» Members: 10,417
» Latest member: archerfleming
» Forum threads: 4,322
» Forum posts: 21,300
There are currently 259 online users.
» 0 Member(s) | 248 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Google, PetalBot, bot
KC868-A4 – Relay 1 clicks...
Yesterday, 11:58 PM
Yesterday, 07:34 PM
» Replies: 24
Yesterday, 03:04 AM
Yesterday, 01:34 AM
Yesterday, 12:15 AM
450 Hz allowed on input?
Forum: Development
11-02-2026, 09:41 PM
How Do You Handle Relay C...
11-02-2026, 05:41 PM
"KCS" v3.27.4 firmware BI...
11-02-2026, 06:02 AM
how to check i2c extend c...
Forum: T16M
11-02-2026, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
11-02-2026, 12:35 AM
  H32BS questions
Posted by: leliodm - 12-02-2024, 01:26 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
I have two questions for the hb32BS
1. is there a KCS software for it?
2. for the original firmware version 1.50 how can I use the two RF controllers?
Thank you
  E16S home assistant
Posted by: janami - 11-30-2024, 07:39 AM - Forum: KC868-E16S/E16P - Replies (5)
Ahoj všichni,
Na mini PC mám přes PROXMOX nainstalovanou desku KC868-E16S a Home Assistant. Jaký komunikační protokol bych měl použít, abych zajistil stabilní připojení? Rozhodně nechci žádné bezdrátové možnosti.
Mohl by mi prosím někdo napsat podrobný návod jak to nastavit?
A jaký firmware mám nahrát do KC868-E16S?
Děkuju.
  "KCS" v3.3.0 firmware for F16 controller
Posted by: admin - 11-30-2024, 03:51 AM - Forum: "KCS" v2 firmware system - No Replies
v3.3.0 improvement:
1. Fixed the problem of Tuya automatically managing  by Reset button and network Led
2. Add a delay after i2c initialization to fix the issue where AT24C02 occasionally fails to read i2c data too quickly, resulting in interrupted startup.
.zip   KCS_F16_V3.3.0.zip (Size: 1.01 MB / Downloads: 918)
  "KCS" v3.3.0 firmware for B16M controller
Posted by: admin - 11-30-2024, 03:50 AM - Forum: "KCS" v2 firmware system - No Replies
v3.3.0 improvement:
.zip   KCS_B16M_V3.3.0.zip (Size: 1.01 MB / Downloads: 912)
  "KCS" v3.3.0 firmware for F24 controller
Posted by: admin - 11-30-2024, 03:47 AM - Forum: "KCS" v2 firmware system - No Replies
.zip   KCS_F24_V3.3.0.zip (Size: 1.01 MB / Downloads: 783)
  Error when flashing A32 Pro
Posted by: drazvan2003 - 11-29-2024, 07:03 PM - Forum: DIY Project - Replies (6)
im getting this error when im trying to flash my a32pro
as you can see in the picture attached that my config, i hit run, it stays for ever in loading. When i stop this i get
[2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:422][ERROR]: Chip sync error
[2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:582][ERROR]: ESP32S3 Chip sync error esp_sync_blocking.
  Hardware issues
Posted by: ogo - 11-29-2024, 09:54 AM - Forum: KC868-A8 - Replies (1)
I bought a KC868-A8 a while ago that I've been using to test things and learn. Today I finally wanted to configure it properly to controls some lights. I have two issues
  1. Output 3 and 4 don't work: when I enable the outputs via home assistant or KCS, the LEDs for the outputs don't turn on, and I can't hear the click on the relay.
  2. When activating output 8, outputs 5, 6, and 7 are also activated: When I activate output 8 via home assistant or KCS, the LEDs of outputs 5, 6, 7, 8 turn on, even though those relays aren't active.
Things I've done so far:
  • Remove everything from home assistant and install it again
  • Disconnect everything from the board
  • Flashed KCS instead of ESPHome
  • Factory reset using KCS
  • Flashed ESPHome again
Nothing seems to fix it, so I can only think it's a hardware issue, not software. The board version is 1.6, and it also has a 433 MHz receiver/transmitter.
Any ideas?
  Replacing KCS868-E8 relays with 24V
Posted by: Revinor - 11-29-2024, 09:24 AM - Forum: Development - Replies (1)
I'm using 24V output from KCS868-B16M for controlling few devices. At same time, I would like to use some of these outputs to drive 230VAC. Can I just replace all relays on KCS868-E8 with G2R-1A-E-24VDC, connect 24V supply and 24V outputs from KCS868-B16M there and everything will work? Or are there some parts there which won't work with 24V even if all relays are replaced?
  G1 ESP32-S3 IO pins define
Posted by: admin - 11-28-2024, 12:01 PM - Forum: G1 - Replies (2)
IIC SDA:GPIO12
IIC SCL:GPIO11
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
RS485:
RXD:GPIO18
TXD:GPIO8
4G SIM7600:
RXD:GPIO10
TXD:GPIO9
1-wire1:GPIO15
1-wire2:GPIO16
1-wire3:GPIO17
1-wire4:GPIO40
1-wire (without resistance on PCB):
1-wire1:GPIO13
1-wire2:GPIO14
1-wire2:GPIO21
free GPIOs(without ESD diode on PCB):
GPIO4
GPIO5
GPIO6
GPIO7
24C02 EPROM i2c address: 0x50
  F24 ESPHome yaml for home assistant
Posted by: admin - 11-28-2024, 11:54 AM - Forum: F24 - No Replies
  friendly_name: f24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.3.0
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_in_2'  # for output channel 1-8  + (input 17-24)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: cchos3g1j2ucfbyd
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_in_2
      number: 12
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f24_output01"
      number: 13
    dp_id: 2
    internal: true
    bind_switch_id: "f24_output02"
      number: 14
    dp_id: 3
    internal: true
    bind_switch_id: "f24_output03"
      number: 15
    dp_id: 4
    internal: true
    bind_switch_id: "f24_output04"
      number: 8
    dp_id: 5
    internal: true
    bind_switch_id: "f24_output05"
      number: 9
    dp_id: 6
    internal: true
    bind_switch_id: "f24_output06"
      number: 10
    dp_id: 101
    internal: true
    bind_switch_id: "f24_output07"
      number: 11
    dp_id: 102
    internal: true
    bind_switch_id: "f24_output08"
      pcf8574: pcf8574_hub_out_1
    dp_id: 103
    internal: true
    bind_switch_id: "f24_output09"
    dp_id: 104
    internal: true
    bind_switch_id: "f24_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "f24_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "f24_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "f24_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "f24_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "f24_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "f24_output16"
      number: 8
    dp_id: 126
    internal: true
    bind_switch_id: "f24_output17"
      number: 9
    dp_id: 129
    internal: true
    bind_switch_id: "f24_output18"
      number: 10
    dp_id: 130
    internal: true
    bind_switch_id: "f24_output19"
      number: 11
    dp_id: 131
    internal: true
    bind_switch_id: "f24_output20"
      number: 12
    dp_id: 132
    internal: true
    bind_switch_id: "f24_output21"
      number: 13
    dp_id: 133
    internal: true
    bind_switch_id: "f24_output22"
      number: 14
    dp_id: 134
    internal: true
    bind_switch_id: "f24_output23"
      number: 15
    dp_id: 135
    internal: true
    bind_switch_id: "f24_output24"
    dp_id: 111
    bind_binary_sensor_id: f24_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f24_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f24_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f24_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: f24_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: f24_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: f24_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: f24_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f24_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f24_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f24_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f24_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f24_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f24_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f24_input15
    internal: true
      number: 15
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
  - platform: adc
    pin: 5
    name: "f24 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f24 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f24 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f24 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F24");
download yaml file:
.txt   F24-HA.txt (Size: 18.55 KB / Downloads: 734)
