» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 603 online users.
» 0 Member(s) | 583 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Yandex, bot
kc868-a6 analog input
9 hours ago
F24 ESPHome yaml for home...
Forum: F24
11 hours ago
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  KC868-A16S or KC868-A8S
Posted by: mbeaven - 09-17-2024, 08:13 PM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
I'm thinking of using either KC868-A16S or KC868-A8S to control 24V lights/devices in a campervan via ESP32 with momentary switches and via a smartphone. Both boards indicate they handle AC current. Can they also handle DC 12v and/or 24v loads with the built in relays? If so, what is the max amps per relay and in total? What is the make/model/part number of the relay switch used on the board?
They also indicate they use DC 12V to power the board. Can they use 24V power as well?
  Sensor inputs
Posted by: BaconRanch - 09-17-2024, 06:13 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (1)
I am trying trying to wire in a 3 wire, 12V pir motion detector.
I have a brown wire to constant 12v source
I have a red wire ( trigger ) going to terminal for sensor #1
And I have the blue ground going to body and to ground terminal right next to terminal #1 as per legend on metal cover .
When I short ground terminal and terminal #1 I get a response but the pir is not working as expected.  Have tried other pir devices with no luck.
What is my problem here, has to be something very easy and I just can't get there because I don't know yet how to fine tune time, distance and LUX on the pir.
Picture of wiring at terminal attached .
By the way, check out my project at YouTube video
https://youtu.be/kaFyxVdjftc?si=IFzDsg6tIEdfazml
Heart Sample request(s) for Education (A
Posted by: bsarra - 09-16-2024, 04:03 PM - Forum: Apply for free sample product - No Replies
Greetings.
This post mirrors an email request sent with the subject matching this thread.  Please respond to the email request (sender also matches this forum user account email).
Due to privacy concerns, I am not permitted to post my request details or shipping information on a public platform, so I would direct you to the email sent at the known addresses:
  • hificat@163.com
  • xu169@sina.com
Please advise and correct if there is a better/preferred email address to send such requests.
Thank you.
  4-20mah sensor wiring example
Posted by: aucirc - 09-16-2024, 01:26 PM - Forum: KC868-AIO - Replies (3)
I'm considering the KC868-AIO - I need several water level sensors and interested in using the 4-20mah version of this (as the accuracy is better over longer distances)
https://aliexpress.com/item/1005006338737673.html
It's a two-wire sensor, but I can't find any examples of how this should be connected to the KC868-AIO?  As these work best with 24V should the KC868-AIO be powered with 24V also?
  KC868 A32 Firmware 2.2.4 binding
Posted by: iozzi_giorgio - 09-16-2024, 11:27 AM - Forum: KC868-A32/A32 Pro - Replies (2)
good morning I tried to load the KCS 2.2.4 firmware on the KC868_A32 rev. 1.4 board. in programming I can't connect the input to the output (bind). in the input screen I only see "reverse". I also tried to load a previous version of KCS. I saw the video on YouTube but I couldn't solve it. I also tried with different browsers. can you help me?
  AG PRO / KCS Firmware / IR Learning / Node Red
Posted by: chmabu - 09-16-2024, 07:27 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - No Replies
running the AG PRO with the latest firmware.
1. IR Learning - KCS
If I put the firmware to learning via KCS Web frontend, the Samsung TV IR signals are not recorded. Even no beep is played.
If I use Tuya the IR is recorded.
2. IR Learining - Node Red
In addition I found a video on youtube where the Inject node was used to put IR in learning.
Now I checked the HTTP and the MQTT protocoll. There is no explanation on these protocols how to do this.
3. MQTT Problems
I enabled the MQTT to a remote MQTT server.
Using the MQTT-Explorer I can see the Topic with STATE created. So, apparently AG and MQTT server connection is ok.
BUT: STATE is always empty! Also when I send  {"get _datas" : {"value": true}} -  nothing is responded.
  KinCony Video Contest: Share Your Project, Earn Rewards!
Posted by: admin - 09-16-2024, 02:00 AM - Forum: News - Replies (1)
KinCony Video Submission Campaign: Showcase Your Project and Get Rewarded!
Dear Valued KinCony Customers,
We’re excited to launch a new campaign where you can share how you’re using KinCony products in your projects and help inspire other users! Simply create a short, real-life video showcasing KinCony products in action, and in return, you’ll receive rewards and have your video featured on our official KinCony YouTube channel.
Video Submission Requirements:
  1. Record in vertical format using your smartphone.
  2. The video should be between 15 seconds and 1 minute long.
  3. Show the real wiring connections of the product.
  4. Highlight the actual control features in action.
  5. Capture the real environment where the product is used, such as home settings, outdoor farms, or other real-world IoT project environments.
How to Participate:
  1. Submit your video in MP4 format along with your KinCony official store account email address and username to kincony.iot@gmail.com, or upload it to Google Drive and email us the download link.
  2. We will review your submission within 2 business days and, if approved, upload it to our YouTube channel to share your project with the community.
Get Rewarded: As a token of appreciation, we will provide you with a discount coupon for your next purchase on the KinCony website. Coupon values range from 5 USD to 10 USD, depending on the quality of the video.
We believe that your video can help more users understand and utilize KinCony products in their own projects. We look forward to seeing your submissions and sharing your success with the KinCony community!
  a16 as basis for a security system
Posted by: lcrisp - 09-16-2024, 12:50 AM - Forum: KC868-A16 - Replies (16)
I was planning to use my A16 to form a security system, and while door sensors are easy enough, I'm just a touched confused over how to connect alarms, buzzers, and a motion detector...
A four-wire motion detector needs two of it's wires to be connected to a 12v power supply (I think?) and it's two alarm wires can be connected directly to one of the dry digital inputs.
I believe that I'll then need to connect the siren and alarm to the mosfet outputs via two relays, which will then also have to be connected to their own power supplies?
Am I correct in this assumption? I purchased three 12v power supplies with the board, but I'm now worried that I'll need to purchase another one just to hook everything up! Am I correct in assuming that none of them can be powered via the board's 12v power supply? Can any of them be connected to a 12v power supply in sequence. *Especially valid because an alarm shouldn't ever be sounding (drawing power from a supply) at the same time as a buzzer.
And thus far I've connected it to Home Assistant via Esphome, but because my wireless networks have been hacked before I'd rather limit the A16's exposure to potential hacking attempts. Is there any other way to connect the A16 to Home Assistant so that it doesn't need to be constantly connected via ethernet?
  Free sample request
Posted by: Tran Song HUng - 09-15-2024, 03:59 PM - Forum: Apply for free sample product - No Replies
Dear KINCONY Team
I already know some microprocessor like as PIC, Atmega and now. I want to learn ESP32.
After learning hardware. I know KINCONY have support Apply for free sample.
I hope i can be lucky enough to get it.
I am waiting your feedback.
Thank you so much.  Heart
  H32L - faulty network card
Posted by: athxp - 09-15-2024, 08:19 AM - Forum: KC868-HxB series Smart Controller - Replies (5)
hi, this morning I found H32L disconnected. the network card is turned off and has no green LEDs on. ESP32 tuya module also fails to connect. I tried changing the cable but nothing.
from the input keys the plc works correctly. I attach a screenshot, where you can see that it is not online. what could have happened?
Thank you
