DPID_SWITCH26, DP_TYPE_BOOL},
  {DPID_SWITCH27, DP_TYPE_BOOL},{DPID_SWITCH28, DP_TYPE_BOOL},
  {DPID_SWITCH29, DP_TYPE_BOOL},{DPID_SWITCH30, DP_TYPE_BOOL},
  {DPID_SWITCH31, DP_TYPE_BOOL},{DPID_SWITCH32, DP_TYPE_BOOL},
unsigned char pid[] = {"ytgvxhy4zoaxdqtp"}; ////change pid here....
#endif
/* last time */
unsigned long last_time = 0;
* @param {unsigned char} dpid
* @return {unsigned char}
  int16_t index_out_coil = -1;
  unsigned char get_down_cmd = false;
  for(int16_t i=0;i<RLY_NUMS;i++)
    if(dpid == dp_array[i][0])
      index_out_coil = i;
      break;
    #if DEBUG
    Serial1.print("Rcv Command:<dpid,");
    Serial1.print(dpid,DEC);
    Serial1.print(" value,");
    Serial1.print(value[0],DEC);
    Serial1.print(" len,");
    Serial1.print(length,DEC);
    Serial1.println("> ");
  #endif
  if(index_out_coil < 0) return TY_ERROR;
  get_down_cmd = my_device.mcu_get_dp_download_data(dpid,value,length);
  #if DEBUG
    Serial1.print("get_down_cmd value is:<");
    Serial1.print(get_down_cmd,DEC);
  #endif
  SetRlyByChannel(index_out_coil,get_down_cmd?true:false);
  Serial1.print("Send board control command:");
  Serial1.println(command_str_arr);
  uint16_t result = client.write(command_str_arr,strlen(command_str_arr));
  #if DEBUG
    Serial1.print("client WriteCoilAddr<");
    Serial1.print(index_out_coil,DEC);
    Serial1.print("> result:<");
    Serial1.print(result,DEC);
  #endif
  my_device.mcu_dp_update(dpid, value, length);
  return TY_SUCCESS;
  My485Serial.begin(SERIAL_BAUD, SERIAL_8N1, RX_PIN, TX_PIN); //RS485 serial port
  Serial.begin(9600,SERIAL_8N1,22,19);  //Tuya module serial port
  Serial1.begin(115200,SERIAL_8N1,3,1);   //USB serial port
  // Serial with tuyawifi
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
/*  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);*/
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 2);
  //delay(300);
  last_time = millis();
  String ns_ssid = prefs.getString("ns_ssid","123");
  String ns_psw = prefs.getString("ns_psw","123");
  String ns_ip = prefs.getString("ns_ip","127.0.0.1");
  server_port = prefs.getUShort("ns_port",4096);
  memcpy(ssid_buf,ns_ssid.c_str(),ns_ssid.length());
  memcpy(password_buf,ns_psw.c_str(),ns_psw.length());
  memcpy(server_ip,ns_ip.c_str(),ns_ip.length());
  prefs.end();
  WiFi.mode(WIFI_STA);     //set to STA mode
static void FuncStatusMachine(int status)
  switch(status)
    case INIT_STATUS:
    InitWifi();break;
    case RDY_STATUS:
    WifiConnect();break;
    case CONNECT_STATUS:
    TcpServerConn();break;
    case TCP_COMM:
    SendPeriodCheckCommand();break;
    case STOP_STATUS:
    break;
    default:break;
  FuncStatusMachine(statusMachine);  // read RS485 sensor
  delay(100);
  CheckClientRcv();
  my_device.uart_service();
  delay(100);
  GetSerialCmd();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
        led_state = LOW;
  /* report the temperature and humidity */
  if ((my_device.mcu_get_wifi_work_state() == WIFI_CONNECTED) ||
      (my_device.mcu_get_wifi_work_state() == WIFI_CONN_CLOUD)) {
    dp_update_all();
  delay(800);
static bool coils_old_status[RLY_NUMS] = {0};
static void CompareAndReport(void)
    if(coils_old_status[i] != rt_coils_status[i])
      coils_old_status[i] = rt_coils_status[i];
      my_device.mcu_dp_update(dp_array[i][0],rt_coils_status[i], 1);
      break;
* @param {*}
* @return {*}
  CompareAndReport();
here is arduino source code download link:
.zip   Hx.zip (Size: 5.12 KB / Downloads: 946)
  KC868 HA V2 and KCS v2
Posted by: whitehawk1979 - 06-03-2024, 12:06 AM - Forum: KC868-HA /HA v2 - Replies (5)
Hi
 Can you make a tutorial video for KC868 HA V2 and KCS v2 settings please ?
Question communicate between multiple boards
Posted by: bartekm01 - 06-02-2024, 12:15 PM - Forum: KC868-A16 - Replies (8)
I would like to ask about possibility to communicate between two or more KC868-A16 boards. So my scenario is that I have two A16s connected via lan cable to my local network. I was able to configure them in home assistant (esphome add on) using some of your lessons. I`m also able to add switches etc. But I dont know how to implement one thing - I have relays connected to digital outputs of those two boards (A16_1, A16_2) which are controlling lights/rollers in my house. Next to my front door I have wall switch which is connected to board A16_1 (input_1). What I want to achieve is that when I click wall switch all lights (both boards) should be turned off. So simply saying one input should turn off all outputs from both boards. How to send information from board A16_1 to a16_2 (in the future I`m planning to have more boards so I wish them to communicate one to each other)?  is it possible? I`m beginner so I will be grateful for detailed answer Smile thank you in advance for support!
  Kincony KC868-A32 Pro 250V / 7A
Posted by: Lamri - 06-02-2024, 08:50 AM - Forum: KC868-A32/A32 Pro - Replies (1)
The outputs of the Kincony KC868-A32 Pro module are 250V / 7A. What is the risk when I protect my lighting circuits with 10A circuit breakers?
  schematic of KC868-HAv2
Posted by: admin - 06-01-2024, 10:59 PM - Forum: KC868-HA /HA v2 - No Replies
.pdf   R485HA_V200.pdf (Size: 146.12 KB / Downloads: 1187)
  Factory Default Firmware
Posted by: ia1 - 06-01-2024, 03:12 PM - Forum: "KCS" v2 firmware system - Replies (3)
Dear Admin
After updating with KCS v2 firmware if I need to go back original factory default firmware, from where I can download, I have A4,A6,A16,A32.
Imran Alam
