» Members: 9,526
» Latest member: naderkenway
» Forum threads: 4,182
» Forum posts: 20,780
There are currently 18 online users.
» 0 Member(s) | 10 Guest(s)
Amazonbot, Applebot, Baidu, Google, bot
KC868-A16 UART pins
Last Post: meowdokugame
Yesterday, 07:40 AM
KC868-A32 Malfunction Aft...
Forum: KC868-A32/A32 Pro
Yesterday, 06:19 AM
KinCony F8 + ESPHome: Una...
Forum: F8
08-02-2026, 11:00 PM
F8 ESPHome yaml for home ...
Forum: F8
Schema A16V3 for Research...
Forum: KC868-A16v3
Last Post: hamzachaouri
08-02-2026, 10:34 PM
B8 ADS1115 current inputs
Forum: B8
07-29-2026, 09:47 PM
KINCONY IN KSA
07-29-2026, 10:43 AM
» Replies: 14
A32 Pro ESPHome yaml for ...
07-27-2026, 06:25 AM
E8v3 E16v3 E24v3 relay mo...
Forum: Extender module
07-27-2026, 01:00 AM
KC868-H32B V5.08 firmware
Forum: News
07-25-2026, 11:53 PM
» Replies: 23
  Pinout od AS Voice Assistant P1 and P2???
Posted by: ZodInLynn - 12-07-2025, 01:19 PM - Forum: KinCony AS - Replies (1)
Hi, I am trying to add onto the Kincony AS Voice assistant (hardware) and I cannot find the pinout of the P1 and P2 "connectors" (are they set up for 433mhx transmitter and receiver?)
I have looked everywhere and cannot find any info.
could you please let me know (and add the info to the product web page for others??) what the pins on these "ports" do and what GPIO they area attached to???
a graphic with all of the solder pads labelled would be most helpful......
  KC868-A16 HTTP request config
Posted by: basilioo - 12-06-2025, 06:42 PM - Forum: KC868-A16 - Replies (5)
I can't configure sending an http request with kc868-a16 board. Рlease help me make the correct settings.
[Image: 2025-12-06_21-08-59.jpg][Image: 2025-12-06_21-10-20.jpg]
  Can the usb-c port be used to power another device?
Posted by: bernieke - 12-06-2025, 09:28 AM - Forum: F24 - Replies (3)
I was thinking of powering a small switch which draws 0.6A at 5V from the usb-c port on a F24, is this possible?
  KC868-COLB Tuya Integration
Posted by: danielyoud2@gmail.com - 12-05-2025, 11:52 PM - Forum: Development - Replies (11)
I have connected my KC868-COLB to wifi and verified connection to my router, entered Tuya Licence details sent through, generated the QR Code and connected device to Tuya App. It is always showing as offline in Tuya app and I cannot get it connected. I have also tried just with ethernet, and with both ethernet and wifi connected.
What else do i need to do to get my device online in Tuya App?
  PCF8574 INT pin on KC868-A6 — Is it connected to ESP32? Schematic request.
Posted by: Asil - 12-05-2025, 06:31 PM - Forum: KC868-A6 - Replies (3)
I am using the KC868-A6 board and reading digital inputs through the PCF8574.
I need to know whether the INT (nINT) pin of the PCF8574 is connected to any GPIO pin of the onboard ESP32.
I have checked the hardware documentation, but I could not find a clear answer.
Some older forum posts suggest that the INT pin might not be connected at all, but I want to confirm this specifically for the KC868-A6.
Could you please clarify:
  1. Is the PCF8574 INT pin connected to the ESP32 on the KC868-A6 board?
  2. If yes, which ESP32 GPIO pin is it wired to?
  3. If not, is there a pad or test point where the INT pin can be accessed so we can wire it manually?
  4. If possible, could you share the related portion of the schematic or PCB layout showing the PCF8574 connections?
I want to use hardware interrupts instead of polling the inputs constantly, so knowing the actual connection would help a lot.
Thank you very much!
  SSD1306 not working at same time as pcf8574
Posted by: Eggman - 12-05-2025, 01:49 AM - Forum: KC868-A series and Uair Smart Controller - Replies (7)
Does anyone know anything about the u8g2 library for the SSD1306 librarry onflicting with pcf8574?  It seems that as soon as I write to the display the inputs connected to pcf8574 controllers stop working.
I am just using standard sample code for u8g2 from this site.  But have included it in a much larger sketch.  With the u8g2 firstpage / nextpage loop my pcf8574 inputs work fine.  But as soon as I include those commands the inputs stop working.
  N30 installation for Home Assistant
Posted by: Vega - 12-04-2025, 10:20 PM - Forum: N30 - Replies (13)
I have an N30 but is there a installation manual how install a yaml file on it for Home Assistant.
And where can I find the Home Assistant yaml configuration file for ethernet/wifi/lora for the N30.
  KC868-A16 verison with N-channel MOSTFETS in DO
Posted by: Nicktonious - 12-04-2025, 12:08 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hello everyone. According to schematics of KC868-A16, P-MOSFETS are used in DO circuits. Is there any
a)  KC868-A16 alternaatives with another schematics
b) possibility to orded specific boards whith N-MOSFETS schematics
In all other aspects this board perfectly siuts my needs and I'm looking for opportnity to use it but the MOSFETS type in DO is extremly important in my case.
  E16T is not detected when connected via USB
Posted by: Sansol94 - 12-02-2025, 09:45 PM - Forum: KC868-E16T - Replies (8)
I have an e16t controller. Since the purchase, I have been using tuya (factory firmware). I recently decided to try a smart home based on the Home assistant. The Home assistant is installed on Raspberry pi5.
I found a post on the forum that you can install a new configuration file on the e16t (via esphome), which will allow you to control the relay via tuya and home assistant.
I did everything according to the scheme, and I ran into such a problem that esphome does not see the connected e16t device via usb. I used the cable from the e16t kit, I also tried to use another cable, but with no result.
After that I tried to connect e16t to PC (windows), but PC cannot detect e16t. The driver for the ch340c is installed.
Nothing happens when connected to a PC.
Can you tell me how to solve this problem?
  KC868-A8 simple switch
Posted by: sgrass - 12-02-2025, 05:07 AM - Forum: KC868-A8 - Replies (3)
I am building an off-road caravan and wish to use a simple smart switch to control the lights, etc. I found Kincony's Lesson 3 - Control relay by wall switch video on YouTube of a KC868-A4 receiving a momentary input switch that toggled the output relay on, a second momentary input toggled the relay off. It was perfect. I could have momentary switches in multiple locations to operate the same light (relay). I needed more relays, so ordered the larger A8 online.
I have zero experience with Arduino or ESP32, but I hoped to learn off the online examples. As part of that learning I discovered the A4 is different to the A8 through the addition of the PCF8574 to expand the I/O. I have managed to successfully upload the code from the Kincony - Arduino Lesson 19 on using the PCF8574, so I have the settings correct, I just can't find any code examples for making the A8 behave like the A4 example in lesson 3.
As a novice, could someone please point me in the right direction for the code to use a momentary press of a dry contact switch on an input to energise its corresponding relay, a second momentary contact on the same input to de-energise that relay again.
Obviously for all 8 inputs to control 8 relays. I would really appreciate it.
