» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 33 online users.
» 0 Member(s) | 25 Guest(s)
Amazonbot, Baidu, PetalBot, bot
kc868-a6 analog input
9 hours ago
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Input Flickering Issue with KC868-A16
Posted by: amir - 09-10-2024, 07:03 AM - Forum: KC868-A16 - Replies (3)
I'm using a KC868-A16 controller with ESPHome and I've encountered an issue with two inputs that occasionally "jump" - turning on and off by themselves.
to input 03 nothing is connected
 I'd appreciate any help in resolving this problem.
  Ayuda con configuración de pines rs485
Posted by: sistemasyusa - 09-10-2024, 01:26 AM - Forum: KC868-A6 - Replies (5)
Me pueden ayudar con la configuración en el mismo código de Arduino, el cambio de.pines del rs485 y scl ya que tengo otras tarjetas que programo y no quiero estar moviendo ese dato desde la configuración de Arduino ide, gracias
  ESPHOME DAC 0-10 Valve control
Posted by: montemartello - 09-09-2024, 03:27 PM - Forum: KC868-A4S - Replies (2)
I would like to make a PID control of 2 3-way valves of the HVAC system. The valves have a 0-10V control and are powered by 24VAC.
I saw the example that controls an RGB led, but now ESPHOME has added the "valve" entity. Is it possible to have an example of how to control a 0-10V valve?
https://esphome.io/components/valve/index.html
  CONECTAR A RED WIFI
Posted by: sistemasyusa - 09-09-2024, 08:23 AM - Forum: KC868-A6 - Replies (2)
BUEN DIA ME PUEDEN APOYAR PARA CONECTAR EN MODO CLIENTE EL ESP DE LA TARJETA Y USAR EL RS485 PARA RECIBIR DATOS Y ENVIARLOS A UNA PAGINA WEB PROPIA
  "KCS" v2.4.9 firmware for M30 AC Energy Meter
Posted by: admin - 09-09-2024, 08:07 AM - Forum: "KCS" v2 firmware system - No Replies
2.4.9 improment:
support M30 work with home assistant "Energy" dashboard.
ESP32 firmware download:
.zip   KCS_M30_V2.4.9.zip (Size: 733.53 KB / Downloads: 834)
  A16 crashing when using string driver
Posted by: brendon - 09-09-2024, 12:31 AM - Forum: KC868-A16 - Replies (4)
Hi there,
I am writing a TCP string driver for our AV system and I have the board going, and the inputs/outputs work, I am getting feedback.
However, if i send commands quickly it seems to be able to easily overwhelm the board and it crashes - it will reset and work again after a short while.
I'd understand if it was a lot of packets, but I'm literally sending 1 a second and that's enough to crash the board - it should be able to handle this faster than I can click without issues?
I am only sending one string at a time, either all on, all off, or a multi-on which does a bitwise operation on the AV side and sends the correct string.
Can you advise why this is?
  Jogging
Posted by: remiasz - 09-08-2024, 06:14 PM - Forum: KC868-A16 - Replies (7)
How does output work in "jogging" mode?
I don't see any diffrence with "hold on" mode.
  KCS firmware
Posted by: remiasz - 09-08-2024, 05:28 PM - Forum: KC868-A series and Uair Smart Controller - Replies (14)
Hello
Can You add "save/restore configuration" option to admin page.
I upgraded firmware and all config was lost.
I had only a few IFTTT rules and one Custom Protocol but writing again 128 IFTT rules and 64 protocols, config all outputs and sensors parameter may be frustrating.
Question using 5v-12v as input sensor
Posted by: amararsa24s - 09-08-2024, 11:05 AM - Forum: KC868-A6 - Replies (23)
hi all
I would like to use IR Photoelectric Switch such as :  PNP, Normally Open sensor. E3F-DS30P1
Ideally, I would use the 12v from the A6 board to power the IR switch, I'm only concerned about the output of the switch...
Can I connect it safely to one of the Digital inputs or Analog inputs?
The E3D-DS30P1 will output the exact same voltage as it get's on it's the vcc leg when it detects an object.
thanks!
https://www.bing.com/search?q=PNP%2C+Nor...E3F-DS30P1
  KinCony new cloud server begin test
Posted by: admin - 09-08-2024, 01:11 AM - Forum: News - No Replies
login URL: https://mq.kincony.com/qq
