» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 404 online users.
» 0 Member(s) | 384 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot, owler
kc868-a6 analog input
11 hours ago
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  KC868-A4S for heating controll
Posted by: tadam - 11-27-2024, 01:05 PM - Forum: KC868-A4S - Replies (9)
Hello there,
I am looking for confirmation before purchase that I can use this board as I plannig to. Smile
So my plan is to use this board for central heating management. I attached a picture how does the setup looks so far.
I will use Home assistant and esphome.
As you can see I have
- 4 24V AC valve.
- 5 temperature sensor (ds18B20)
- analog pressure sensor (SEN0257)
- leak sensor (just a basic contact sensor)
- opentherm adapter (this one)
- for network connection I will use ethernet
Do I need an additonal power supply (9-24V DC) to power my board? Or it can be power from 5V?
4x 24V AC valve: This is easy, They can go to the 4 relay. I think I will use the normaly closed terminals, in case of a board issue, the heating should not be affected. There is a separate 24V AC power supply, which only responsible for powering these valves.
5 temperature sensor (ds18B20): As far as I know these sensors has uniq id and can use the same pin, with one wire protocol. I can use the 3.3V output and ground from the board, and GPIO01 for the onewire.
analog pressure sensor (SEN0257): This sensor needs 5V can I get 5V out of this board? The output of this sensor is analog, so I can use AI1 for that.
leak sensor: This is just a digital sensor this is trivial too, it can go DI1 and ground.
opentherm adapter: This board need 3.3V, this I can get from the board. But also needs 2 free IO. Is there an IO I can repurpose in this case? There is only one free "bare" gpio left which is this case GPIO2. All other looks like has a special purpose.
I am really excited for this project and looking forward for responses. Thanks in advance.
  Drawning 2D/3D
Posted by: Belfaso - 11-27-2024, 12:18 PM - Forum: KC868-A16 - Replies (2)
Are there any other drawings availiable beside schematics? I looking for board dimensions, hole locations.
  Kincony Server 16 User Manual
Posted by: electronics engineer - 11-27-2024, 05:12 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (7)
Is there a detailed user manual available for the Kincony Server 16 that includes the I/O port numbers or addresses? I need this information to utilize the device's pins and ports more efficiently for my application.
  "KCS" v3.2.0 firmware for B16M controller
Posted by: admin - 11-26-2024, 11:24 PM - Forum: "KCS" v2 firmware system - No Replies
v3.2.0 improvement:
1. supports displaying user-defined ranges and units for analog input ports in home assistant.
.zip   KCS_B16M_V3.2.0.zip (Size: 1.01 MB / Downloads: 857)
  kcs firmware system source code
Posted by: davidbvega - 11-26-2024, 11:25 AM - Forum: Development - Replies (1)
Good morning!
I wanted to know if you have available the firmware source code that you provide for the KC868-A8-V1.6 board.
I want to extend functionalities needed for my project, but if it is possible, starting from your base.
Best regards!
  A24 work with K-Type Thermocouple by web service
Posted by: admin - 11-26-2024, 01:36 AM - Forum: KinCony A24 - No Replies
yaml code:
  platform: ESP32
# Example configuration entry
   - id: bus_a
     sda: 16
     scl: 5
     frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - id: 'pcf8574_hub_out_1'  # for output channel 1-12 CS1-CS3
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 13-24
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a24--input channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      pcf8574: pcf8574_hub_out_2
      number: 8
      number: 9
      number: 10
      number: 11
# Individual inputs
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_2
  - platform: adc
    pin: 35
    name: "A24 A1 Voltage"
    update_interval: 10s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 34
    name: "A24 A2 Voltage"
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 39
    name: "A24 A3 Current"
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 36
    name: "A24 A4 Current"
    attenuation: 11db
    filters:
  - platform: max31855
    name: "K-Type Thermocouple-1"
    cs_pin:
      number: 13
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-2"
    cs_pin:
      number: 14
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-3"
    cs_pin:
      number: 15
      inverted: false
    update_interval: 5s
spi:
  - id: spi_bus0
    clk_pin: 14
    miso_pin: 12
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    output: gp8403_output_1
    output: gp8403_output_2
web_server:
  port: 80
  "KCS" v3.0.4 firmware for A32 Pro controller
Posted by: admin - 11-25-2024, 11:49 AM - Forum: "KCS" v2 firmware system - No Replies
v3.0.4 improvement:
1. Fix the problem that after power off can't remember the relay state.
.zip   KCS_A32PRO_V3.0.4.zip (Size: 999.72 KB / Downloads: 871)
  Read 12V battery charge
Posted by: darsh - 11-25-2024, 11:03 AM - Forum: KC868-A6 - Replies (7)
I am powering the board with a solar panel connected to a charge controller and a 12V battery. I have installed the ESPHome system on the board connected to Home Assistant, and it is working perfectly.
I would like to read the battery charge level using the analog sensor A1, but I know that this sensor reads a maximum of 5V, so the 12V from the battery (13V when fully charged) needs to be reduced. For this, I tried using a voltage divider circuit with two resistors, one 200KOhm and one 100KOhm. I connected the GND and A1 terminals of the analog sensors across the 100KOhm resistor, with the GND terminal going to the negative terminal of the battery.
+12V (Battery)
    [R1]  200kOhm
      +------ A1
    [R2]  100kOhm
    GND (Battery -)
The configuration in ESPHome is:
  - platform: adc
    pin: 36
    name: 'Battery Charge - Voltage'
    accuracy_decimals: 5
    device_class: "voltage"
    state_class: "measurement"
    unit_of_measurement: "V"
    update_interval: 5s
    filters:
    - multiply: 24.6
This configuration gives me readings of values below 0, which I had to multiply by 24.6 to get battery voltage values close to what I read using a voltmeter connected to the battery terminals.
Additionally, the values read are not stable, while the voltmeter provides a rather stable value.
Can you tell me if I am making any mistakes in the configuration or in the circuit? Is there a simpler way to perform this reading?
Thank you.
Darsh
  M16 Incorrect current reading
Posted by: salvolivigni - 11-23-2024, 05:06 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Hi Admin, I recently purchased the M16 and 13 SCT013 board, I configured everything with esphome, so far everything is ok. But when I go to read the values of the specific probes, comparing them for example with a PZEM 0-16, I have values in watts very far from the real absorption, I also did a comparison with a clamp meter, and unfortunately the M16 probes all read values much higher than reality. For the voltage I solved it by modifying the file #define SENSITIVITY 525.0f, and now the voltage is correct, but unfortunately for the wattage I can't find a solution, can you help me?
  HC868-AK firmware update
Posted by: leliodm - 11-23-2024, 03:25 PM - Forum: KC868-HxB series Smart Controller - Replies (6)
can you please point me to a step by step guide on how to update the AK firmware to the latest version?
regards
