» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 313 online users.
» 0 Member(s) | 294 Guest(s)
Amazonbot, AwarioBot, Baidu, Bing, Bytespider, Crawl, HeadlessChrome, bot
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  A128 and B32Pro
Posted by: kkabuu - 10-29-2024, 05:10 PM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Hello. I also ask for help.
I have 1 piece of A128 and B32Pro with AK.
I want to make one of these modules keep the output on as long as I press an input?
I also tried with (KCS firmware v2 and v1)
can i do this with these modules?
  Issue with Device Connectivity – KC868-A4S Relay Controller
Posted by: Bhumijo - 10-29-2024, 06:14 AM - Forum: KC868-A4S - Replies (1)
So far, I've completed this part. Here’s the link, but it’s still not working: [Link] . Please help me for the solution . My device name is : 4 channel GSM relay esp32 board – KC868-A4S , link of the product :: https://www.kincony.com/4-channel-gsm-re...board.html
  H32B Pro No integration possible in Home assistant
Posted by: kenny H - 10-29-2024, 02:11 AM - Forum: KC868-HxB series Smart Controller - Replies (5)
Hello
I'm struggling with the integration of the H32B Pro controller into Home assistant via MQTT on Ethernet.
So I followed all the steps like in your video  (https://www.youtube.com/watch?v=wMkQccSFY3A&t=406s )
But I cannot see any entity of the relay inputs/Outputs.
Instead in the log files I get fault messages on the configuration code:
Logger: homeassistant.config
Source: config.py:1300
Invalid config for 'mqtt' at configuration.yaml, line 13: 'broker' is an invalid option for 'mqtt', check: mqtt->0->broker, please check the docs at https://www.home-assistant.io/integrations/mqtt Invalid config for 'mqtt' at configuration.yaml, line 13: 'password' is an invalid option for 'mqtt', check: mqtt->0->password, please check the docs at https://www.home-assistant.io/integrations/mqtt Invalid config for 'mqtt' at configuration.yaml, line 13: 'port' is an invalid option for 'mqtt', check: mqtt->0->port, please check the docs at https://www.home-assistant.io/integrations/mqtt Invalid config for 'mqtt' at configuration.yaml, line 13: 'username' is an invalid option for 'mqtt', check: mqtt->0->username, please check the docs at https://www.home-assistant.io/integrations/mqtt
In the file editor I added the configuration code with the Broker IP adress of the Raspberry pie 5 it's running on, and filled in the correct UID.
Here is what I filled in:
/homeassistant/configuration.yaml
mqtt:
  broker: 192.168.0.25
  port: 1883
  username: mqtt
  password: 123
  - name: 'output-1'
    unique_id: output-1
    state_topic: 'relay32/582284c1f1ea0c0db02022b1/state'
    command_topic: 'relay32/582284c1f1ea0c0db02022b1/set'
    payload_on:  '{"relay1":{"on":1}}'
    payload_off:  '{"relay1":{"on":0}}'
    state_on: 1
    state_off: 0
I installed the Mosquitto broker and the MQTT integration I can't see what Im missing here
  voice assistant supported languages list in home assistant
Posted by: admin - 10-27-2024, 11:39 PM - Forum: KinCony AS - No Replies
https://developers.home-assistant.io/doc...languages/
  "KCS" v2.2.6 firmware BIN file download
Posted by: admin - 10-27-2024, 12:53 AM - Forum: "KCS" v2 firmware system - No Replies
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.2.6 improvement:
1. Missing coma after last input and before first output, example:
... "input15":{"value":false},"input16":{"value":false}"output1":{"value":false}, ...
2. Missing coma after last output and before first adc, example:
... "output15":{"value":false},"output16":{"value":true}"adc1":{"value":0}, ...
3. Missing coma after last adc and before first sensor, example:
... "adc4":{"value":0}"sensor1":{"temperature":-100.0,"humity":-100.0}, ...
4. Typo error on sensor humidity name, example:
... sensor1":{"temperature":-100.0,"humity":-100.0}, ...
instead of: ... sensor1":{"temperature":-100.0,"humidity":-100.0}, ...
.zip   KCS_KC868_A2_V2.2.6.zip (Size: 785.33 KB / Downloads: 806)
.zip   KCS_KC868_A4_V2.2.6.zip (Size: 772.44 KB / Downloads: 801)
.zip   KCS_KC868_A4S_V2.2.6.zip (Size: 795.91 KB / Downloads: 834)
.zip   KCS_KC868_A6_V2.2.6.zip (Size: 770.95 KB / Downloads: 816)
.zip   KCS_KC868_A8_V2.2.6.zip (Size: 778.91 KB / Downloads: 829)
.zip   KCS_KC868_A8M_V2.2.6.zip (Size: 795.43 KB / Downloads: 802)
.zip   KCS_KC868_A8S_V2.2.6.zip (Size: 796.92 KB / Downloads: 796)
.zip   KCS_KC868_A16_V2.2.6.zip (Size: 786.53 KB / Downloads: 930)
.zip   KCS_KC868_A16S_V2.2.6.zip (Size: 797.08 KB / Downloads: 805)
.zip   KCS_KC868_A32_V2.2.6.zip (Size: 776.66 KB / Downloads: 800)
.zip   KCS_KC868_A32M_V2.2.6.zip (Size: 794.87 KB / Downloads: 800)
.zip   KCS_KC868_A64_V2.2.6.zip (Size: 776.8 KB / Downloads: 825)
.zip   KCS_KC868_A128_V2.2.6.zip (Size: 776.65 KB / Downloads: 764)
.zip   KCS_KC868_AG_V2.2.6.zip (Size: 755.13 KB / Downloads: 784)
.zip   KCS_KC868_AI_V2.2.6.zip (Size: 779.15 KB / Downloads: 760)
.zip   KCS_KC868_AIO_V2.2.6.zip (Size: 796.54 KB / Downloads: 799)
.zip   KCS_KC868_AK_V2.2.6.zip (Size: 757.96 KB / Downloads: 844)
.zip   KCS_KC868_AM_V2.2.6.zip (Size: 772.38 KB / Downloads: 766)
.zip   KCS_KC868_AP_V2.2.6.zip (Size: 774.81 KB / Downloads: 760)
.zip   KCS_KC868_ASR_V2.2.6.zip (Size: 752.01 KB / Downloads: 729)
.zip   KCS_KC868_E16S_V2.2.6.zip (Size: 781.42 KB / Downloads: 797)
.zip   KCS_KC868_UAIR_V2.2.6.zip (Size: 758.67 KB / Downloads: 783)
  KC8686-A2 + SIM7070 GSM
Posted by: fogamz - 10-26-2024, 06:25 PM - Forum: KC868-A2 - Replies (1)
KC868-A2 works well with SIM76XX  but I can't connect (no AT response) to the SIM7070.
I've noticed that PWRKEY pin is not conected with the ESP32, so no possibility to do correct reset.
Do you have experience with SIM7070?
Regards
  KC868-HAv2 phantom press in ESPhome
Posted by: Dario - 10-26-2024, 09:27 AM - Forum: KC868-HA /HA v2 - Replies (2)
Is there a way to optimise the Kincony KC868-HAv2? I currently use the new B16M and 2 of the KC868-HAv2 boards in test on ESPhome and I noticed that when I press and release the button quickly multiple times the B16M sees the button as pressed while it is not. When I press again it ofcourse gets reset.
It needs to be fool/child proof in my solution because I'm going to work with double/triple and long press commands in my solution.
Might the debounce setting do something?
Kind regards,
Dario
  B16M ESPHome yaml for home assistant work with Tuya app
Posted by: admin - 10-26-2024, 07:01 AM - Forum: B16M - No Replies
  friendly_name: b16m
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 38
     scl: 39
     frequency: 400kHz
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 18
    rx_pin: 8
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: tg4bava25acki7vz
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b16m_output01"
    dp_id: 2
    internal: true
    bind_switch_id: "b16m_output02"
    dp_id: 3
    internal: true
    bind_switch_id: "b16m_output03"
    dp_id: 4
    internal: true
    bind_switch_id: "b16m_output04"
    dp_id: 5
    internal: true
    bind_switch_id: "b16m_output05"
    dp_id: 6
    internal: true
    bind_switch_id: "b16m_output06"
    dp_id: 101
    internal: true
    bind_switch_id: "b16m_output07"
    dp_id: 102
    internal: true
    bind_switch_id: "b16m_output08"
      number: 8
    dp_id: 103
    internal: true
    bind_switch_id: "b16m_output09"
      number: 9
    dp_id: 104
    internal: true
    bind_switch_id: "b16m_output10"
      number: 10
    dp_id: 105
    internal: true
    bind_switch_id: "b16m_output11"
      number: 11
    dp_id: 106
    internal: true
    bind_switch_id: "b16m_output12"
      number: 12
    dp_id: 107
    internal: true
    bind_switch_id: "b16m_output13"
      number: 13
    dp_id: 108
    internal: true
    bind_switch_id: "b16m_output14"
      number: 14
    dp_id: 109
    internal: true
    bind_switch_id: "b16m_output15"
      number: 15
    dp_id: 110
    internal: true
    bind_switch_id: "b16m_output16"
    dp_id: 111
    bind_binary_sensor_id: b16m_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: b16m_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: b16m_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: b16m_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: b16m_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: b16m_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: b16m_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: b16m_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: b16m_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: b16m_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: b16m_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: b16m_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: b16m_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: b16m_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: b16m_input15
    internal: true
      number: 15
    dp_id: 126
    bind_binary_sensor_id: b16m_input16
    internal: true
##pull-up resistance on PCB
      number: 40
      number: 15
      number: 48
      number: 47
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted: false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B16M");
ESPHome yaml file download:
.txt   B16M_HA-Tuya.txt (Size: 13.87 KB / Downloads: 911)
  KinCony Product Tree
Posted by: admin - 10-26-2024, 06:05 AM - Forum: News - Replies (3)
Here is KinCony products tree , help you to find suitable product. We will continue to innovate and update our product tree.
  MQTT PREFIX TOPIC could be changed in the kincony firmware webpage.
Posted by: Aladin - 10-25-2024, 10:24 AM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
It's possible to permit MQTT PREFIX TOPIC to be changed in the kincony firmware webpage like in TASMOTA?
SOME_CUSTOM_PREFIX/KC868_A16/B8D61B4AA69C/STATE
or
SOME_CUSTOM_PREFIX/XXXXX/XXXXX/STATE
Instead of : KC868_A16/B8D61A5AA69C/STATE
You could keep the default PREFIX & permit to set the entire CUSTOM PREFIX.
We also need to choose UPPERCASE or LOWERCASE format for the MQTT TOPIC.
Thanks!
