» Members: 8,355
» Latest member: jcyu5662
» Forum threads: 3,641
» Forum posts: 18,808
There are currently 26 online users.
» 0 Member(s) | 11 Guest(s)
AhrefsBot, Amazonbot, Bing, Bytespider, Crawl, Google, bot
KC868-M16v2 configure yam...
Today, 10:00 AM
» Replies: 129
sample code to receive ht...
Forum: F16
Today, 09:57 AM
» Replies: 12
Goes Offline
Forum: KC868-E16S/E16P
Today, 01:19 AM
KC868-A16 - IP & PORT ?? ...
Yesterday, 02:46 AM
» Replies: 7
Server 16 issues
Yesterday, 02:44 AM
N20 Problem with Home Ass...
Forum: N20
12-31-2025, 06:55 AM
N30 Energy entry not work...
Forum: N30
12-31-2025, 06:50 AM
» Replies: 14
Problems and general Feed...
Forum: N30
12-31-2025, 06:49 AM
kWh resolution
Forum: N30
KCS_N60_N30_N20_N10_V3.18...
Forum: N60
12-31-2025, 06:45 AM
  how to install raspberry pi CM4 module to KinCony Server-Mini
Posted by: admin - 10-12-2023, 04:21 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
  DEFINE BOARD ARDUINO
Posted by: Regis - 10-10-2023, 02:26 PM - Forum: KC868-A64 - Replies (3)
Hello, excuse me, I am new on the forum . I have a kc868_A64 and I want to code in ARDUINO
I have loaded  the kc868-arduino-library, but I don't know what BOARD to choose in the combo list : ESP32 Dev Module ? ESP32S2 Dev Module ? ....
Thank a lot for your help
  pip install rpi-rf for python
Posted by: admin - 10-10-2023, 01:06 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
pip3 install rpi-rf
  Accessing permission to open port /dev/ttyS0 for Serial communication
Posted by: admin - 10-10-2023, 01:05 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
sudo chmod 666 /dev/ttyS0
  [Arduino source code for KC868-M16 V2]-OLED Show
Posted by: KinCony Support - 10-10-2023, 02:43 AM - Forum: KC868-M16 / M1 / MB / M30 - No Replies
/*OLED SSD1306 Code for KC868-M16v2*/
#include <U8g2lib.h>
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  5, 4, U8X8_PIN_NONE);//SCL IO5  SDA  IO4
void page1() {
  u8g2.setFont(u8g2_font_timR12_tf);//Font 12
  u8g2.setCursor(0,15);
  u8g2.print("KC868-M16 V2");
void setup(){
  u8g2.setI2CAddress(0x3C*2);
  u8g2.begin();
  u8g2.enableUTF8Print();
void loop(){
  u8g2.firstPage();
  do
    page1();
  }while(u8g2.nextPage());
Install ug82 library
  [Arduino source code for KC868-M16 V2]-SHT31 sensor detect code
Posted by: KinCony Support - 10-10-2023, 02:35 AM - Forum: KC868-M16 / M1 / MB / M30 - No Replies
/*Read SHT31 sensor  Temperature and Humidity*/
#include "Wire.h"
#include "SHT31.h"
#define SHT31_ADDRESS_1   0x44
SHT31 sht_1(&Wire);
bool b1;
  Serial.println(__FILE__);
  Serial.println(SHT31_LIB_VERSION);
  Wire.begin(4,5);
  Wire.setClock(100000);
  b1 = sht_1.begin(SHT31_ADDRESS_1);
  if (b1) sht_1.read();
  Serial.print("Temperature:");
  Serial.print(sht_1.getTemperature(), 1);
  Serial.print("\t");
  Serial.print("Humidity:");
  Serial.print(sht_1.getHumidity(), 1);
  Serial.print("\t");
  Serial.println();
install library SHT31
  Help with pulse_counter config
Posted by: MnM - 10-09-2023, 06:01 PM - Forum: KC868-A16 - Replies (5)
I would like some help to configure an input for count my water with pulse_counter
I need to use a port that is connected directly to the ESP module.
What PIN number should I define in my config:
  - platform: pulse_counter
      number: XX??
      mode:
        input: true
        pullup: true
 and which actual pin on the board that will be? (I suspect either GPIO 01, 02 or 03??)
  KC868-M16v2 configure yaml for ESPhome using Tuya app
Posted by: admin - 10-09-2023, 04:30 AM - Forum: KC868-M16 / M1 / MB / M30 - No Replies
work by Tuya app remote monitor by internet.
how to order tuya license see here:
https://www.kincony.com/forum/showthread.php?tid=2544
upload zmpt101b folder to your home assistant folder as this:
.zip   zmpt101b.zip (Size: 1.8 KB / Downloads: 634)
ymal file download:
.zip   m16v2.zip (Size: 2.18 KB / Downloads: 759)
substitutions:
  zmpt101b_sensitivity: "533.75"
  friendly_name: ${name}
  includes:
    - zmpt101b/ZMPT101B.h
    - zmpt101b/ZMPT101B.cpp
    - zmpt101b/zmpt101b_custom_sensor.h
external_components:
  # - source:
  #     type: local
  #     path: my_components/esphome-tuya-iot/components
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-tuya-iot
  encryption:
    key: "bw/rPHdwHVn/1VcrLR3klCXs3KieOgLLzS5lr4uXAMI="
ota:
  password: "bd01aad7e00d3e47eaff147d8e37b6de"
tuya_iot:
  product_id: trt1ssh9tckaoxof
  device_id: 26d09e3ccf9314f1eblodu
  device_secret: hzwwkVtJG3GvJzff
# how to order tuya license please check with KinCony's forum
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - lambda: |-
            static int display_voltage = 0;
            display_voltage = (display_voltage + 1) % 3;
            id(display_voltage_id).publish_state(display_voltage);
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      if (id(display_voltage_id).state == 0)
        it.printf(0, 40, id(roboto), "AC1:%.1fV", id(voltage_1).state);
      else if (id(display_voltage_id).state == 1)
        it.printf(0, 40, id(roboto), "AC2:%.1fV", id(voltage_2).state);
      else
        it.printf(0, 40, id(roboto), "AC3:%.1fV", id(voltage_3).state);
# Example configuration entry
  - platform: template
    name: "Display Voltage ID"
    accuracy_decimals: 0
    update_interval: never
  - platform: custom
    lambda: |-
      auto my_sensor34 = new ZMPT101BSensor(34, ${zmpt101b_sensitivity});
      auto my_sensor36 = new ZMPT101BSensor(36, ${zmpt101b_sensitivity});
      auto my_sensor39 = new ZMPT101BSensor(39, ${zmpt101b_sensitivity});
      App.register_component(my_sensor34);
      App.register_component(my_sensor36);
      App.register_component(my_sensor39);
      return {my_sensor34, my_sensor36, my_sensor39};
    sensors:
      - name: "m16v2-voltage-1"
        unit_of_measurement: V
        accuracy_decimals: 1
        state_class: "measurement"
      - name: "m16v2-voltage-2"
      - name: "m16v2-voltage-3"
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 10s
  - platform: adc
    pin: 35
    attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    update_interval: 60s
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
interval:
  - interval: 15s
    then:
      - lambda: !lambda |-
          id(tuya_iot_component).property_report("voltage_1", id(voltage_1).state);
          id(tuya_iot_component).property_report("voltage_2", id(voltage_2).state);
          id(tuya_iot_component).property_report("voltage_3", id(voltage_3).state);
          id(tuya_iot_component).property_report("temperature", id(temperature).state);
          id(tuya_iot_component).property_report("humidity", id(humidity).state);
          id(tuya_iot_component).property_report("measured_current_1", id(Measured_Current_1).state);
          id(tuya_iot_component).property_report("measured_current_2", id(Measured_Current_2).state);
          id(tuya_iot_component).property_report("measured_current_3", id(Measured_Current_3).state);
          id(tuya_iot_component).property_report("measured_current_4", id(Measured_Current_4).state);
          id(tuya_iot_component).property_report("measured_current_5", id(Measured_Current_5).state);
          id(tuya_iot_component).property_report("measured_current_6", id(Measured_Current_6).state);
          id(tuya_iot_component).property_report("measured_current_7", id(Measured_Current_7).state);
          id(tuya_iot_component).property_report("measured_current_8", id(Measured_Current_8).state);
          id(tuya_iot_component).property_report("measured_current_9", id(Measured_Current_9).state);
          id(tuya_iot_component).property_report("measured_current_10", id(Measured_Current_10).state);
          id(tuya_iot_component).property_report("measured_current_11", id(Measured_Current_11).state);
          id(tuya_iot_component).property_report("measured_current_12", id(Measured_Current_12).state);
          id(tuya_iot_component).property_report("measured_current_13", id(Measured_Current_13).state);
          id(tuya_iot_component).property_report("measured_current_14", id(Measured_Current_14).state);
          id(tuya_iot_component).property_report("measured_current_15", id(Measured_Current_15).state);
          id(tuya_iot_component).property_report("measured_current_16", id(Measured_Current_16).state);
time:
  - platform: sntp
  - platform: homeassistant
  Get starded trouble
Posted by: Savino - 10-07-2023, 05:21 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (5)
i'm new to kincony products and looking for a server board able to substitute my old domotic home system (HAI Control - very old and out of production).
Looking at kincony products it seems to me that KC868 - Mini Server may be a correct choice.
My trouble is about software to use the mini server and control inputs and outputs as I would.
Following a list of question:
1) It seems to me that there are some free app that could communicate with the server locally or by remote via internet. The question is: the mini server has built in software to act as a server or I have to develop this part of the software myself?
2) The mini server have a built in software to communicate via RS485, or USB etc. or I have to develop this part of software?
3) There's a free PC software to configure, program and control the mini server or I must operate via Mobile Apps to do that?
To start is enough Smile  and thanks in advance.
  Connect KC868-HA and mechanical switch
Posted by: dharma - 10-07-2023, 08:44 AM - Forum: KC868-HxB series Smart Controller - Replies (7)
Hi, I tried to follow the last diagram on the following page to connect KC868-HA with my H32B Pro board and also with a mechnical digital switch.
https://www.kincony.com/rs485-modbus-but...apter.html
And I'm attaching a photo of my connections.  Can you please tell me if it's correct or not.
