» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 33 online users.
» 0 Member(s) | 18 Guest(s)
Amazonbot, Applebot, AwarioBot, Crawl, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  [ESP-IDF code examples for A32 Pro]-02 Read digital input ports state
Posted by: admin - 09-14-2024, 12:47 AM - Forum: KC868-A32/A32 Pro - No Replies
* This program reads inputs from two XL9535 I/O expander chips (I2C addresses 0x24 and 0x25)
* and one PCF8574 I/O expander (I2C address 0x23) via I2C using an ESP32-S3.
* The state of all inputs is printed in binary format to the serial monitor every second.
* - The XL9535 chips read inputs from channels 1-32.
* - The PCF8574 chip reads inputs from channels 33-40.
* I2C is initialized on GPIO 11 (SDA) and GPIO 10 (SCL) with a frequency of 40kHz.
#include <stdio.h>
#include "driver/i2c.h"
#include "esp_log.h"
// I2C communication settings
#define I2C_MASTER_SCL_IO           10    // GPIO number for I2C clock line (SCL)
#define I2C_MASTER_SDA_IO           11    // GPIO number for I2C data line (SDA)
#define I2C_MASTER_FREQ_HZ          40000  // I2C frequency set to 40kHz
#define I2C_MASTER_PORT             I2C_NUM_0  // I2C port number used in this program
// I2C addresses for XL9535 chips and PCF8574
#define XL9535_ADDR_1               0x24  // Address for XL9535 (channels 1-16)
#define XL9535_ADDR_2               0x25  // Address for XL9535 (channels 17-32)
#define PCF8574_ADDR                0x23  // Address for PCF8574 (channels 33-40)
// XL9535 registers for input ports
#define XL9535_INPUT_PORT_0         0x00  // Input register for port 0 (channels 1-8)
#define XL9535_INPUT_PORT_1         0x01  // Input register for port 1 (channels 9-16)
// Function prototypes
esp_err_t i2c_master_init();
esp_err_t xl9535_read_inputs(uint8_t device_addr, uint8_t *data);
esp_err_t pcf8574_read_inputs(uint8_t *data);
void read_and_print_inputs();
void app_main() {
    // Initialize I2C master
    ESP_ERROR_CHECK(i2c_master_init());
    // Main loop to read and print input states every second
    while (1) {
        vTaskDelay(1000 / portTICK_PERIOD_MS);  // Wait for 1 second
// Initialize I2C master interface
esp_err_t i2c_master_init() {
    i2c_config_t conf = {
        .mode = I2C_MODE_MASTER,  // Set I2C mode to master
        .sda_io_num = I2C_MASTER_SDA_IO,  // SDA GPIO pin
        .scl_io_num = I2C_MASTER_SCL_IO,  // SCL GPIO pin
        .sda_pullup_en = GPIO_PULLUP_ENABLE,  // Enable internal pull-up for SDA line
        .scl_pullup_en = GPIO_PULLUP_ENABLE,  // Enable internal pull-up for SCL line
        .master.clk_speed = I2C_MASTER_FREQ_HZ,  // Set I2C clock frequency to 40kHz
    i2c_param_config(I2C_MASTER_PORT, &conf);
    return i2c_driver_install(I2C_MASTER_PORT, conf.mode, 0, 0, 0);
// Read inputs from XL9535 I/O expander
esp_err_t xl9535_read_inputs(uint8_t device_addr, uint8_t *data) {
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    i2c_master_start(cmd);
    i2c_master_write_byte(cmd, (device_addr << 1) | I2C_MASTER_WRITE, true);
    i2c_master_write_byte(cmd, XL9535_INPUT_PORT_0, true);
    i2c_master_write_byte(cmd, (device_addr << 1) | I2C_MASTER_READ, true);
    i2c_master_read_byte(cmd, &data[0], I2C_MASTER_ACK);  // Read port 0 (channels 1-8 or 17-24)
    i2c_master_read_byte(cmd, &data[1], I2C_MASTER_NACK); // Read port 1 (channels 9-16 or 25-32)
    i2c_master_stop(cmd);
    esp_err_t ret = i2c_master_cmd_begin(I2C_MASTER_PORT, cmd, 1000 / portTICK_PERIOD_MS);
    i2c_cmd_link_delete(cmd);
    return ret;
// Read inputs from PCF8574 I/O expander
esp_err_t pcf8574_read_inputs(uint8_t *data) {
    i2c_master_write_byte(cmd, (PCF8574_ADDR << 1) | I2C_MASTER_READ, true);
    i2c_master_read_byte(cmd, data, I2C_MASTER_NACK);
    return ret;
// Function to read and print the state of inputs from XL9535 and PCF8574 chips
void read_and_print_inputs() {
    uint8_t xl9535_data_1[2];  // Data buffer for XL9535 (channels 1-16)
    uint8_t xl9535_data_2[2];  // Data buffer for XL9535 (channels 17-32)
    uint8_t pcf8574_data;      // Data buffer for PCF8574 (channels 33-40)
    // Read inputs from the first XL9535 (channels 1-16)
    if (xl9535_read_inputs(XL9535_ADDR_1, xl9535_data_1) == ESP_OK) {
        printf("1-16 input states: %02X%02X\n", xl9535_data_1[1], xl9535_data_1[0]);  // Print in binary
        printf("Error reading from XL9535 (channels 1-16)\n");
    // Read inputs from the second XL9535 (channels 17-32)
    if (xl9535_read_inputs(XL9535_ADDR_2, xl9535_data_2) == ESP_OK) {
        printf("17-32 input states: %02X%02X\n", xl9535_data_2[1], xl9535_data_2[0]);  // Print in binary
        printf("Error reading from XL9535 (channels 17-32)\n");
    // Read inputs from the PCF8574 (channels 33-40)
    if (pcf8574_read_inputs(&pcf8574_data) == ESP_OK) {
        printf("33-40 input states: %02X\n", pcf8574_data);  // Print in binary
        printf("Error reading from PCF8574 (channels 33-40)\n");
  [ESP-IDF code examples for A32 Pro]-01 Turn ON/OFF relay
Posted by: admin - 09-14-2024, 12:38 AM - Forum: KC868-A32/A32 Pro - No Replies
* This program controls two PCA9555 I/O expander chips via I2C to control a total of 32 relays.
* The first PCA9555 (at I2C address 0x21) controls relays 1-16, while the second PCA9555 (at I2C address 0x22)
* controls relays 17-32. The relays are turned ON (LOW) and OFF (HIGH) in sequence.
* Each PCA9555 chip has two ports: port 0 controls relays 1-8 (or 17-24), and port 1 controls relays 9-16 (or 25-32).
* The program will initialize both chips and turn all relays OFF initially, then turn each relay ON one by one.
* After a delay, all relays are turned OFF again.
#include <stdio.h>
#include <string.h>
#define I2C_MASTER_FREQ_HZ          100000 // Frequency for I2C clock (100kHz)
// I2C write/read settings
#define WRITE_BIT                   I2C_MASTER_WRITE // I2C write mode
#define READ_BIT                    I2C_MASTER_READ  // I2C read mode
#define ACK_CHECK_EN                0x1     // Enable I2C ACK checking
#define ACK_CHECK_DIS               0x0     // Disable I2C ACK checking
#define ACK_VAL                     0x0     // I2C ACK value
#define NACK_VAL                    0x1     // I2C NACK value
// PCA9555 I2C addresses (chip 1: controls relays 1-16, chip 2: controls relays 17-32)
#define PCA9555_ADDR_1              0x21    // I2C address for the first PCA9555 (1-16 relays)
#define PCA9555_ADDR_2              0x22    // I2C address for the second PCA9555 (17-32 relays)
// PCA9555 Register addresses
#define PCA9555_REG_OUTPUT_0        0x02    // Output register for port 0 (controls relays 1-8 or 17-24)
#define PCA9555_REG_OUTPUT_1        0x03    // Output register for port 1 (controls relays 9-16 or 25-32)
// Function declarations (prototypes)
esp_err_t i2c_master_init(); // Initializes the I2C master
esp_err_t pca9555_write_byte(uint8_t device_addr, uint8_t reg_addr, uint8_t data); // Writes a byte to a PCA9555 register
void control_relays(); // Main function to control the relays
// Main application entry point
void app_main() {
    // Set both PCA9555 chips' all pins as output and turn all relays OFF initially (0xFF = all HIGH = OFF)
    ESP_ERROR_CHECK(pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_0, 0xFF)); // Turn off relays 1-8
    ESP_ERROR_CHECK(pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_1, 0xFF)); // Turn off relays 9-16
    ESP_ERROR_CHECK(pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_0, 0xFF)); // Turn off relays 17-24
    ESP_ERROR_CHECK(pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_1, 0xFF)); // Turn off relays 25-32
    // Start controlling relays (turn on one by one, then off)
    control_relays();
// Function to initialize the I2C master
    // I2C configuration structure
        .mode = I2C_MODE_MASTER,       // Set the I2C mode to master
        .sda_io_num = I2C_MASTER_SDA_IO, // Set the SDA GPIO pin
        .scl_io_num = I2C_MASTER_SCL_IO, // Set the SCL GPIO pin
        .master.clk_speed = I2C_MASTER_FREQ_HZ, // Set I2C clock frequency to 100kHz
    // Apply I2C configuration to I2C master port
    // Install the I2C driver for the master port
// Function to write a byte of data to a specified register of the PCA9555
// device_addr: I2C address of the PCA9555 chip (0x21 or 0x22)
// reg_addr: Register address to write to (e.g., output register 0 or 1)
// data: The byte of data to write (e.g., relay states: HIGH = OFF, LOW = ON)
esp_err_t pca9555_write_byte(uint8_t device_addr, uint8_t reg_addr, uint8_t data) {
    // Create a new I2C command link
    // Start the I2C communication
    // Send the PCA9555's I2C address with the write bit
    i2c_master_write_byte(cmd, (device_addr << 1) | WRITE_BIT, ACK_CHECK_EN);
    // Send the register address where the data should be written
    i2c_master_write_byte(cmd, reg_addr, ACK_CHECK_EN);
    // Send the actual data to be written to the register
    i2c_master_write_byte(cmd, data, ACK_CHECK_EN);
    // Stop the I2C communication
    // Execute the I2C command and return the result
    // Delete the I2C command link after use
    return ret;
// Function to control the relays on both PCA9555 chips
void control_relays() {
    uint8_t relay_state_0 = 0xFE; // Relay 1 ON (LOW), others OFF (HIGH) for port 0
    uint8_t relay_state_1 = 0xFF; // All OFF (HIGH) for port 1 initially
    // Control the first PCA9555 chip (relays 1-16)
    // Port 0 controls relays 1-8
    for (int i = 0; i < 8; ++i) {
        ESP_LOGI("Relay Control", "Setting relay %d ON (chip 1, port 0)", i + 1);
        // Write relay states to port 0 of the first PCA9555 (1-8 relays)
        pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_0, relay_state_0);
        relay_state_0 = (relay_state_0 << 1) | 0x01; // Shift to the next relay
        vTaskDelay(100 / portTICK_PERIOD_MS); // Delay between relay actions
    relay_state_0 = 0xFE; // Reset state for port 0, relay 9 ON
    // Port 1 controls relays 9-16
        ESP_LOGI("Relay Control", "Setting relay %d ON (chip 1, port 1)", i + 9);
        // Write relay states to port 1 of the first PCA9555 (9-16 relays)
        pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_1, relay_state_0);
    relay_state_0 = 0xFE; // Relay 17 ON (LOW), others OFF (HIGH) for port 0
    // Control the second PCA9555 chip (relays 17-32)
    // Port 0 controls relays 17-24
        ESP_LOGI("Relay Control", "Setting relay %d ON (chip 2, port 0)", i + 17);
        // Write relay states to port 0 of the second PCA9555 (17-24 relays)
        pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_0, relay_state_0);
    relay_state_0 = 0xFE; // Reset state for port 1, relay 25 ON
    // Port 1 controls relays 25-32
        ESP_LOGI("Relay Control", "Setting relay %d ON (chip 2, port 1)", i + 25);
        // Write relay states to port 1 of the second PCA9555 (25-32 relays)
        pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_1, relay_state_0);
    // After a short delay, turn all relays OFF
    // Set all relays on both chips to OFF (HIGH)
    pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_0, 0xFF); // Turn off relays 1-8
    pca9555_write_byte(PCA9555_ADDR_1, PCA9555_REG_OUTPUT_1, 0xFF); // Turn off relays 9-16
    pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_0, 0xFF); // Turn off relays 17-24
    pca9555_write_byte(PCA9555_ADDR_2, PCA9555_REG_OUTPUT_1, 0xFF); // Turn off relays 25-32
  [arduino code examples for A32 Pro]-11 How to use digital input port trigger relay
Posted by: admin - 09-14-2024, 12:12 AM - Forum: KC868-A32/A32 Pro - Replies (2)
  Program functionality:
  This program uses ESP32-S3 to read inputs from two PCA9555 I/O expander chips (I2C addresses 0x24 and 0x25)
  for channels 1-32, and control corresponding relays using two PCA9555 I/O expander chips (I2C addresses 0x21 and 0x22)
  for controlling 32 relays (1-32). When input1 is triggered, relay1 is activated; when input2 is triggered,
  relay2 is activated, and so on.
  The I2C bus is initialized on GPIO pins 11 (SDA) and 10 (SCL) with a frequency of 100kHz.
#include <PCA95x5.h>
#include <Wire.h>
// Initialize the PCA9555 objects for reading inputs (channels 1-32)
PCA9555 input_ioex1;  // For channels 1-16 (I2C address 0x24)
PCA9555 input_ioex2;  // For channels 17-32 (I2C address 0x25)
// Initialize the PCA9555 objects for controlling relays (channels 1-32)
PCA9555 output_ioex1; // For relays 1-16 (I2C address 0x21)
PCA9555 output_ioex2; // For relays 17-32 (I2C address 0x22)
    delay(10);
    // Initialize the I2C bus with GPIO 11 as SDA and GPIO 10 as SCL, 100kHz frequency
    Wire.begin(11, 10, 100000);
    // Configure the input PCA9555 chips (for inputs 1-32)
    input_ioex1.attach(Wire, 0x24);  // I2C address 0x24 for inputs 1-16
    input_ioex1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);  // No polarity inversion
    input_ioex1.direction(PCA95x5::Direction::IN_ALL);  // Set all pins as inputs
    input_ioex2.attach(Wire, 0x25);  // I2C address 0x25 for inputs 17-32
    input_ioex2.polarity(PCA95x5::Polarity::ORIGINAL_ALL);  // No polarity inversion
    input_ioex2.direction(PCA95x5::Direction::IN_ALL);  // Set all pins as inputs
    // Configure the output PCA9555 chips (for relays 1-32)
    output_ioex1.attach(Wire, 0x21);  // I2C address 0x21 for relays 1-16
    output_ioex1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);  // No polarity inversion
    output_ioex1.direction(PCA95x5::Direction::OUT_ALL);  // Set all pins as outputs
    output_ioex1.write(PCA95x5::Level::H_ALL);  // Initialize all relays to OFF (HIGH)
    output_ioex2.attach(Wire, 0x22);  // I2C address 0x22 for relays 17-32
    output_ioex2.polarity(PCA95x5::Polarity::ORIGINAL_ALL);  // No polarity inversion
    output_ioex2.direction(PCA95x5::Direction::OUT_ALL);  // Set all pins as outputs
    output_ioex2.write(PCA95x5::Level::H_ALL);  // Initialize all relays to OFF (HIGH)
    delay(50);  // Wait for initialization to complete
    // Read the input states from the first PCA9555 chip (inputs 1-16)
    uint16_t inputs_1_16 = input_ioex1.read();
    // Iterate through each input (1-16) and control corresponding relay output
    for (int i = 0; i < 16; ++i) {
        bool input_state = bitRead(inputs_1_16, i);  // Read the state of each input (0 = triggered, 1 = not triggered)
        if (input_state == 0) {  // If the input is triggered (pressed, i.e., LOW)
            output_ioex1.write((PCA95x5::Port::Port)i, PCA95x5::Level::L);  // Activate corresponding relay (LOW)
            output_ioex1.write((PCA95x5::Port::Port)i, PCA95x5::Level::H);  // Deactivate relay (HIGH)
    // Read the input states from the second PCA9555 chip (inputs 17-32)
    uint16_t inputs_17_32 = input_ioex2.read();
    // Iterate through each input (17-32) and control corresponding relay output
        bool input_state = bitRead(inputs_17_32, i);  // Read the state of each input (0 = triggered, 1 = not triggered)
            output_ioex2.write((PCA95x5::Port::Port)i, PCA95x5::Level::L);  // Activate corresponding relay (LOW)
            output_ioex2.write((PCA95x5::Port::Port)i, PCA95x5::Level::H);  // Deactivate relay (HIGH)
    delay(100);  // Small delay for stability
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 1.26 KB / Downloads: 909)
.zip   11-input-trigger-output.ino.merged.zip (Size: 187.31 KB / Downloads: 816)
  [arduino code examples for A32 Pro]-10 How to test AT command with SIM7600 4G modulde
Posted by: admin - 09-14-2024, 12:09 AM - Forum: KC868-A32/A32 Pro - Replies (2)
  All rights reserved.
  ESP32-S3 with SIM7600 and RS485 Communication
  This program sends an AT command to the SIM7600 4G module every 3 seconds to query its model number.
  The response from the SIM7600 is then sent out through the RS485 interface.
  Connections:
  SIM7600:
    TXD: GPIO18
    RXD: GPIO17
  RS485:
    TXD: GPIO9
    RXD: GPIO8
#include <HardwareSerial.h>
// Create a hardware serial object for SIM7600 communication using UART2
HardwareSerial sim7600(2); // UART2: TXD on GPIO18, RXD on GPIO17
// Create a hardware serial object for RS485 communication using UART1
HardwareSerial rs485(1);   // UART1: TXD on GPIO9, RXD on GPIO8
  // Initialize the default serial port for debugging (Serial Monitor)
  Serial.begin(115200);        // Baud rate of 115200 for debugging
  // Initialize the SIM7600 serial port with baud rate of 115200
  // Set TX to GPIO18 and RX to GPIO17
  sim7600.begin(115200, SERIAL_8N1, 17, 18);
  // Initialize the RS485 serial port with baud rate of 9600
  // Set TX to GPIO9 and RX to GPIO8
  rs485.begin(9600, SERIAL_8N1, 8, 9);
  // Wait for 3 seconds before starting (optional, can be used for initialization delay)
  delay(3000);
  // Send the AT command to query SIM7600 module model number
  // "AT+CGMM" is the command used to get the model of the SIM7600
  sim7600.println("AT+CGMM");
  // Wait for 1 second to allow time for the SIM7600 to respond
  // Check if there is any data available from the SIM7600 module
  if (sim7600.available()) {
    // Create a string to store the response from the SIM7600
    String simResponse = "";
    // While data is available from the SIM7600, read it byte by byte
    while (sim7600.available()) {
      // Read one byte from the SIM7600 serial
      char c = sim7600.read();
      // Append the byte to the response string
      simResponse += c;
    // Send the SIM7600 response to the RS485 serial port
    rs485.print(simResponse);
    // Also print the response to the Serial Monitor for debugging
    Serial.println(simResponse);
  // Wait for 3 seconds before sending the next query
  delay(3000);
.zip   10-4g-sim7600.zip (Size: 1.04 KB / Downloads: 836)
.zip   10-4g-sim7600.ino.merged.zip (Size: 182.27 KB / Downloads: 829)
  [arduino code examples for A32 Pro]-09 How to output DC0-10v from GP8403 DAC port
Posted by: admin - 09-14-2024, 12:06 AM - Forum: KC868-A32/A32 Pro - No Replies
* This Arduino program controls the GP8403 DAC I2C chip using an ESP32-S3 board.
* The program sets the DAC outputs for two channels:
* - Channel 0 (CH0) outputs 5V.
* - Channel 1 (CH1) outputs 10V.
* The I2C communication is handled using the Wire library, and the SDA and SCL pins
* are custom defined as GPIO11 (SDA) and GPIO10 (SCL).
* GP8403 I2C address: 0x58
#include "DFRobot_GP8403.h"
// Initialize the GP8403 DAC object with the I2C address 0x58
DFRobot_GP8403 dac(&Wire, 0x58);
  // Start serial communication for debugging purposes
  // Initialize I2C communication with custom SDA and SCL pins
  Wire.begin(11, 10);  // SDA = GPIO11, SCL = GPIO10
  // Try to initialize the DAC, retry if initialization fails
  while(dac.begin() != 0) {
    Serial.println("Initialization failed, retrying...");
    delay(1000);  // Wait for 1 second before retrying
  // If initialization succeeds
  Serial.println("Initialization successful!");
  // Set the DAC output range to 10V (this setting applies to both channels)
  dac.setDACOutRange(dac.eOutputRange10V);
  // Set the output for DAC channel 0 to 5V
  // Range for 10V mode is 0-10000, so 5000 represents 5V
  dac.setDACOutVoltage(5000, 0);  // Set CH0 to 5V
  Serial.println("Channel 0 set to 5V");
  // Set the output for DAC channel 1 to 10V
  dac.setDACOutVoltage(10000, 1);  // Set CH1 to 10V
  Serial.println("Channel 1 set to 10V");
  // Store the data in the chip's non-volatile memory so it persists after power-off
  dac.store();
  Serial.println("DAC values stored in memory");
  // No need to continuously write the values, the DAC holds the last set value
.zip   9-dac-GP8403.zip (Size: 975 bytes / Downloads: 832)
.zip   9-dac-GP8403.ino.merged.zip (Size: 187.92 KB / Downloads: 899)
  [arduino code examples for A32 Pro]-08 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 09-14-2024, 12:04 AM - Forum: KC868-A32/A32 Pro - No Replies
* - SCL (clock) on pin IO10
* - SDA (data) on pin IO11
// Initialize the display using the software I2C method (SCL = IO10, SDA = IO11)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  10, 11, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   8-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 798)
.zip   8-oled-ssd1306.ino.merged.zip (Size: 198.95 KB / Downloads: 836)
  [arduino code examples for A32 Pro]-07 Communication between ESP32-S3 and Tuya module
Posted by: admin - 09-14-2024, 12:00 AM - Forum: KC868-A32/A32 Pro - No Replies
* Copyright (c) 2024 KinCony IoT (https://www.kincony.com)
* This Arduino program implements communication between ESP32-S3 and the Tuya module
* and responds according to predefined commands. Additionally, it uses an LED connected
* to GPIO45 to indicate the network status based on the Tuya module's response, and a button
* on GPIO21 to initiate a manual quick configuration (EZ mode).
* Functionality:
* 1. The ESP32-S3 communicates with the Tuya module via serial (UART).
* 2. The program listens for specific commands from the Tuya module, such as heartbeat, product info requests, work mode requests, and network status.
* 3. When the ESP32-S3 receives a heartbeat packet (0x55 0xAA 00 00 00 00 0xFF), it responds with a heartbeat response (0x55 0xAA 03 00 00 01 00 03).
* 4. When the ESP32-S3 receives a network status update, it controls an LED connected to GPIO45 to indicate the current state:
*    - Fast blink (every 250ms) indicates the device is in quick configuration mode (EZ mode).
*    - Slow blink (every 1500ms) indicates the device is in hotspot configuration mode (AP mode).
*    - Solid ON indicates the device is successfully connected to the cloud.
* 5. A button connected to GPIO21 is used to send a command to the Tuya module to start the quick configuration mode.
* Pin definitions:
* - TXD (ESP32 to Tuya module): GPIO15
* - RXD (Tuya module to ESP32): GPIO16
* - LED for network status indication: GPIO45
* - Button for starting quick configuration: GPIO21
HardwareSerial tuyaSerial(1);
// Define the GPIO pins for TXD and RXD used for serial communication with the Tuya module
#define TXD_PIN 15
#define RXD_PIN 16
#define BAUD_RATE 9600
// Define the GPIO for LED and Button
#define LED_PIN 45
#define BUTTON_PIN 21
// Define LED flash intervals (in milliseconds) for different states
#define FAST_FLASH_INTERVAL 250      // Fast blink for EZ mode
#define SLOW_FLASH_INTERVAL 1500     // Slow blink for AP mode
#define LONG_LIGHT_INTERVAL 10000    // Long light for cloud connection (simulating always ON)
// Variables to control LED state
bool ledState = LOW;                 // Tracks the current state of the LED
unsigned long previousMillis = 0;    // Used to track time for blinking the LED
unsigned long flashInterval = LONG_LIGHT_INTERVAL;  // Default interval (long ON)
// Heartbeat response: Tuya expects this response after sending a heartbeat
// Product info response with details (e.g., product ID, firmware version, etc.)
// Work mode response: Sent when the Tuya module asks for the current work mode
uint8_t workModeResponse[] = {0x55, 0xAA, 0x03, 0x02, 0x00, 0x00, 0x04};
// Network status response: Sent when the Tuya module asks for the network status
// Subsequent heartbeat response: Sent after the first heartbeat response
// Command to start quick configuration (EZ mode) when the button is pressed
uint8_t quickConfigCommand[] = {0x55, 0xAA, 0x03, 0x05, 0x00, 0x01, 0x00, 0x08};
  // Initialize the GPIO for LED and button
  pinMode(LED_PIN, OUTPUT);       // Set the LED pin as output
  pinMode(BUTTON_PIN, INPUT_PULLUP); // Use internal pull-up resistor for the button
  // Handle LED blinking based on the current flash interval
  unsigned long currentMillis = millis();  // Get the current time
  if (currentMillis - previousMillis >= flashInterval) {
    previousMillis = currentMillis;        // Update the time tracker
    ledState = !ledState;                  // Toggle the LED state
    digitalWrite(LED_PIN, ledState);       // Update the LED state
  // Check if the button is pressed (active low)
  if (digitalRead(BUTTON_PIN) == LOW) {
    Serial.println("Button pressed, sending quick config command...");
    sendPacket(quickConfigCommand, sizeof(quickConfigCommand));  // Send quick config command
    delay(500);  // Debounce delay to avoid multiple triggers
  // Check if there is any data available from the Tuya module
  if (tuyaSerial.available()) {
    size_t bytesRead = tuyaSerial.readBytes(incomingPacket, 7); // Read 7 bytes from Tuya module
      if (bytesRead < 7) {
        delay(50); // Wait briefly to receive the remaining bytes
          if (bytesRead >= 7) break;
      // If the packet is still incomplete, discard it
      if (bytesRead < 7) return;
      // Process the received packet
      // If the header is invalid, discard the packet
  // Small delay to prevent CPU overload
  delay(100);
// Function to process the received packet from Tuya module and send appropriate responses
  // Ensure the packet size is correct and the header is valid
    // Check the command byte (packet[2]) to determine the type of request
    switch (packet[2]) {
      case 0x00:
        // Heartbeat request
          sendPacket(heartBeatResponse, sizeof(heartBeatResponse));  // Send heartbeat response
        break;
      case 0x01:
        // Product info request
        sendPacket(productInfoResponse, sizeof(productInfoResponse));  // Send product info response
        break;
      case 0x02:
        // Work mode request
        sendPacket(workModeResponse, sizeof(workModeResponse));  // Send work mode response
        break;
      case 0x03:
        // Network status request
        sendPacket(netStatusResponse, sizeof(netStatusResponse));  // Send network status response
        // Change LED flash pattern based on network status (packet[6])
        if (packet[6] == 0x00) {
          flashInterval = FAST_FLASH_INTERVAL;  // Set LED to fast blink for EZ mode
        } else if (packet[6] == 0x01) {
          flashInterval = SLOW_FLASH_INTERVAL;  // Set LED to slow blink for AP mode
        } else if (packet[6] == 0x04) {
          flashInterval = LONG_LIGHT_INTERVAL;  // Set LED to long ON for cloud connection
          digitalWrite(LED_PIN, HIGH);          // Ensure LED is ON
        break;
      default:
        break;
// Function to send a response packet to the Tuya module
  // Send the packet via UART to the Tuya module
  // Debug: Print the sent packet for logging purposes
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   7-tuya-wifi-config.zip (Size: 2.89 KB / Downloads: 895)
.zip   7-tuya-wifi-config.ino.merged.zip (Size: 182.85 KB / Downloads: 853)
  [arduino code examples for A32 Pro]-06 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 09-13-2024, 11:55 PM - Forum: KC868-A32/A32 Pro - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO44
* - MISO: GPIO40
* - CS: GPIO39
* - RST: GPIO43
* - INT: GPIO41
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
// Define the W5500 Ethernet module pins with the new GPIO assignments
#define W5500_CS_PIN  39
#define W5500_RST_PIN 43
#define W5500_INT_PIN 41
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 44
#define W5500_MISO_PIN 40
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   6-Ethernet-W5500.zip (Size: 1.25 KB / Downloads: 879)
.zip   6-Ethernet-W5500.ino.merged.zip (Size: 186.82 KB / Downloads: 870)
  [arduino code examples for A32 Pro]-05 Read free GPIO state
Posted by: admin - 09-13-2024, 11:51 PM - Forum: KC868-A32/A32 Pro - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 1
* - GPIO 2
* - GPIO 38
* - GPIO 0
* - GPIO 21
* Hardware Requirements:
#define GPIO_PIN_1  1
#define GPIO_PIN_2  2
#define GPIO_PIN_38 38
#define GPIO_PIN_0  0
#define GPIO_PIN_21 21
bool prevState[5] = {false, false, false, false, false}; // Adjusted to 5 elements
  pinMode(GPIO_PIN_1, INPUT);
  pinMode(GPIO_PIN_2, INPUT);
  pinMode(GPIO_PIN_38, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  bool currentState[5];
  currentState[0] = digitalRead(GPIO_PIN_1);
  currentState[1] = digitalRead(GPIO_PIN_2);
  currentState[2] = digitalRead(GPIO_PIN_38);
  currentState[3] = digitalRead(GPIO_PIN_0);
  currentState[4] = digitalRead(GPIO_PIN_21);
  for (int i = 0; i < 5; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_1 :
                   i == 1 ? GPIO_PIN_2 :
                   i == 2 ? GPIO_PIN_38 :
                   i == 3 ? GPIO_PIN_0 : GPIO_PIN_21);
      Serial.print(" changed to ");
      // Update the previous state
.zip   5-free-gpio-state.zip (Size: 1,011 bytes / Downloads: 801)
.zip   5-free-gpio-state.ino.merged.zip (Size: 177.4 KB / Downloads: 781)
  [arduino code examples for A32 Pro]-04 RS485 communication test
Posted by: admin - 09-13-2024, 11:49 PM - Forum: KC868-A32/A32 Pro - No Replies
* RS485 Communication Test with Echo
* This program tests RS485 communication using ESP32-S3.
* It sends a message over RS485, reads incoming messages, and echoes them back.
* The TXD pin is defined as GPIO 9 and RXD pin is defined as GPIO 8.
// Define RS485 pins
#define RS485_RXD 8
#define RS485_TXD 9
  while (!Serial);
  // Send a test message periodically
// rs485Serial.println("Hello from KinCony A32 Pro!");
  // Wait for a short period
  delay(100);
  // Check if data is available to read from RS485
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message to the serial monitor
    Serial.print("Received: ");
    // Echo the received message back over RS485
    rs485Serial.print("Echo: ");
    rs485Serial.println(receivedMessage);
  delay(2000);
.zip   4-RS485-Test.zip (Size: 823 bytes / Downloads: 791)
.zip   4-RS485-Test.ino.merged.zip (Size: 182.27 KB / Downloads: 811)
