» Members: 9,561
» Latest member: Energizer
» Forum threads: 4,184
» Forum posts: 20,809
There are currently 33 online users.
» 0 Member(s) | 23 Guest(s)
Amazonbot, Applebot, Baidu, Bing, PetalBot, bot
N60 Voltage reference
Forum: N60
2 hours ago
K868-a32 plastic case
Yesterday, 08:48 AM
CT Clamp Compatibility
08-09-2026, 10:32 PM
» Replies: 10
KinCony F8 + ESPHome: Una...
Forum: F8
08-08-2026, 11:51 PM
How to get started
08-07-2026, 11:42 PM
» Replies: 39
Questions on the B4M
Forum: B4M
08-07-2026, 11:19 PM
cannot see KC868-A6 in ro...
08-07-2026, 09:59 AM
» Replies: 7
CAN-BUS Transceiver
Forum: T16M
08-07-2026, 09:57 AM
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
08-06-2026, 07:18 AM
KC868-A16
Last Post: 5310h
08-05-2026, 09:40 PM
» Replies: 9
  B8M Schematic
Posted by: mikkojay - 01-15-2026, 06:41 PM - Forum: B8M - Replies (5)
Is the schematic diagram available for the B8M?
I am specifically looking to see if the INT pin 1 of the PCF8575 is connected to anything.
I have used the PCF8575 IC in other applications, and prefer to use the interrupt when possible.
Thank You
  ESPHome Compile warning message
Posted by: petez69 - 01-15-2026, 06:16 AM - Forum: KC868-A8 - Replies (1)
Hi Admin
Using ESPHome and Homeassistant, the publish_initial_state warning has been there for some time when compiling.  Is this an option we fix in YAML or something the ESPHome people will sort with their code ?
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq/#why-am-i-...pping-pins
WARNING The 'publish_initial_state' option has been replaced by 'trigger_on_initial_state' and will be removed in a future release
Many Thanks..Peter
  F32 and 433 Mhz
Posted by: lulu01 - 01-15-2026, 12:21 AM - Forum: F32 - Replies (5)
on the F32, if I want to use a Kincony 433 Mhz remote:
- can I do this with ESPHome instead of KCS?
- do I need to buy a RF433 MHz tx/rx module, or is it included in the board already?
- with the ESPHome firmware, how do I learn the codes from the remote controller and associate them to relays?
Thank you!
  Voltage wrong
Posted by: Painy - 01-14-2026, 01:20 PM - Forum: N30 - Replies (4)
Hello
I just bought an N30.
I have a 3 phase (3x240V) energy system at home.
So 3 wires (L1, L2 and L3) come in with 240V difference between the wires, but no neutral.
Each of those wires has a CT clamp from KC webstore around it.
I flashed KCS  v3.19.0 and ARM processor (N10203060_KU_V20_251231), but the readings show a frequency of 3x10 Hz (should be 50) and a voltage of +- 20V, one of +- 40V and one of +-30V. All three should be around 230V.
Al my fuse boxes are 2fase, so it always takes two of three available phases. The CT clamp around those seems to have good current readings.
I also have two higher load 3 phase fuses.
The fuse has 3 outgoing wires, each a phase. Each of those wires has a CTclamp around it.
In software, one is is registered on E3ch8,ch9 and ch10. Channels 8 and 10 always show 0.59A  and channel 9 always 0A. When I'm using that fuse (cooking), ch8 and 10 go up and show the same value. ch9 stays at 0.
Also, like other post, Energy always 0KWh
  [arduino code examples for B4]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 01-14-2026, 04:05 AM - Forum: B4 - No Replies
* This program reads 4 input states from a PCF8574 I/O expander and
* controls a corresponding 4-channel relay module. When an input pin
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24
#include <Wire.h>
#include <PCF8574.h>
// I2C pins
#define SDA 8
#define SCL 18
// PCF8575 I2C address
#define INPUT_I2C_ADDRESS 0x24
// Create PCF8575 object
PCF8574 pcf8574_IN(INPUT_I2C_ADDRESS);
  Wire.begin(SDA, SCL);
    pcf8574_IN.pinMode(P0, INPUT);
    pcf8574_IN.pinMode(P1, INPUT);
    pcf8574_IN.pinMode(P2, INPUT);
    pcf8574_IN.pinMode(P3, INPUT);
      pcf8574_IN.pinMode(P4, OUTPUT);
    pcf8574_IN.pinMode(P5, OUTPUT);
    pcf8574_IN.pinMode(P6, OUTPUT);
    pcf8574_IN.pinMode(P7, OUTPUT);
  // Initialize PCF8575
  pcf8574_IN.begin();
  // Turn off all relays first (assuming LOW activates the relay)
  for (int i = 4; i < 8; i++) {
    pcf8574_IN.digitalWrite(i, HIGH);  // Set to HIGH to turn off the relay
  delay(50);
  if (pcf8574_IN.digitalRead(0)) pcf8574_IN.digitalWrite(4, HIGH); else pcf8574_IN.digitalWrite(4, LOW);
  delay(50);
  if (pcf8574_IN.digitalRead(1)) pcf8574_IN.digitalWrite(5, HIGH); else pcf8574_IN.digitalWrite(5, LOW);
  delay(50);
  if (pcf8574_IN.digitalRead(2)) pcf8574_IN.digitalWrite(6, HIGH); else pcf8574_IN.digitalWrite(6, LOW);
  delay(50);
  if (pcf8574_IN.digitalRead(3)) pcf8574_IN.digitalWrite(7, HIGH); else pcf8574_IN.digitalWrite(7, LOW);
  delay(50);
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 846 bytes / Downloads: 284)
.zip   11-input-trigger-output.ino.merged.zip (Size: 199.42 KB / Downloads: 288)
  [arduino code examples for B4M]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 01-14-2026, 04:05 AM - Forum: B4M - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <Wire.h>
// I2C pins
#define SDA 8
#define SCL 18
  pcf8574_IN.begin();
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
.zip   11-input-trigger-output.zip (Size: 846 bytes / Downloads: 242)
.zip   11-input-trigger-output.ino.merged.zip (Size: 199.42 KB / Downloads: 318)
  [arduino code examples for B4]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 01-14-2026, 04:04 AM - Forum: B4 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 309)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 202.58 KB / Downloads: 292)
  [arduino code examples for B4M]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 01-14-2026, 04:04 AM - Forum: B4M - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 255)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 202.58 KB / Downloads: 250)
  [arduino code examples for B4]-09 how to communication with Tuya WiFi module
Posted by: admin - 01-14-2026, 04:02 AM - Forum: B4 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 15
#define RXD_PIN 16
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 283)
  [arduino code examples for B4M]-09 how to communication with Tuya WiFi module
Posted by: admin - 01-14-2026, 04:02 AM - Forum: B4M - No Replies
* Functionality:
#define TXD_PIN 15
#define RXD_PIN 16
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 288)
