» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 220 online users.
» 0 Member(s) | 198 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, HeadlessChrome, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  868-A4S
Posted by: DabblerIOT - 08-22-2024, 10:09 PM - Forum: Getting Started with ESPHome and Home Assistant - Replies (9)
Hi.   Had everything working this past winter with the 868-A4S board and home assistant.
I recompiled my code and installed it on the device.   It installs, then hangs, can't connect or anything.
If I say prepare for first use from home assistant, it sets the board type (to esp32-c3-devkitm-1).
This installs, and runs normally, but not all pins are available to the program, and when I press the reset button it defaults back to the old firmware that shipped with the board (where it cycles the relays and outputs on power up).
So..
Have any examples of home assistant yaml for current revision of home assistant that should install and work?
Or any feedback on what the board type should be?   esp32dev doesn't work for me.
Thanks in advance.   I don't think I missed any step, but I am probably doing something wrong.
  Tuya connection drops out
Posted by: Aza0110 - 08-21-2024, 09:10 AM - Forum: KC868-A16 - Replies (7)
Hi, has anyone got this issue? Everything works fine tcp udp http server, client etc except for Tuya.
Monitor Page its green but only for about 10 seconds then goes red disconnected for ten seconds then back to green.
Tuya App shows input/output state but can't control any switches. I'm guessing the router as it works fine when hotspot from my phone but all my other Tuya devices work fine on my router.
Have tried on LAN only, wifi only, dmz to board.
Very strange as i have 10+ tuya devices that work no problem
  A16 Modbus and Coil
Posted by: Arek - 08-20-2024, 07:29 PM - Forum: KC868-A16 - Replies (3)
I have a problem when controlling via modbus. When coil No.1 is activated, coil No.9 is activated on board. When starting coil No. 9, coil No.1 is activated on board. The coils work interchangeably. 1->9, 2->10, 3->11....8->16 and 9->1, 10->2, 11->3....16->8. The same situation occurs with input.
what's wrong?
  Ethernet and requests
Posted by: Vokob - 08-20-2024, 08:59 AM - Forum: KC868-A8 - Replies (4)
Hello!
I can't figure out the ethernet in arduino ide.
I need to get data from an http/https web page.
Help me, please!
  Problem with KC868-A16 Firmware
Posted by: Arek - 08-19-2024, 06:05 PM - Forum: "KCS" v2 firmware system - Replies (3)
Hi, I have a problem with KC868-A16 board. I can't log in to the board. Firmware installation performed in accordance with the guide returns information as shown in the attached screenshots. The LAN port LEDs do not light up. I can't log in to the board.
what could be the cause? where to start?
Screenshot_1
Screenshot_2
Screenshot_3
  A32Pro problem whit lan and ntp
Posted by: Carlithost - 08-19-2024, 10:10 AM - Forum: Development - Replies (3)
Good morning, I have a KinCony A32 Pro 32 module, firmware version 1.0.5 and I noticed these anomalies:
 1. the time zone does not update, I tried to enter various ntp servers but to get the correct time for my zone (UTC+1) I have to enter UTC+8.
 2. if I set the LAN IP in DHCP everything works fine, if instead I set it in static, the module blocks as if it were in conflict with another IP address. By removing the network cable it starts working again but logically without lan but only in wifi.
Thanks for help.
  KC868-A16
Posted by: vjh - 08-18-2024, 09:02 AM - Forum: KC868-A16 - Replies (1)
Good morning,
ESP32 works limitedly in AP mode, LAN does not work even as a static address, can be connected via wifi. As soon as you enter the transition to STA mode the ESP32 stops working (other ESP32 in the same place works without problems) (it does not get an address, the DHCP server does not have a new client). According to the log from the serial port, as soon as you enter transition to STA mode, the listing ends. I tried using firmware V2.2.2.
  4G card applications
Posted by: BaconRanch - 08-18-2024, 02:02 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (1)
Is anyone using the device with the 4G sim card to expose the Home Assistant and enabling control of the relays amd sensors of the server16 from anywhere that is not not on your same LAN network?  Or is this not possible?  I am considering Starlink but would like to test with sometging lesss expensive first.
Thank you,
Mark @ Bacon Ranch
  Reading Load Cell with KC868-A6
Posted by: vladaman - 08-17-2024, 01:03 PM - Forum: KC868-A6 - Replies (2)
do you have any idea how to read data from load cell such as this using KC868-A6 ?
[Image: TBcJN86DBlgeN23_v8S_dl2Rk8IY2MUPQMjkAnQs...1JbCqCleWB]
  Inquiry About Newer Software Version for KC868-SERVER Device
Posted by: engrezk - 08-17-2024, 11:15 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (1)
Is there a newer version of the software SERVER_V1.48 for the KC868-SERVER device?
