» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 409 online users.
» 0 Member(s) | 388 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bytespider, Google, HeadlessChrome, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Replacing KCS868-E8 relays with 24V
Posted by: Revinor - 11-29-2024, 09:24 AM - Forum: Development - Replies (1)
I'm using 24V output from KCS868-B16M for controlling few devices. At same time, I would like to use some of these outputs to drive 230VAC. Can I just replace all relays on KCS868-E8 with G2R-1A-E-24VDC, connect 24V supply and 24V outputs from KCS868-B16M there and everything will work? Or are there some parts there which won't work with 24V even if all relays are replaced?
  G1 ESP32-S3 IO pins define
Posted by: admin - 11-28-2024, 12:01 PM - Forum: G1 - Replies (2)
IIC SDA:GPIO12
IIC SCL:GPIO11
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
RS485:
RXD:GPIO18
TXD:GPIO8
4G SIM7600:
RXD:GPIO10
TXD:GPIO9
1-wire1:GPIO15
1-wire2:GPIO16
1-wire3:GPIO17
1-wire4:GPIO40
1-wire (without resistance on PCB):
1-wire1:GPIO13
1-wire2:GPIO14
1-wire2:GPIO21
free GPIOs(without ESD diode on PCB):
GPIO4
GPIO5
GPIO6
GPIO7
24C02 EPROM i2c address: 0x50
  F24 ESPHome yaml for home assistant by PCF8575 chip
Posted by: admin - 11-28-2024, 11:54 AM - Forum: F24 - No Replies
  friendly_name: f24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.3.0
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_in_2'  # for output channel 1-8  + (input 17-24)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: cchos3g1j2ucfbyd
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_in_2
      number: 12
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f24_output01"
      number: 13
    dp_id: 2
    internal: true
    bind_switch_id: "f24_output02"
      number: 14
    dp_id: 3
    internal: true
    bind_switch_id: "f24_output03"
      number: 15
    dp_id: 4
    internal: true
    bind_switch_id: "f24_output04"
      number: 8
    dp_id: 5
    internal: true
    bind_switch_id: "f24_output05"
      number: 9
    dp_id: 6
    internal: true
    bind_switch_id: "f24_output06"
      number: 10
    dp_id: 101
    internal: true
    bind_switch_id: "f24_output07"
      number: 11
    dp_id: 102
    internal: true
    bind_switch_id: "f24_output08"
      pcf8574: pcf8574_hub_out_1
    dp_id: 103
    internal: true
    bind_switch_id: "f24_output09"
    dp_id: 104
    internal: true
    bind_switch_id: "f24_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "f24_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "f24_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "f24_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "f24_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "f24_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "f24_output16"
      number: 8
    dp_id: 126
    internal: true
    bind_switch_id: "f24_output17"
      number: 9
    dp_id: 129
    internal: true
    bind_switch_id: "f24_output18"
      number: 10
    dp_id: 130
    internal: true
    bind_switch_id: "f24_output19"
      number: 11
    dp_id: 131
    internal: true
    bind_switch_id: "f24_output20"
      number: 12
    dp_id: 132
    internal: true
    bind_switch_id: "f24_output21"
      number: 13
    dp_id: 133
    internal: true
    bind_switch_id: "f24_output22"
      number: 14
    dp_id: 134
    internal: true
    bind_switch_id: "f24_output23"
      number: 15
    dp_id: 135
    internal: true
    bind_switch_id: "f24_output24"
    dp_id: 111
    bind_binary_sensor_id: f24_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f24_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f24_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f24_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: f24_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: f24_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: f24_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: f24_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f24_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f24_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f24_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f24_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f24_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f24_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f24_input15
    internal: true
      number: 15
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
  - platform: adc
    pin: 5
    name: "f24 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f24 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f24 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f24 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F24");
download yaml file:
.txt   F24-HA.txt (Size: 18.55 KB / Downloads: 739)
  [arduino code examples for F24]-12 How to control one relay
Posted by: admin - 11-28-2024, 11:52 AM - Forum: F24 - Replies (2)
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* It toggles relay 24 every 2 seconds and prints its status via the serial port.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Relay 24 is controlled through the first PCF8575 (I2C_ADDRESS_R1).
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
#define TOGGLE_DELAY 2000  // Define the toggle delay time (2 seconds)
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module (for relays 9-24)
#define I2C_ADDRESS_R2 0x26 // I2C address of the second PCF8575 module (for relays 1-8)
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
bool relay24State = HIGH; // Initialize relay 24 state to OFF (assuming HIGH is OFF)
  // Initialize serial communication for debugging
  Serial.println("PCF8575 Relay 24 Toggle Program: Starting...");
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  // Ensure that all relays are turned off initially (set all pins HIGH)
    pcf8575_R1.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
  // Toggle relay 24 state (relay 24 corresponds to pin 15 on pcf8575_R1)
  relay24State = !relay24State; // Toggle the state
  pcf8575_R1.write(15, relay24State); // Write the new state to relay 24
  // Print the current state of relay 24 to the serial port
  if (relay24State == LOW) {
    Serial.println("Relay 24 is ON");
    Serial.println("Relay 24 is OFF");
  // Wait for 2 seconds before toggling again
  delay(TOGGLE_DELAY);
arduino ino file download:
.zip   12-control-one-relay.zip (Size: 1.09 KB / Downloads: 794)
  [arduino code examples for F24]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 11-28-2024, 11:51 AM - Forum: F24 - No Replies
* This program reads 24 input states from two PCF8575 I/O expanders and
* controls a corresponding 24-channel relay module.
* When an input pin is LOW, the corresponding relay is turned ON (LOW means ON for the relay).
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - Input I2C Address 1 (inputs 1-16): 0x24
* - Input/Relay I2C Address 2 (inputs 17-24 and relays 1-8): 0x26
* - Relay I2C Address 3 (relays 9-24): 0x25
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 8            // SDA pin
#define SCL 18           // SCL pin
// I2C addresses for the PCF8575 modules
#define INPUT_I2C_ADDRESS_1 0x24   // I2C address for the first input PCF8575 module (inputs 1-16)
#define INPUT_RELAY_I2C_ADDRESS_2 0x26   // I2C address for inputs 17-24 and relays 1-8
#define RELAY_I2C_ADDRESS_3 0x25   // I2C address for relays 9-24
PCF8575 pcf8575_IN1(INPUT_I2C_ADDRESS_1);    // Create an object for the first input PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2);    // Create an object for the second input PCF8575 (inputs 17-24 and relays 1-8)
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3);    // Create an object for the relay PCF8575 (relays 9-24)
  pcf8575_IN1.begin();  // For inputs 1-16
  pcf8575_IN2.begin();  // For inputs 17-24 and relays 1-8
  pcf8575_RL.begin();   // For relays 9-24
  // Turn off all relays at the start (LOW means OFF)
  for (int i = 0; i < 8; i++) {
    pcf8575_IN2.write(i, LOW);  // Turn off relays 1-8
    pcf8575_RL.write(i, LOW);  // Turn off relays 9-24
  Serial.println("System started: Input state controlling 24 relays");
  // Read and control relays 1-16
    bool inputState = pcf8575_IN1.read(i);  // Read input i from the first input module
    if (inputState) {
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the corresponding relay OFF
      pcf8575_RL.write(i, LOW);   // If input is LOW, turn the corresponding relay ON
  // Read and control relays 17-24 (shared with second input module)
    bool inputState = pcf8575_IN2.read(i + 8);  // Read input 17-24 from the second input module (pins 8-15)
    if (inputState) {
      pcf8575_IN2.write(i, HIGH);  // If input is HIGH, turn the corresponding relay OFF (1-8)
      pcf8575_IN2.write(i, LOW);   // If input is LOW, turn the corresponding relay ON (1-8)
  // Delay for 500 milliseconds
  delay(500);
.zip   11-input-trigger-output.zip (Size: 1.11 KB / Downloads: 781)
  [arduino code examples for F24]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 11-28-2024, 11:50 AM - Forum: F24 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 796)
  [arduino code examples for F32]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 11-28-2024, 11:50 AM - Forum: F32 - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 804)
  [arduino code examples for F24]-09 how to communication with Tuya WiFi module
Posted by: admin - 11-28-2024, 11:49 AM - Forum: F24 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 39
#define RXD_PIN 38
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 791)
  [arduino code examples for F32]-09 how to communication with Tuya WiFi module
Posted by: admin - 11-28-2024, 11:49 AM - Forum: F32 - No Replies
* Functionality:
#define TXD_PIN 39
#define RXD_PIN 38
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 762)
  [arduino code examples for F24]-08 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 11-28-2024, 11:48 AM - Forum: F24 - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   8-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 756)
