» Members: 10,407
» Latest member: ghostwritingservices
» Forum threads: 4,322
» Forum posts: 21,300
There are currently 100 online users.
» 0 Member(s) | 81 Guest(s)
AhrefsBot, Amazonbot, Baidu, Bing, Bytespider, Crawl, PetalBot, Semrush, bot
KC868-A4 – Relay 1 clicks...
5 hours ago
9 hours ago
» Replies: 24
Yesterday, 03:04 AM
Yesterday, 01:34 AM
Yesterday, 12:15 AM
450 Hz allowed on input?
Forum: Development
11-02-2026, 09:41 PM
How Do You Handle Relay C...
11-02-2026, 05:41 PM
"KCS" v3.27.4 firmware BI...
11-02-2026, 06:02 AM
how to check i2c extend c...
Forum: T16M
11-02-2026, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
11-02-2026, 12:35 AM
  Board KC868_A16 FW 2.2.7 no value sensor MQTT
Posted by: kerdalle - 12-07-2024, 05:09 PM - Forum: KC868-A16 - Replies (4)
I updated my card with the latest firmware 2.2.7 and I have a problem with MQTT and sensor 1,2,3. I installed a DS18B20 sensor on sensor 3 It is displayed well and gives the right temperature on the Monitor web page.
However I have the zero value with mqtt:
topic KC868_A16/ECC9FFB5F36C/STATE
value:
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"output1":{"value":false},"output2":{"value":false},"output3":{"value":false},"output4":{"value":false},"output5":{"value":false},"output6":{"value":false},"output7":{"value":false},"output8":{"value":false},"output9":{"value":false},"output10":{"value":false},"output11":{"value":false},"output12":{"value":false},"output13":{"value":false},"output14":{"value":false},"output15":{"value":false},"output16":{"value":false},"adc1":{"value":0},"adc2":{"value":0},"adc3":{"value":0},"adc4":{"value":0},"sensor1":{"temperature":0.0,"humity":0.0},"sensor2":{"temperature":0.0,"humity":0.0},"sensor3":{"temperature":0.0,"humity":0.0}}
topic KC868_A16/ECC9FFB5F36C/STATE  [sensor3]
value {"temperature":0,"humity":0}
topic KC868_A16/ECC9FFB5F36C/STATE  [sensor3][temperature]
value 0
KC868 monitor web page  sensor chanel 3 show good température 21.2 witch varie according room température.
I think read all post and nothing found abour this problem.
With the software MQTT explorer it's idem
Inputs, outputs state and order works fine with mqtt.
Where I am wrong?
Edit: I have also for test connect ADC chanel 4 on board 3V .  Web page MONITOR board display value 4095 but in MQTT topic stil 0:
"adc1": {
    "value": 0
  "adc2": {
    "value": 0
  "adc3": {
    "value": 0
  "adc4": {
    "value": 0
  H32B smar home app connection
Posted by: Saif Kitany - 12-07-2024, 01:27 PM - Forum: KC868-HxB series Smart Controller - Replies (7)
Hello technical support team,
I have H32b controller, and I use kincony smart home app. I was controlling the H32B by the kincony smart home app (with ethernet cable and UDP mode), and Kbox app (with wifi and TCP server mode)and everything were working perfectly, till my router got broken.
I bought new router, with same gateway ip address as the old one.
Now, the new router, has new wifi network, and i set the new network and password in wifi settings of the H32B, and I succeeded to control the H32B controller by Kbox app, but i still not able to control the H32B controller by kincony smart home app.
Is there any settings i have to update in the router or H32b ethernet settings?
  how to use DHT22 temperature humidity sensor with KC868-A16 by ESPHome
Posted by: admin - 12-07-2024, 05:40 AM - Forum: KC868-A16 - No Replies
DHT22 use by 3.5v--5.5v power. so i have contact with 433MHz receiver's pin, that have a 5V point.
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x25
    address: 0x21
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      inverted: false
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
  - platform: dht
    pin: 32
    temperature:
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
web_server:
  port: 80
  KinCony F24 ESP32-S3 16A Removable Relay Board released
Posted by: admin - 12-07-2024, 01:18 AM - Forum: News - Replies (2)
KinCony F24 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 24 manual control switch buttons can turn ON/OFF relay even if system is broken. 24 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F24 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F24 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware(tasmota total support MAX 32channel INPUT+OUTPUT ports) for smart home automation DIY. F24 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. F24 support Apple HomeKit, easy to use directly. Support save state LOG to SD Card. It use by local RTC clock, use timer work without internet. F24 support to use KinCony cloud server service, so that you can remote control and monitor your device by internet using mobile phone or computer web browser. note: (buy from KinCony Official Shop have KinCony cloud server 2 years free)
[Image: F24-1_small.jpg]
Model No. KinCony F24
Description: KinCony 24 Channel ESP32-S3 Removable Relay Controller – F24
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
24CH OMRON removable relay, every channel have "COM"(common) and "NO"(normal open) ports.
MAX load 250VAC/16A 30VDC/16A
[Image: F24-12_small.jpg]
Inputs:
24CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
[Image: F24-11_small.jpg]
[Image: F24-2_small.jpg]
[Image: F24-4_small.jpg]
software solution:
3. download tasmota firmware.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7132
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=7145
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=65
KCS v3 firmware online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
YouTube video tour: upload soon
Order bundles:
Bundle A: F24
Bundle B: F24 + USB-C cable+ power supply
[Image: F24-size_small.png]
  Error: Installing ESPHome on Windows without Home Assistant/Rasberry Pi
Posted by: OrenaikeJ - 12-06-2024, 12:36 PM - Forum: Getting Started with ESPHome and Home Assistant - Replies (1)
When I attempted to install ESPHome on Windows PC without Home Assistant & Rasberry Pi, on my Laptop, following your Youtube Instructional Guide, I got the error mesages seen in the attachment. Kindly assist me to successfully install the ESPHome on Windows without Home Assistant & Rasberry Pi.
  KC868-A16 need gpio pins
Posted by: msinfo - 12-06-2024, 11:21 AM - Forum: KC868-A16 - Replies (3)
Hello, is there a way i can use the gpio 18,19 and 21 from the esp32 to connect a device from a project im trying to do? I think the pins i need are connected to the Ethernet chip.
  KC868 A16 Tasmota
Posted by: Istvan - 12-06-2024, 09:19 AM - Forum: KC868-A series and Uair Smart Controller - Replies (15)
Hi all,
I'm using a KC868 controller with  Tasmota.
I found two tasmota firmwares here on the forum.
One shows the digital inputs nicely on the main page.  However, with this version, I can't select the DS18x20 temperature sensor I'm using because it's not listed.
If I use the version that includes this sensor, the digital inputs are not shown.
Is there one that can do both functions ?
Thx,
István
  KinCony G1 ESP32-S3 SIM7600E 4G Module released
Posted by: admin - 12-06-2024, 06:21 AM - Forum: News - Replies (4)
KinCony G1 ESP32 4G module based on ESP32-S3-WROOM-1U (N16R8) and SIMCOM SIM7600E series chip. G1 have RS485 port and many free GPIOs for user.You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant. Such as send SMS and make CALL by ESPHome. for example, when sensor trigger, it can send SMS to user's mobile phone. Just according to SIMCOM AT command, you can do anything.
[Image: G1-1_pix400.jpg][Image: G1-2_pix400.jpg]
[Image: G1-view.jpg]
Model No. KinCony G1
Description: KinCony 4G Module – G1
Power supply: 12-24V DC
4G Module: SIM7600E-L1C
SIM Card: Nano SIM
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,I2C extender, LCD, Buttons
Antenna Extender: ESP32-S3, 4G, GPS
Inputs:
12 buttons: Telephone Keyboard
free GPIO: 4CH (without ESD diode on PCB):
[Image: G1-3_pix400.jpg][Image: G1-4_pix400.jpg]
[Image: G1-7.png]
  [arduino code examples for G1]-06 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 12-06-2024, 01:44 AM - Forum: G1 - No Replies
* - SCL (clock) on pin IO11
* - SDA (data) on pin IO12
#include <Wire.h>     // Include the Wire library for I2C communication
// Initialize the display using the software I2C method (SCL = IO11, SDA = IO12)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  11, 12, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
void page1() {
  u8g2.setFontPosTop();               // Set the text position at the top of the display
  u8g2.setCursor(5, 0);               // Position the cursor at coordinates (5, 0)
  u8g2.begin();
  do {
    page1();
arduino ino file download:
.zip   6-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 747)
.zip   6-oled-ssd1306.ino.merged.zip (Size: 201.32 KB / Downloads: 739)
  [arduino code examples for G1]-05 GSM test
Posted by: admin - 12-06-2024, 01:41 AM - Forum: G1 - No Replies
#include <HardwareSerial.h>
// Define serial port
HardwareSerial SimSerial(1); // Use hardware serial port 1 (GPIO9 and GPIO10)
  // Initialize USB serial port (default serial port 0)
  while (!Serial) {
    ; // Wait for USB serial port to connect
  // Initialize SIM7600 serial port
  SimSerial.begin(115200, SERIAL_8N1, 9, 10); // RX=GPIO9, TX=GPIO10
  //Serial.println("ESP32-S3 begin work");
  // If data is received from the computer, forward it to the SIM7600 module
  if (Serial.available()) {
    while (Serial.available()) {
      char data = Serial.read();
      SimSerial.write(data);
  // If data is received from the SIM7600 module, forward it to the computer
  if (SimSerial.available()) {
    while (SimSerial.available()) {
      char data = SimSerial.read();
      Serial.write(data);
.zip   5-GSM-Test.zip (Size: 598 bytes / Downloads: 738)
.zip   5-GSM-Test.ino.merged.zip (Size: 184.08 KB / Downloads: 817)
