» Members: 10,057
» Latest member: apkspanda
» Forum threads: 4,253
» Forum posts: 21,064
There are currently 251 online users.
» 0 Member(s) | 230 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot, owler
Best way to read from N30
Forum: N30
Last Post: ChrisNZ
7 hours ago
N60/N30/N20/N10 PC softwa...
Forum: N10
9 hours ago
» Replies: 7
getting the A8A inputs to...
Forum: Development
09-24-2026, 11:07 PM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
  DM4 ESPHome yaml for home assistant without tuya
Posted by: admin - 02-03-2026, 12:17 AM - Forum: DM4 - No Replies
  friendly_name: dm4
  board: esp32-s3-devkitc-1
ota:
  platform: esphome
web_server:
  port: 80
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 38
    rx_pin: 39
  - platform: uart
    uart_id: uart_1
    i2c_id: bus_a
    pcf8575: false
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
      number: 17
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
mcp4728:
  - id: dac_output
output:
- platform: mcp4728
  mcp4728_id: dac_output
  channel: A
  vref: internal
- platform: mcp4728
  channel: B
  vref: internal
- platform: mcp4728
  channel: C
  vref: internal
- platform: mcp4728
  channel: D
  vref: internal
light:
  - platform: monochromatic
    output: ac_dimmer_1
    gamma_correct: 1.0
    output: ac_dimmer_2
    gamma_correct: 1.0
    output: ac_dimmer_3
    gamma_correct: 1.0
    output: ac_dimmer_4
    gamma_correct: 1.0
esphome yaml file download:
.txt   DM4-HA-without Tuya.txt (Size: 4.4 KB / Downloads: 236)
  DM4 ESP32-S3 IO pins define
Posted by: admin - 02-03-2026, 12:15 AM - Forum: DM4 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8574: (input1-4): i2c address:0x24
P0:input1
P1:input2
P2:input3
P3:input4
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
MCP4728 DAC i2c address: 0x60
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO17
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO15
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
  [arduino code examples for DM4]-05 Read free GPIO state
Posted by: admin - 02-03-2026, 12:12 AM - Forum: DM4 - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 40
* - GPIO 7
* - GPIO 48
* - GPIO 47
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 0
* Hardware Requirements:
#define GPIO_PIN_40 40
#define GPIO_PIN_7 7
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_0 0
bool prevState[8] = {false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_40, INPUT);
  pinMode(GPIO_PIN_7, INPUT);
  pinMode(GPIO_PIN_48, INPUT);
  pinMode(GPIO_PIN_47, INPUT);
  pinMode(GPIO_PIN_13, INPUT);
  pinMode(GPIO_PIN_14, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_40);
  currentState[1] = digitalRead(GPIO_PIN_7);
  currentState[2] = digitalRead(GPIO_PIN_48);
  currentState[3] = digitalRead(GPIO_PIN_47);
  currentState[4] = digitalRead(GPIO_PIN_13);
  currentState[5] = digitalRead(GPIO_PIN_14);
  currentState[6] = digitalRead(GPIO_PIN_21);
  currentState[7] = digitalRead(GPIO_PIN_0);
  for (int i = 0; i < 8; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_40 :
                   i == 1 ? GPIO_PIN_7 :
                   i == 2 ? GPIO_PIN_48 :
                   i == 3 ? GPIO_PIN_47 :
                   i == 4 ? GPIO_PIN_13 :
                   i == 5 ? GPIO_PIN_14 :
                   i == 6 ? GPIO_PIN_21 : GPIO_PIN_0);
      Serial.print(" changed to ");
      // Update the previous state
arduino ino file download:
.zip   5-free-gpio-state.zip (Size: 1.04 KB / Downloads: 393)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.57 KB / Downloads: 382)
  [arduino code examples for DM8]-05 Read free GPIO state
Posted by: admin - 02-03-2026, 12:12 AM - Forum: DM8 - No Replies
* - GPIO 40
* - GPIO 7
* - GPIO 48
* - GPIO 47
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 0
.zip   5-free-gpio-state.zip (Size: 1.04 KB / Downloads: 419)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.57 KB / Downloads: 338)
  [arduino code examples for DM4]-02 Read digital input ports state
Posted by: admin - 02-03-2026, 12:09 AM - Forum: DM4 - No Replies
KeyPressed on PIN1
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Define I2C pins
#define I2C_SDA 8   // SDA pin
#define I2C_SCL 18  // SCL pin
// Set i2c address
PCF8574 pcf8574(0x24);
unsigned long timeElapsed;
    Wire.begin(I2C_SDA, I2C_SCL);
//    pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
    if (pcf8574.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
    delay(300);
.zip   2-digital-input.zip (Size: 667 bytes / Downloads: 355)
.zip   2-digital-input.ino.merged.zip (Size: 199.38 KB / Downloads: 357)
  [arduino code examples for DM4]-01 4 Channel DAC output by digital input buttons
Posted by: admin - 02-03-2026, 12:08 AM - Forum: DM4 - No Replies
// Basic demo for configuring the MCP4728 4-Channel 12-bit I2C DAC
#include <Adafruit_MCP4728.h>
#include <Wire.h>
Adafruit_MCP4728 mcp;
TwoWire MYI2C = TwoWire(0);
void setup(void)
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MCP4728 test!");
  MYI2C.begin(I2C_SDA, I2C_SCL,100000);
  // Try to initialize!
  if (!mcp.begin(MCP4728_I2CADDR_DEFAULT,&MYI2C)) {
    Serial.println("Failed to find MCP4728 chip");
    while (1) {
      delay(10);
  mcp.setChannelValue(MCP4728_CHANNEL_A, 4095);
  mcp.setChannelValue(MCP4728_CHANNEL_B, 2048);
  mcp.setChannelValue(MCP4728_CHANNEL_C, 1024);
  mcp.setChannelValue(MCP4728_CHANNEL_D, 0);
void loop() { delay(1000); }
.zip   1-dac-4ch.zip (Size: 596 bytes / Downloads: 341)
.zip   1-dac-4ch.ino.merged.zip (Size: 198.77 KB / Downloads: 353)
  connecting sensors
Posted by: skench - 02-02-2026, 11:07 PM - Forum: KC868-A8 - Replies (5)
Good afternoon, can you tell me how to connect a temperature and humidity sensor to the A8 or A16 boards? I have several different sensors
An AM2120 temperature and humidity sensor https://ali.click/klm2yz
There is also a BME280 pressure and temperature sensor. https://ali.click/zmm2ye
And I also bought a DHT22 temperature and humidity sensor. https://ali.click/mom2y9 there's a problem with everyone, with the latest DHT22, I don't understand where to get the 5v from, which vcc pin to connect to to get the 5v? I'm acting on the picture https://www.kincony.com/forum/showthread.php?tid=3194 I tried to connect the AM2120 in different ways, both to the ds18b20 and to other neighboring ports and tried the settings in the sensors tab, as well as different firmware ksc v2, I thought there might be a problem with the firmware, but I also failed.
  TA with Home Assistant with Ethernet Only
Posted by: upstream - 02-02-2026, 10:54 PM - Forum: Getting Started with ESPHome and Home Assistant - Replies (3)
How do I get the Tiny Alarm System (TA) to work with Home Assistant?
The yaml example at this post is set to use wifi. I want to use ethernet / poe only.
However, if I remove the wifi components, this line:
PHP Code:
- platform: tuya_wifi_mcu
is located all over the place.
Does anyone have a complete yaml example without any wifi (ethernet only)?
  E16V3 - baudrate change
Posted by: ldebacker - 02-02-2026, 04:40 PM - Forum: Suggestions and feedback on KinCony's products - Replies (3)
Is there a way to change the default RS485 baudrate (which is 38400 bps) ?
Any existing register to change the RS485 parameters ?
Thanks in advance !
  E16v3 - CE
Posted by: ldebacker - 02-02-2026, 04:35 PM - Forum: Suggestions and feedback on KinCony's products - Replies (9)
I have seen the CE certificate for the Kincony products here: https://www.kincony.com/images/patent/CCJS.2411163.pdf
This certificate mentions The Kincony V2, but not the V3.
Where can I find the certificate for the V3?
Thanks in advance !
