» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 320 online users.
» 0 Member(s) | 296 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  NTC 10KOHM temperature sensor
Posted by: Kais - 06-26-2024, 06:51 PM - Forum: KC868-A32/A32 Pro - Replies (1)
Hello Admin !
Is it possible / how to wire an NTC 10KOHM temperature sensor to the A32 board ? thanks
(i'll join a picture of it)[Image: 51PKKpebNoL._SL1200_.jpg]
  KC868 Uair  external sensor SHT3xD erro
Posted by: hassankash - 06-25-2024, 03:35 PM - Forum: KC868-Uair - Replies (7)
I'm trying to load the Uair with external sensor and got the below error:
19:16:51][C][dallas.temp.sensor:036]:  Update Interval: 60.0s
[19:16:51][C][sht3xd:049]: SHT3xD:
[19:16:51][D][sht3xd:055]:  Error reading serial number
[19:16:51][E][sht3xd:064]:  Communication with SHT3xD failed!
[19:16:51][E][component:082]:  Component sht3xd.sensor is marked FAILED
[19:16:51][C][captive_portal:088]: Captive Portal:
[19:16:51][C][mdns:115]: mDNS:
  KCS Firmware and home assistant together ?
Posted by: Kais - 06-24-2024, 05:40 PM - Forum: "KCS" v2 firmware system - Replies (5)
Hello !
Is there a way to run KCS Firmware and home assistant simultaneously?
  m30 rs485 compatible energy meter
Posted by: kiloptero - 06-24-2024, 12:45 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (15)
hi, i will purchase a m30
and want to know if a rs485 like this
Just found this amazing item on AliExpress. Check it out! CLP33.582 | 1P Energy Meter RS485 Modbus RTU Monitor Voltage Current Power Factor Frequency Toal Consumption
https://a.aliexpress.com/_mstTztE
its compatible and if the esphome yaml include this comunication
to see all the power di energy in 1 sensor!
  Tuto for NOOBS
Posted by: Denis S. - 06-23-2024, 02:05 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Basic Ewelink and HA user, I'm just a noob and try to "play" at the moment with my new KC868-A4
The idea is that at the end, i can connect my store to sensors "Rain", "Temperature", "Light (UV), send command UP and Down, this only with the KC868, later on, intergate it to HA to monitor my veranda when I'm away... but :
I downloaded Arduino IDE and after struggling installing serial port driver, I finaly managed to see NodeMCi-32s on COM3.
But it seems no communication is possible with the board as I have an error message when I try to send some commands  :
Invalid FQBN: getting build properties for board esp32:esp32:nodemcu-32s: invalid value '460800' for option 'UploadSpeed'
Compilation error: Invalid FQBN: getting build properties for board esp32:esp32:nodemcu-32s: invalid value '460800' for option 'UploadSpeed'
I searched on Kinkony guides, Youtube channel, but didnt find any complete startup-guide. Seems they are all assuming on is already familiar... its unfortunately not my case. They probably exist somewhere, but not so easy to find. Even this idiot Microsoft copilot was unable to give me detailed informations. its alway "connect to the device and... " but how to be sure iam connected to the device ?
Any links with such guides for noobs / Youtube channels... (really from the scratch) ?
  A32 RRO -homeassistanbt-Tuya-SIM-RF
Posted by: hassankash - 06-22-2024, 08:06 AM - Forum: KC868-A32/A32 Pro - Replies (11)
hi Admin
is there is any way I can have the source file not the .bin for the A32 pro with RF and SIM modules that has delays of 10 ms?
Because using that file I can't connect it to home assistant .
Thanks,
  KCS v2.2.4 versus ESPHOME
Posted by: Philadam - 06-21-2024, 04:19 AM - Forum: KC868-AM - Replies (1)
I am testing ds18b20 sensors with KC868-AM I have 8 sensors attached, 2 per input terminal.
With KCS v2.2.4 firmware I get results from at least 4 sensors. See picture.
However when I try to setup in ESPHOME I consistently getting the following:
20:42:58][C][gpio.one_wire:016]: GPIO 1-wire bus:
[20:42:58][C][gpio.one_wire:017]:  Pin: GPIO5
[20:42:58][C][gpio.one_wire:080]:  Found devices:
[20:42:58][C][gpio.one_wire:082]:    0x8c000000306c8028 (DS18B20)
[20:42:58][C][gpio.one_wire:082]:    0xc800000030c41b28 (DS18B20)
[20:42:58][C][gpio.one_wire:016]: GPIO 1-wire bus:
[20:42:58][C][gpio.one_wire:017]:  Pin: GPIO14
[20:42:58][W][gpio.one_wire:078]:  Found no devices!
[20:42:58][C][gpio.one_wire:017]:  Pin: GPIO13
[20:42:58][C][gpio.one_wire:017]:  Pin: GPIO33
[20:42:58][C][gpio.one_wire:082]:    0xfe00000030e49428 (DS18B20)
[20:42:58][C][gpio.one_wire:082]:    0x770000003065cc28 (DS18B20)
It cannot find any sensors on gpio 13 and 14. This was working before the ESPHOME update to 2024.6.1
Any idea on what might have happened?
Also tested with one ds18b20 sensor in each one of the sensor inputs with KCS v2.2.4 firmware and each individual sensor input worked.
.txt   esphome.txt (Size: 1.36 KB / Downloads: 511)
  Dallas DS18b20 sensor is no longer found after the last ESPHOME update - KC868-A4
Posted by: csacomani - 06-20-2024, 07:40 PM - Forum: KC868-A4 - Replies (10)
I made the corrections requested by ESPHOME 2024.6.1 for 1 WIRE:
Dallas:
- pin: 13
for
one_wire:
  pin: 13
  - platform: dallas_temp
    address: 0x650114534966aa28
And the sensor was no longer recognized, I am receiving the message in the LOG:
Help me
  Home Assistant ESP home AIO firmware update failed
Posted by: telewizard13 - 06-20-2024, 11:56 AM - Forum: KC868-AIO - Replies (6)
In Home Assistant this morning, there was an ESP home update and a AIO firmware update shown. I clicked on install in the AIO update, but it failed. Do you have any information about what might be the issue?
  on relays via modbus rs485
Posted by: 31marlosouza - 06-20-2024, 02:57 AM - Forum: KC868-A6 - Replies (7)
Olá, estou com dificuldade para ativar os relés da placa KC868 - através do pool modbus consigo ler as entradas analógicas, ler as entradas digitais, mas não consigo ativar os relés. Você poderia me enviar a documentação.
