» Members: 10,011
» Latest member: mentorHub
» Forum threads: 4,252
» Forum posts: 21,053
There are currently 473 online users.
» 0 Member(s) | 459 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Crawl, PetalBot, bot
Las Firmware ?
Last Post: oxedgar
1 hour ago
» Replies: 7
kc868-a6 analog input
Yesterday, 11:38 PM
A32 pro tuya
Yesterday, 11:38 PM
Disconnect loop with Home...
Forum: F16
Yesterday, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
Yesterday, 01:16 AM
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
  Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching
Posted by: krzemodam2 - 02-10-2026, 09:57 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
I am experiencing two possibly related issues with my Kincony A-128 controller.
Issue 1 – Digital Output LEDs glowing when OFF
Some Digital Output LEDs are glowing dimly even when the outputs are OFF in the control panel.
When I turn an output ON, the LED becomes much brighter (normal behavior).
Details:
  • One section has 8 LEDs dimly ON
  • Another section has 4 out of 8 LEDs dimly ON
  • The remaining 14 sections work correctly
  • The issue always affects the same sections
  • LEDs are visible directly on the board
  • I may have accidentally caused a short circuit on these outputs during wiring
Issue 2 – Module freezes when switching all outputs ON
When I use Home Assistant and press a button that turns all relays ON at once, the following happens:
  • The module freezes
  • All channels turn OFF
  • Home Assistant shows the device as offline
  • The module does not reconnect automatically
  • I have to disconnect power completely and power it on again for Home Assistant to discover it again
Important observations:
  • If I turn the outputs on slowly / step by step, the problem does not occur
  • The problem only appears when switching many outputs ON simultaneously
Load and power details
  • Most outputs are connected to 6A relays
  • Some outputs are connected to WAGO 16A relays (higher current consumption)
  • All relays and the A-128 module are powered from the same 24V power supply
  • Control voltage and relay supply voltage are both 24V
Questions
  1. Could the dimly glowing LEDs indicate damaged output channels?
  2. Could the freeze/offline behavior be caused by power supply overload or voltage drop when switching all outputs at once?
  3. Is this a known behavior of the A-128 when driving many relays simultaneously?
  4. Has anyone experienced similar issues with A-128 and Home Assistant?
I am attaching photos of the board showing the glowing LEDs.
I can also provide:
  • Firmware version
  • Power supply specifications
  • Voltage measurements during switching
Thank you for any help or suggestions.
Best regards
  G1
Posted by: mcdave - 02-10-2026, 12:44 AM - Forum: G1 - Replies (3)
Hi Admin,
I am planning to add a relay module to the G1, and I was wondering if you have any diagrams that I could use as a reference for how to properly add it.
This correct?
GPIO12 → relay IN
GND    → relay GND
5V    → relay VCC
12V+  → COM
NO    → Siren+
Siren- → GND
Thank you for your help.
  Help to chose the right hardware to control relays
Posted by: Serg!o - 02-09-2026, 04:31 AM - Forum: DIY Project - Replies (7)
I have an existing home automation setup and need your advice please.
I have multiple modules of relays as on the picture below, they are DPDT relays, 12v coil.
32 relays in total that I control with a device I bought online 5 years ago (Arduino with 8x4 (32) outputs), it listens to MQTT brocker on Home Assistant and basically turns the relays ON/OFF, which are controlling all my lights and a few ceiling fans/exhausts.
This device becomes unreliable and freezes from time to time so I need a replacement.
Can you please recommend a Kincony device so I can manage my existing relays.
Thank you.
[Image: Uc064ce43053f4ff2b135492379cd1dcaH.jpg]
[Image: Ueaec458ec4e6422a9d74ddec0e10e0f39.jpg]
  http requesto to toggle switch
Posted by: danielrio - 02-08-2026, 07:27 PM - Forum: B16 - Replies (4)
Hi all,
i have some B16 currently with the 3.80 kcs firmware.
I had the need to control an output on the module 2 when a DI on module 1 is pressed.
I saw i can do it with custom protocol. I tried with UDP message, but it seems a bit loosy, in some ways each 10 clicks, 2 or 3 are lost,  alternatively i thought i could do it with http call (POST or GET).
The problem is that i don't know how to do it with the KCS firmware, i don't know if there are some preconfigured urls to let the modules relays to be switched on off or toggled.
I saw on ESPHome there are some documentations talking about this possibility, but i'm not sure these are usable on KCS firmware.
Sorry i'm a bit new and i cannot find a way to do this, but i'm pretty sure it can be done easily, and i'm just not able to do it.
Could someone please help me?
  E16V3 - LED operations
Posted by: ldebacker - 02-08-2026, 05:10 PM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
On the E16V3, is there a way to reduce the intensity of the LEDs (throuh a modbus register setting, for example) ?
Thanks in advance,
BRs,
Laurent
  E16V3 - Noise reduction
Posted by: ldebacker - 02-08-2026, 10:58 AM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
The E16V3 works great so far.
I would just like to suggest an enhancement for future versions...
The relays, when changing state, generate some noise, which is normal.
However, the added cover is metallic, and it resonates quite a lot when the relays are changing state.
May be some internal isolation could be added to reduce the noise levels ?
Thanks in advance for considering the suggestion.
Best regards,
Laurent
  communication between 2 boards
Posted by: guycaluwaerts - 02-07-2026, 05:47 PM - Forum: DIY Project - Replies (4)
I have kc868-A16 and kc868-AP board, both connected with ethernet cable to the router. Both has their own IP-address.
Is it possible without using homeassistant to have an input on one board to control an output on the other board ?
With a long push on a button on input 1 from board KC868-A16, all outputs on KC868-a16 and KC868-AP has to go OFF.
Is this possible ? I cannot find an example in the description how to do this.
  KinCony Z1 Problem
Posted by: siwybug - 02-04-2026, 09:42 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (14)
Hello, I purchased a KinCony Z1. I have already tried many different ways of flashing various firmware versions, but the device is generally unstable. It connects to Wi-Fi and to MQTT, but nothing more than that works. No MQTT entities appear and nothing is discovered automatically. When I try to add ZigBee devices, it scans for them, detects them, pairs successfully, sends signals, and everything seems fine — but after a short while, those devices disappear.
  Digital Input Voltage
Posted by: wojtekkk87 - 02-04-2026, 08:36 AM - Forum: T64M - Replies (1)
What is the acceptable Voltage range for the Digital Inputs?
  DTSU 666 energy meter - any code?
Posted by: marekw - 02-03-2026, 07:13 PM - Forum: KC868-A8S - Replies (1)
I'm trying read from CHINT DTSU-666 meter, but no success. My code below. Anyone can help?
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  parity: NONE
  stop_bits: 1
  data_bits: 8
  debug:
    direction: BOTH
modbus:
  uart_id: mod_bus
  flow_control_pin: 32
modbus_controller:
  address: 0x02
  modbus_id: modbus_hub
  update_interval: 10s
  command_throttle: 500ms
  - platform: modbus_controller
    modbus_controller_id: dtsu666
    name: "Test - Napięcie UA"
    address: 0x2006
    register_type: read
    value_type: FP32
    unit_of_measurement: "V"
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    name: "Test - Prąd IA"
    address: 0x200C
    register_type: read
    value_type: FP32
    unit_of_measurement: "A"
    accuracy_decimals: 2
    filters:
      - multiply: 0.001
