» Members: 10,453
» Latest member: 789kwiki
» Forum threads: 4,326
» Forum posts: 21,315
There are currently 319 online users.
» 0 Member(s) | 295 Guest(s)
Amazonbot, AwarioBot, Baidu, Bing, Bytespider, Crawl, HeadlessChrome, PetalBot, Sogou web, bot
No AP appears
6 hours ago
» Replies: 8
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
  KinCony G1 ESP32-S3 SIM7600E 4G Module released
Posted by: admin - 12-06-2024, 06:21 AM - Forum: News - Replies (4)
KinCony G1 ESP32 4G module based on ESP32-S3-WROOM-1U (N16R8) and SIMCOM SIM7600E series chip. G1 have RS485 port and many free GPIOs for user.You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant. Such as send SMS and make CALL by ESPHome. for example, when sensor trigger, it can send SMS to user's mobile phone. Just according to SIMCOM AT command, you can do anything.
[Image: G1-1_pix400.jpg][Image: G1-2_pix400.jpg]
[Image: G1-view.jpg]
Model No. KinCony G1
Description: KinCony 4G Module – G1
Power supply: 12-24V DC
4G Module: SIM7600E-L1C
SIM Card: Nano SIM
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,I2C extender, LCD, Buttons
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Antenna Extender: ESP32-S3, 4G, GPS
Inputs:
12 buttons: Telephone Keyboard
free GPIO: 4CH (without ESD diode on PCB):
[Image: G1-3_pix400.jpg][Image: G1-4_pix400.jpg]
[Image: G1-7.png]
  [arduino code examples for G1]-06 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 12-06-2024, 01:44 AM - Forum: G1 - No Replies
* - SCL (clock) on pin IO11
* - SDA (data) on pin IO12
#include <Wire.h>     // Include the Wire library for I2C communication
// Initialize the display using the software I2C method (SCL = IO11, SDA = IO12)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  11, 12, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
void page1() {
  u8g2.setFontPosTop();               // Set the text position at the top of the display
  u8g2.setCursor(5, 0);               // Position the cursor at coordinates (5, 0)
  u8g2.begin();
  do {
    page1();
arduino ino file download:
.zip   6-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 765)
.zip   6-oled-ssd1306.ino.merged.zip (Size: 201.32 KB / Downloads: 757)
  [arduino code examples for G1]-05 GSM test
Posted by: admin - 12-06-2024, 01:41 AM - Forum: G1 - No Replies
#include <HardwareSerial.h>
// Define serial port
HardwareSerial SimSerial(1); // Use hardware serial port 1 (GPIO9 and GPIO10)
  // Initialize USB serial port (default serial port 0)
  while (!Serial) {
    ; // Wait for USB serial port to connect
  // Initialize SIM7600 serial port
  SimSerial.begin(115200, SERIAL_8N1, 9, 10); // RX=GPIO9, TX=GPIO10
  //Serial.println("ESP32-S3 begin work");
  // If data is received from the computer, forward it to the SIM7600 module
  if (Serial.available()) {
    while (Serial.available()) {
      char data = Serial.read();
      SimSerial.write(data);
  // If data is received from the SIM7600 module, forward it to the computer
  if (SimSerial.available()) {
    while (SimSerial.available()) {
      char data = SimSerial.read();
      Serial.write(data);
.zip   5-GSM-Test.zip (Size: 598 bytes / Downloads: 742)
.zip   5-GSM-Test.ino.merged.zip (Size: 184.08 KB / Downloads: 818)
  [arduino code examples for G1]-04 RS485 communication test
Posted by: admin - 12-06-2024, 01:37 AM - Forum: G1 - No Replies
* RS485 Communication Test
* The TXD pin is defined as GPIO 8 and RXD pin is defined as GPIO 18.
// Define RS485 pins
#define RS485_RXD 18
#define RS485_TXD 8
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony G1!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 760 bytes / Downloads: 808)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.54 KB / Downloads: 816)
  [arduino code examples for G1]-03 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 12-06-2024, 01:34 AM - Forum: G1 - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
Static IP address configuration
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   3-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 702)
.zip   3-Ethernet-W5500.ino.merged.zip (Size: 189.2 KB / Downloads: 764)
  [arduino code examples for G1]-02 Read free GPIO state
Posted by: admin - 12-06-2024, 01:32 AM - Forum: G1 - No Replies
* GPIO Status Monitoring with Change Detection
* Additional Functionality:
* - The program now monitors 11 GPIO pins, not just the previously listed ones.
* - GPIO pins include: GPIO 15, 16, 17, 40, 13, 14, 21, 4, 5, 6, 7.
* - For each pin, whenever its state changes (from HIGH to LOW or vice versa), the new state is printed to the serial monitor.
* GPIO Pins Monitored:
* - GPIO 15
* - GPIO 16
* - GPIO 17
* - GPIO 40
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 4
* - GPIO 5
* - GPIO 6
* - GPIO 7
* Hardware Requirements:
* - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing.
* - Ensure that the ESP32-S3 is powered and connected to a serial monitor to observe the output.
* How it works:
* - The setup function initializes the serial communication and configures the GPIO pins as inputs.
* - The loop function continuously checks the state of each GPIO pin.
* - If a pin's state changes, the new state is printed to the serial monitor, along with the corresponding pin number.
* - The program uses a delay to prevent excessive serial prints, which can be adjusted as necessary.
#define GPIO_PIN_15 15
#define GPIO_PIN_16 16
#define GPIO_PIN_17 17
#define GPIO_PIN_40 40
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_4 4
#define GPIO_PIN_5 5
#define GPIO_PIN_6 6
#define GPIO_PIN_7 7
bool prevState[11] = {false, false, false, false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_15, INPUT);
  pinMode(GPIO_PIN_16, INPUT);
  pinMode(GPIO_PIN_17, INPUT);
  pinMode(GPIO_PIN_40, INPUT);
  pinMode(GPIO_PIN_13, INPUT);
  pinMode(GPIO_PIN_14, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  pinMode(GPIO_PIN_4, INPUT);
  pinMode(GPIO_PIN_5, INPUT);
  pinMode(GPIO_PIN_6, INPUT);
  pinMode(GPIO_PIN_7, INPUT);
  bool currentState[11];
  currentState[0] = digitalRead(GPIO_PIN_15);
  currentState[1] = digitalRead(GPIO_PIN_16);
  currentState[2] = digitalRead(GPIO_PIN_17);
  currentState[3] = digitalRead(GPIO_PIN_40);
  currentState[4] = digitalRead(GPIO_PIN_13);
  currentState[5] = digitalRead(GPIO_PIN_14);
  currentState[6] = digitalRead(GPIO_PIN_21);
  currentState[7] = digitalRead(GPIO_PIN_4);
  currentState[8] = digitalRead(GPIO_PIN_5);
  currentState[9] = digitalRead(GPIO_PIN_6);
  currentState[10] = digitalRead(GPIO_PIN_7);
  for (int i = 0; i < 11; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_15 :
                   i == 1 ? GPIO_PIN_16 :
                   i == 2 ? GPIO_PIN_17 :
                   i == 3 ? GPIO_PIN_40 :
                   i == 4 ? GPIO_PIN_13 :
                   i == 5 ? GPIO_PIN_14 :
                   i == 6 ? GPIO_PIN_21 :
                   i == 7 ? GPIO_PIN_4 :
                   i == 8 ? GPIO_PIN_5 :
                   i == 9 ? GPIO_PIN_6 : GPIO_PIN_7);
      Serial.print(" changed to ");
      // Update the previous state
.zip   2-free-gpio-state.zip (Size: 1.42 KB / Downloads: 766)
.zip   2-free-gpio-state.ino.merged.zip (Size: 179.82 KB / Downloads: 737)
  [arduino code examples for G1]-01 Read digital input ports state
Posted by: admin - 12-06-2024, 01:29 AM - Forum: G1 - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 12
* - SCL: GPIO 11
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 12  // Define SDA pin
#define I2C_SCL 11  // Define SCL pin
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    Serial.println("KinCony G1 16CH input state 0:ON  1:OFF"); //actually PCB used 12 buttons, reset 4CH digital input free
    uint16_t state = 0;
    for (int pin = 0; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   1-digital-input.zip (Size: 875 bytes / Downloads: 736)
.zip   1-digital-input.ino.merged.zip (Size: 189.81 KB / Downloads: 776)
  SIM7600E AT command transparently transmitted to ESP32 Arduino code and BIN firmware
Posted by: admin - 12-06-2024, 01:27 AM - Forum: G1 - No Replies
function: Use KinCony G1 module to transparently transmit AT commands of SIM7600 4G module to gpio13 and gpio14 of esp23-s3. So that KinCony Controller can connect with extend G1 4G module by KCS v3 firmware.
// Define hardware serial ports
HardwareSerial ExtendSerial(2);  // Use hardware serial port 2 (GPIO13 and GPIO14)
  // Initialize the extended serial port (hardware serial port 2)
  ExtendSerial.begin(115200, SERIAL_8N1, 13, 14); // RX=GPIO13, TX=GPIO14
  while (!ExtendSerial) {
    ; // Wait for the extended serial port to connect
  // Initialize the SIM7600 serial port (hardware serial port 1)
  // If data is received from the extended serial port, forward it to the SIM7600 module
  if (ExtendSerial.available()) {
    while (ExtendSerial.available()) {
      char data = ExtendSerial.read();
  // If data is received from the SIM7600 module, forward it to the extended serial port
      ExtendSerial.write(data);
BIN file download to ESP32-S3 directly:
.zip   7-GSM-Test-extend-pins.ino.merged.zip (Size: 184.13 KB / Downloads: 768)
Question How can I power multiple devices simultaneously using KC868-A16?
Posted by: ingersoj - 12-06-2024, 12:04 AM - Forum: KC868-A series and Uair Smart Controller - Replies (12)
I bought the KC868-A16 recently and I worked with it for a few days to set it up with Home Assistant; now I finally have it set up so I can connect my devices to the outputs and switch them on/off (one at a time) using home assistant.
The problem I am now having is that when I try to switch on more than one device at a time (each connected to a different output on the KC868-A16), the devices will not get enough power and they will switch off automatically through the KC868-A16 after a second or so.
Each of my devices requires 12 Volts and 3 Amps of power. I currently have 12 devices in total. What do I need to do in order to give adequate power to all devices at the same time, assuming I have connected them each to a different output, and without them losing power? I have only tried two devices at once and that didn't even work - only one device at a time can receive enough power to stay on.
  Raspberry pi + KC868-a16 + HA
Posted by: plachowicz - 12-05-2024, 09:24 PM - Forum: DIY Project - Replies (1)
Witam,
Zaczynam swoją przygodę z home assistant. Zakupiłem KC868-a16. System bedzie zainstalowany na raspberry pi.
Czy moze ktos podesłac jakis tutorial pokazujacy konfiguracje KC868-a16 z HA?
Z gory bardzo dziekuje.
Pozdrawiam
Przemek
