» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 192 online users.
» 0 Member(s) | 172 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bytespider, Crawl, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  B16M ESPHome yaml for home assistant with tuya
Posted by: admin - 09-27-2024, 02:16 AM - Forum: B16M - No Replies
  friendly_name: b16m
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 38
     scl: 39
     frequency: 400kHz
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 18
    rx_pin: 8
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
##pull-up resistance on PCB
      number: 40
      number: 15
      number: 48
      number: 47
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted: false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
download yaml file:
.txt   B16M_HA.txt (Size: 7.15 KB / Downloads: 833)
  B16M ESP32-S3 IO pins define
Posted by: admin - 09-27-2024, 02:13 AM - Forum: B16M - Replies (2)
IIC Bus:
SDA:GPIO38
SCL:GPIO39
PCF8575:U57 (relay1-16): i2c address:0x25
PCF8575:U58 (input1-16): i2c address:0x24
DS3231 RTC i2c address: 0x68
1-wire1:GPIO40
1-wire2:GPIO15
1-wire3:GPIO48
1-wire4:GPIO47
free gpio-1:GPIO13
free gpio-2:GPIO14
free gpio-3:GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
RS485:
RXD:GPIO8
TXD:GPIO18
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
  ESPHome PCF8575 and XL9535 yaml format define updated
Posted by: admin - 09-25-2024, 12:54 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
if using PCF8575 , the pin number will begin 0-7 and 8-15
if using XL9535 , the pin number will begin 0-7 and 10-17
  OLED display for A4
Posted by: tarajas - 09-24-2024, 10:02 PM - Forum: KC868-A4 - Replies (6)
Is it possible to add an I2C OlED display to the A4 via using the 433MHz PINs? On 1.2.4 board I have those available...
Maybe I could add the display to the DIN plastic enclosure creating a cutout with a dremel and fixing the display with screws, so that some important info could be shown there...
P3 has looking the board from head on:
VCC ? ? GND
Where should the SDA and SCL be connected?
  Any plans for KC868-D16 update?
Posted by: VKAN - 09-24-2024, 05:55 PM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
Time to time I see that Kincony updates and improves existing boards. Do you considering updating KC868-D16?
Probably running with ESP32?
  Free sample for IT/tech education in a countryside school
Posted by: tarajas - 09-24-2024, 05:31 PM - Forum: Apply for free sample product - Replies (1)
I was wondering if a countryside school's IT/technology teacher in Hungary (my cousin actually) could be eligible for a sample pack. After my own experiences and hobby tinkering with Kincony products I bought up the idea for my cousin to introduce the product to interested kids at the high school and she is all in about this... potentially sparking more interest out of the average bored student... What is your take on this? Is this an initiative that Kincony could support?
Kind Regards
  PIR Sensor A6
Posted by: BalcdLeo - 09-24-2024, 04:46 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hello, everyone!
I'm relatively new to using the models here, so I have a few questions:
I’m trying to connect some sensors for testing. The only one I’ve successfully used is the DHT22, and now I’m attempting to get the PIR Sensor (the cheap ones) to work, but I haven’t been able to do so. Do you know if there’s anything specific regarding the setup, or is it just how the sensor operates?
Regarding the setup, I powered the PIR using both the 12V input of the A6 (the sensor operates from 5V to 20V) and an external power supply. I can see a reading of P0 indicating it’s connected to P0 or P1, P2... Pn. However, when I try to display the data obtained from the sensor, it doesn’t print in the Arduino IDE Serial monitor.
Do you know if these sensors work with the A6? I’m looking to use basic components for future automation projects.
Thank you all!
Here is my code:
#include <Wire.h>
#include "PCF8574.h"
#define SDA 4
#define SCL 15
#define PIR_SENSOR_PIN P0  // P0 pin on PCF8574 for the PIR sensor
PCF8574 pcf8574(0x22, SDA, SCL);  // I2C address 0x22, SDA GPIO4, SCL GPIO15
unsigned long timeElapsed;  // Variable to measure time
int warm_up = 1;  // Variable to control PIR warm-up
  Serial.begin(115200);  // Initialize serial communication
  Serial.println(__FILE__);
  delay(2000);
  Serial.println("System ready!");
  delay(2000);
  pcf8574.pinMode(PIR_SENSOR_PIN, INPUT);  // Set P0 pin as input for the PIR
  Serial.println("Init pcf8574...");
  if (pcf8574.begin()){
      Serial.println("OK");
      Serial.println("KO");
  // Read the value of the PIR connected to P0 of the PCF8574
  uint8_t sensor_output = pcf8574.digitalRead(PIR_SENSOR_PIN);
  // Check if the PIR detected motion
  if (sensor_output == LOW) {
    Serial.println("PIR ACTIVATED (Nothing detected)");
    Serial.println("PIR DETECTED (Motion)");
  delay(200);  // Delay to avoid excessive readings
  how to check PCF8574/PCF8575 i2c address
Posted by: admin - 09-24-2024, 10:43 AM - Forum: KC868-A series and Uair Smart Controller - No Replies
  Pulse Counter Sensor
Posted by: remiasz - 09-23-2024, 10:19 PM - Forum: KC868-A series and Uair Smart Controller - No Replies
ESPHome has Pulse Counter Sensor.
In yaml I can set count_mode to increment or decrement.
Can I change count_mode in runtime
My yaml file:
  - platform: pulse_counter
    update_interval: 1s
    total:
    pin: ...
    on_press:
      then:
        - lambda: |
            id(motor_pulse_counter).set_rising_edge_mode(esphome::pulse_counter::PulseCounterCountMode::PULSE_COUNTER_INCREMENT);
    pin: ...
    on_press:
      then:
        - lambda: |
            id(motor_pulse_counter).set_rising_edge_mode(esphome::pulse_counter::PulseCounterCountMode::PULSE_COUNTER_DECREMENT);
I want add precise position to "Feedback Cover" by counting impulses from motor sensor.
But this konfiguration always count up in opening and closing cover.
  Power supply
Posted by: salvolivigni - 09-23-2024, 03:38 PM - Forum: KC868-E16S/E16P - Replies (1)
Hi, how many watts does the 12VDC power supply need to have, to power with all 16 relays turned on?
