» Members: 9,828
» Latest member: fun79iccom
» Forum threads: 4,219
» Forum posts: 20,935
There are currently 180 online users.
» 0 Member(s) | 166 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, bot
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
19 minutes ago
» Replies: 18
Kc868ia
Forum: KC868-AI
3 hours ago
HAv2 ESPHome
3 hours ago
Need Help Getting Started...
3 hours ago
KC868-H32B
3 hours ago
Last Post: viko
4 hours ago
» Replies: 15
No ethernet communication
Yesterday, 10:56 AM
» Replies: 10
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
09-04-2026, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
  Low Level Relay Trigger
Posted by: shawn@itcharleston.com - 12-11-2025, 06:47 AM - Forum: KC868-A16v3 - Replies (5)
Can the KC868-A16v3 be configured to output a Low Level (Ground) to trigger relays on the SainSmart 16-Channel 12V Relay Module Board?
  json configuration file for platformio
Posted by: realchair - 12-11-2025, 12:00 AM - Forum: KC868-A16v3 - Replies (3)
Hi guys, I am starting to code in platformio using espidf and I couldnt find the board in the list. Can someone provide me with one or tell what board I can use as substite?
  N20 ESPHome & HA - Line to Line voltage?
Posted by: WestCoastXS - 12-10-2025, 02:52 AM - Forum: N20 - Replies (4)
I have just received my N20.
Not very experienced with ESPHome but I did get firmware compiled and the unit is working over Wifi rather than ethernet.
I am in Canada. My electrical service is 120V/240V split phase.
Line 1 to ground is ~120V, line 2 to ground is ~120V, and L1 to L2 is ~240V.
I bought the N20 with its two voltage inputs in the hope that I could measure both 120V circuits and 240V circuits.
Is there a way to change to configuration for individual watt and kWh sensors to use the Line 1 plus Line 2 voltages?
So for example right now I have a 240V 4000W heater running.
There is no 120V load and no neutral so it only needs a single CT, but the voltage is the sum of L1 & L2.
For example my sensors currently read:
bl0910_1_current_1: 16.086A
bl0910_1_power_1: 1874.9W (incorrect)
bl0910_1_voltage: 117.3V
And also:
bl0910_2_voltage: 118.2V
The kWh would also be incorrect.
Can I adjust the yaml so that it calculates bl0910_1_power_1 based on  bl0910_1_voltage PLUS  bl0910_2_voltage?
But ONLY for that specific CT input?
So that other CTs on 120V circuits still calculate correctly?
It seems like it may be able to calculate this within Home Assistant.
I've already made a helper that adds the two voltage sensors together.
But they don't seem to have implemented the multiplication/product helper.
It would be immensely simpler if it could be implemented in the yaml.
Thank you
  Raspberry Pi5 Compute Module 5 IoT Server
Posted by: mcdave - 12-09-2025, 02:50 AM - Forum: Pi5 - Replies (1)
What is best a specific level of current or amper need to use when istall ubuntu OS its keep popoup the screen not compatible the 12V 2amp.
  KC868-A16 rs485
Posted by: guycaluwaerts - 12-08-2025, 04:31 PM - Forum: KC868-A16 - Replies (7)
I want to build a system based on the KC868-A16 board. Using the templates, I can program the outputs, but only in on/off mode.
I also want to use a number of dimmers (24Vdc PWM). That's why I thought I would do this via the RS485 bus and control a DMX controller. Unfortunately, I can't find anything about RS485 in the templates.
Is there more information or examples available about this?
  KC868-COLB Analog Sensor Data in Home Assistant
Posted by: danielyoud401@gmail.com - 12-08-2025, 01:08 PM - Forum: Development - Replies (12)
Hi
I have configured MQTT in home assistant, and connected my KC868-COLB and KC868-H32B boards successfully to home assistant.
I am able to control relay outputs on KC868-H32B, and can see digital inputs on KC868-COLB change when connecting . However Analog Inputs are staying at 0.0V. I am using a 0-5VDC sensor and have confirmed i am getting a valid signal from the sensor using a multimeter (0-2.5 Bar Pressure sensor, reading goes up to 0.5V when i blow into sensor)
I am using YAML code from https://www.kincony.com/mqtt-input-modul...stant.html, with device ID entered in
    - name: COLB-A1
      unique_id: COLB-A1
      state_topic: COLB/99e80c000000c11d13155107/state
      unit_of_measurement: "V"
      value_template: "{{ value_json.A1.value }} "
What else do i need to do to get a reading to register on home assistant?
  "KCS" v3.18.0 firmware BIN file download
Posted by: admin - 12-08-2025, 03:11 AM - Forum: "KCS" v3 firmware - No Replies
v3.18.0 improvement:
1. N10,N20,N30,N60 energy meter board support Loxone miniserver for UDP command.
2. support B32M controller.
3. support F4 controller.
4. fixed bug home assistant server restart mqtt connection issue.
5. add IR as IFTTT IF condition.
6. add Modbus sensor auto update to home assistant by mqtt auto discovery.
7. fixed bug with digital output when using IFTTT.
.zip   KCS_T32M_V3.18.0.zip (Size: 1.1 MB / Downloads: 416)
.zip   KCS_A2V3_V3.18.0.zip (Size: 1.1 MB / Downloads: 382)
.zip   KCS_A6V3_V3.18.0.zip (Size: 1.07 MB / Downloads: 445)
.zip   KCS_A8V3_V3.18.0.zip (Size: 1.13 MB / Downloads: 416)
.zip   KCS_A16V3_V3.18.0.zip (Size: 1.14 MB / Downloads: 502)
.zip   KCS_A32PRO_V3.18.0.zip (Size: 1.11 MB / Downloads: 405)
.zip   KCS_AG8_V3.18.0.zip (Size: 1.09 MB / Downloads: 452)
.zip   KCS_AIO_HYBRID_V3.18.0.zip (Size: 1.32 MB / Downloads: 380)
.zip   KCS_ALR_V3.18.0.zip (Size: 1.08 MB / Downloads: 412)
.zip   KCS_B8_V3.18.0.zip (Size: 1.13 MB / Downloads: 376)
.zip   KCS_B8M_V3.18.0.zip (Size: 1.13 MB / Downloads: 370)
.zip   KCS_B16_V3.18.0.zip (Size: 1.13 MB / Downloads: 381)
.zip   KCS_B16M_V3.18.0.zip (Size: 1.13 MB / Downloads: 394)
.zip   KCS_B24_V3.18.0.zip (Size: 1.13 MB / Downloads: 378)
.zip   KCS_B24M_V3.18.0.zip (Size: 1.13 MB / Downloads: 400)
.zip   KCS_B32M_V3.18.0.zip (Size: 1.13 MB / Downloads: 368)
.zip   KCS_DM16_V3.18.0.zip (Size: 1.1 MB / Downloads: 402)
.zip   KCS_F4_V3.18.0.zip (Size: 1.13 MB / Downloads: 373)
.zip   KCS_F8_V3.18.0.zip (Size: 1.13 MB / Downloads: 423)
.zip   KCS_F16_V3.18.0.zip (Size: 1.14 MB / Downloads: 376)
.zip   KCS_F24_V3.18.0.zip (Size: 1.14 MB / Downloads: 402)
.zip   KCS_F32_V3.18.0.zip (Size: 1.14 MB / Downloads: 401)
.zip   KCS_G1_V3.18.0.zip (Size: 1.09 MB / Downloads: 362)
.zip   KCS_KC_TA_V3.18.0.zip (Size: 1.09 MB / Downloads: 387)
.zip   KCS_N10_V3.18.0.zip (Size: 1 MB / Downloads: 405)
.zip   KCS_N20_V3.18.0.zip (Size: 1 MB / Downloads: 396)
.zip   KCS_N30_V3.18.0.zip (Size: 1 MB / Downloads: 395)
.zip   KCS_N60_V3.18.0.zip (Size: 1.01 MB / Downloads: 400)
.zip   KCS_T16M_V3.18.0.zip (Size: 1.08 MB / Downloads: 368)
.zip   KCS_T64M_V3.18.0.zip (Size: 1.1 MB / Downloads: 401)
.zip   KCS_T128M_V3.18.0.zip (Size: 1.1 MB / Downloads: 366)
.zip   KCS_TR_V3.18.0.zip (Size: 1.06 MB / Downloads: 376)
.zip   KCS_Z1_V3.18.0.zip (Size: 1.23 MB / Downloads: 402)
  "KCS" v2.2.18 firmware BIN file download
Posted by: admin - 12-08-2025, 03:01 AM - Forum: "KCS" v2 firmware system - No Replies
v2.2.18 improvement:
1. fixed bug Tuya app with SIM7600E 4G GPRS connection.
.zip   KCS_KC868_A2_V2.2.18.zip (Size: 795.32 KB / Downloads: 542)
.zip   KCS_KC868_A4_V2.2.18.zip (Size: 782.06 KB / Downloads: 475)
.zip   KCS_KC868_A4S_V2.2.18.zip (Size: 805.81 KB / Downloads: 395)
.zip   KCS_KC868_A6_V2.2.18.zip (Size: 780.69 KB / Downloads: 654)
.zip   KCS_KC868_A8_V2.2.18.zip (Size: 789.06 KB / Downloads: 520)
.zip   KCS_KC868_A8M_V2.2.18.zip (Size: 805.44 KB / Downloads: 434)
.zip   KCS_KC868_A8S_V2.2.18.zip (Size: 806.91 KB / Downloads: 442)
.zip   KCS_KC868_A16_V2.2.18.zip (Size: 796.59 KB / Downloads: 816)
.zip   KCS_KC868_A16S_V2.2.18.zip (Size: 807.03 KB / Downloads: 490)
.zip   KCS_KC868_A32_V2.2.18.zip (Size: 786.7 KB / Downloads: 436)
.zip   KCS_KC868_A32M_V2.2.18.zip (Size: 804.84 KB / Downloads: 454)
.zip   KCS_KC868_A64_V2.2.18.zip (Size: 786.93 KB / Downloads: 482)
.zip   KCS_KC868_A128_V2.2.18.zip (Size: 786.71 KB / Downloads: 399)
.zip   KCS_KC868_AG_V2.2.18.zip (Size: 764.89 KB / Downloads: 455)
.zip   KCS_KC868_AI_V2.2.18.zip (Size: 789.07 KB / Downloads: 460)
.zip   KCS_KC868_AIO_V2.2.18.zip (Size: 806.4 KB / Downloads: 414)
.zip   KCS_KC868_AK_V2.2.18.zip (Size: 767.24 KB / Downloads: 398)
.zip   KCS_KC868_AM_V2.2.18.zip (Size: 782.17 KB / Downloads: 424)
.zip   KCS_KC868_AP_V2.2.18.zip (Size: 784.65 KB / Downloads: 504)
.zip   KCS_KC868_ASR_V2.2.18.zip (Size: 761.56 KB / Downloads: 437)
.zip   KCS_KC868_E16S_V2.2.18.zip (Size: 791.28 KB / Downloads: 427)
.zip   KCS_KC868_UAIR_V2.2.18.zip (Size: 768.06 KB / Downloads: 400)
  Pinout od AS Voice Assistant P1 and P2???
Posted by: ZodInLynn - 12-07-2025, 01:19 PM - Forum: KinCony AS - Replies (1)
Hi, I am trying to add onto the Kincony AS Voice assistant (hardware) and I cannot find the pinout of the P1 and P2 "connectors" (are they set up for 433mhx transmitter and receiver?)
I have looked everywhere and cannot find any info.
could you please let me know (and add the info to the product web page for others??) what the pins on these "ports" do and what GPIO they area attached to???
a graphic with all of the solder pads labelled would be most helpful......
  KC868-A16 HTTP request config
Posted by: basilioo - 12-06-2025, 06:42 PM - Forum: KC868-A16 - Replies (5)
I can't configure sending an http request with kc868-a16 board. Рlease help me make the correct settings.
[Image: 2025-12-06_21-08-59.jpg][Image: 2025-12-06_21-10-20.jpg]
