» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 360 online users.
» 0 Member(s) | 333 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  H32B pro: No IP adress assigned to controller
Posted by: kenny H - 10-24-2024, 07:34 PM - Forum: KC868-HxB series Smart Controller - Replies (8)
I have the KC868-H32B controller. I managed to follow all steps to connect with homekit and also open the admin page via it's IP adress.
Now, with trying to get in to work in Home assistent, I accidently removed its Ethernet settings ( IP adress, mac, port, etc... ) . So instead of Controller Ethernet IP adress 192.168.1.200. , now scanning it wit ' UDP_Scan_List ' tool . It detects the controller with adress 0.0.0.0.0. I cannot connect to it anymore now.
Everything in the red square, was empty when I clicked on ' save settings '
Is there a way to put all factory settings back?
Kind regards
Kenny
  KinCony AS ESP32-S3 voice assistant released
Posted by: admin - 10-22-2024, 05:25 AM - Forum: News - No Replies
KinCony ESP32-S3 voice assistant based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It use by I2S INMP441 microphone and MAX98357A amplifier. SD card socket on PCB. there are WS2812B RGB LED you can use for assistant. It also have IR receiver and many free GPIOs on PCB.
[Image: AS1_pix400.jpg][Image: AS2_pix400.jpg]
[Image: AS3_pix400.jpg][Image: AS4_pix400.jpg]
Model No. KinCony AS
Description: KinCony ESP32-S3 voice assistant – AS
Power supply: 5V DC by USB cable
interfaces: WiFi,Bluetooth,USB-Mini
SD Card: inside of BOX
WS2812B RGB LED: 2 different channel of GPIO
IR receiver: HS0038
433M receiver PCB pins reserved
Microphone: INMP441 (I2S bus)
Amplifier:MAX98357A (MAX:3.2W)
free GPIOs for DIY extend: 13 pins
hardware details:
[Image: 5.jpg]
[Image: 7.jpg]
[Image: 6.jpg][Image: 8.jpg]
[Image: esp32-s3-wroom-1u.JPG]
software solution:
1. install Speech-to-text add-on “faster-whisper” on home assistant.
2. install Text-to-speech add-on “piper” on home assistant.
3. download AS’ ESPHome yaml file from KinCony forum, modify wifi router SSID and PASSWORD.
4. download firmware to AS(ESP32-S3).
5. begin use in home assistant.
Easy integrate KinCony ESP32-S3 voice assistant to home assistant by ESPHome. You can download yaml file from KinCony forum.
[Image: voice-assistant-ready.png]
[Image: voice-assistant-listen.png]
  how to use AS ESP32-S3 voice assistant in home assistant
Posted by: admin - 10-22-2024, 01:46 AM - Forum: KinCony AS - Replies (17)
Set Up Voice Assist Pipeline
To set up voice assistant, we would need two components to create the Voice Assist pipeline in Home Assistant.
Whisper: For speech-to-text
Piper: For text-to-speech
1: Whisper Addon
2: Piper Addon
3: And finally the entire Voice Assist pipeline.
You don't need to set up the Wake Word addon, as we will use the on-device Wake Word detection with the Micro Wake Word framework
So make sure to watch it and set up the Voice Assist pipeline
ESPHome - add device - create new device called AS:
copy and paste KinCony AS yaml file:
  friendly_name: AS
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
  mode: octal  # quad for N8R2 and octal for N16R8
  speed: 80MHz
  encryption:
    key: "TFpb+pBAvQIS1MVwaA7EoJ2DkpWE+79UvVro7yMyGdU="
  on_client_connected:
        then:
          - delay: 50ms
          - light.turn_off: led_ww
          - micro_wake_word.start:
  on_client_disconnected:
        then:
          - voice_assistant.stop:
ota:
  - platform: esphome
    password: "1245211a05eef56614a2ef5a3f3e971c"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Esp32-S3-Wake-Word"
    password: "LJfUrdJk3svP"
captive_portal:
button:
  - platform: restart
  - platform: template
    optimistic: true
    on_turn_on:
      - micro_wake_word.stop:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
    rgb_order: GRB
    pin: GPIO16
    num_leds: 1
    rmt_channel: 0
    chipset: ws2812
    name: "on board light"
    effects:
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  #WS
    i2s_bclk_pin: GPIO2 #SCK
  - id: i2s_speaker
    i2s_lrclk_pin: GPIO6  #LRC
    i2s_bclk_pin: GPIO7 #BLCK
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO4 #SD pin on the INMP441
    channel: left
    pdm: false
    i2s_audio_id: i2s_in
    bits_per_sample: 32 bit
speaker:
    platform: i2s_audio
    i2s_audio_id: i2s_speaker
    dac_type: external
    i2s_dout_pin: GPIO8   #  DIN Pin of the MAX98357A Audio Amplifier
    channel: mono
micro_wake_word:
  on_wake_word_detected:
    # then:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
  models:
    - model: hey_jarvis
voice_assistant:
  microphone: va_mic
  noise_suppression_level: 2.0
  volume_multiplier: 4.0
  speaker: va_speaker
  on_stt_end:
       then:
  on_error:
  on_end:
        then:
          - wait_until:
              not:
                voice_assistant.is_running:
Note: replace wifi router's ssid and password by yourself.
yaml file download from: https://www.kincony.com/forum/showthread.php?tid=6890
now connect AS to your Server16's USB port (raspberry pi or your own server)
click right top windows "install" button, then will show you install way, chose "Plug into the computer running ESPHome Dashboard" item
click "USB=JTAG" option that detected.
ESPHome begin compile and download firmware:
now you will find the AS device discovered on "setting" - "device webpage". Just click "CONFIGURE" button, assign a room to the device.
AS is ready.
if you speak "hey jarvis" command, voice assistant will show "listening", then you can say, such as "turn on light", "turn off light". just say the name of your device.
  [arduino code examples for AS]-08 how to use WS2812B RGB LED by bottom direction
Posted by: admin - 10-22-2024, 01:30 AM - Forum: KinCony AS - No Replies
  Made by KinCony IoT: https://www.kincony.com
  This code controls 3 WS2812 RGB LEDs connected to GPIO 15 on an ESP32-S3.
  Each LED will be set to blue with adjustable brightness.
  The Adafruit NeoPixel library is used to communicate with the WS2812 LEDs.
  Hardware setup:
  - WS2812 RGB LEDs are connected to GPIO 15 (data pin).
  - Total number of LEDs: 3.
#include <Adafruit_NeoPixel.h>
// Create an instance of the Adafruit_NeoPixel class
// Parameters: number of LEDs (3), data pin (GPIO 15), LED type (NEO_GRB with 800 KHz communication)
Adafruit_NeoPixel rgb_display = Adafruit_NeoPixel(3, 15, NEO_GRB + NEO_KHZ800);
  // Initialize the NeoPixel library and prepare the LEDs for use
  rgb_display.begin();
    rgb_display.setPixelColor(uint16_t n, uint32_t c);
    This function sets the color of a specific LED.
    Parameters:
    - n: The LED number (starting from 0).
    - c: The color to set the LED to, in hexadecimal (0x0000ff = blue in RGB format).
  // Set the first LED (LED 0) to blue
  rgb_display.setPixelColor(0, (0x0000ff)); // Blue color for the first LED (index 0)
  rgb_display.setBrightness(100);           // Set brightness to 100 out of 255
  rgb_display.show();                       // Update the LED to reflect the change
  // Set the second LED (LED 1) to blue
  rgb_display.setPixelColor(1, (0x0000ff)); // Blue color for the second LED (index 1)
  // Set the third LED (LED 2) to blue
  rgb_display.setPixelColor(2, (0x0000ff)); // Blue color for the third LED (index 2)
arduino ino file download:
.zip   LED_WS2812B-3pcs.zip (Size: 879 bytes / Downloads: 873)
.zip   LED_WS2812B.ino.merged.zip (Size: 177.55 KB / Downloads: 786)
  [arduino code examples for AS]-07 how to use WS2812B RGB LED by vertical direction
Posted by: admin - 10-22-2024, 01:25 AM - Forum: KinCony AS - No Replies
  This code controls 1 WS2812 RGB LEDs connected to GPIO 16 on an ESP32-S3.
  Hardware setup:
Adafruit_NeoPixel rgb_display = Adafruit_NeoPixel(1, 16, NEO_GRB + NEO_KHZ800);
    Parameters:
.zip   LED_WS2812B-1pc.zip (Size: 834 bytes / Downloads: 848)
.zip   LED_WS2812B-1pc.ino.merged.zip (Size: 179.91 KB / Downloads: 862)
  [arduino code examples for AS]-06 how to play MP3 file by SD Card
Posted by: admin - 10-22-2024, 01:12 AM - Forum: KinCony AS - No Replies
  ESP32 SD I2S Music Player
  esp32-i2s-sd-player.ino
  Plays MP3 file from microSD card
  Uses MAX98357 I2S Amplifier Module
  Uses ESP32-audioI2S Library - https://github.com/schreibfaul1/ESP32-audioI2S
// Include required libraries
#include "Arduino.h"
#include "Audio.h"
#include "SD.h"
#include "FS.h"
// microSD Card Reader connections
#define SD_CS         13
#define SPI_MOSI      12
#define SPI_MISO      10
#define SPI_SCK       11
// I2S Connections
#define I2S_DOUT      8
#define I2S_BCLK      7
#define I2S_LRC       6
// Create Audio object
Audio audio;
    // Set microSD Card CS as OUTPUT and set HIGH
    pinMode(SD_CS, OUTPUT);
    digitalWrite(SD_CS, HIGH);
    // Initialize SPI bus for microSD Card
    SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
    // Start Serial Port
    // Start microSD Card
    if(!SD.begin(SD_CS))
      Serial.println("Error accessing microSD card!");
      while(true);
    // Setup I2S
    audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    // Set Volume
    audio.setVolume(50);
    // Open music file
    audio.connecttoFS(SD,"/music.mp3");
    audio.loop();
place music.mp3 file on your SD card, make sure SD card is FAT32 format. when board power on, will auto play the MP3 file.
.zip   AS-mp3.zip (Size: 760 bytes / Downloads: 867)
.zip   AS-mp3.ino.merged.zip (Size: 878.75 KB / Downloads: 838)
arduino IDE compile setting:
  [arduino code examples for AS]-05 how to use SD Card
Posted by: admin - 10-22-2024, 01:01 AM - Forum: KinCony AS - No Replies
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO  10
#define MOSI  12
#define CS  13
void readFile(fs::FS &fs, const char * path){
  File file = fs.open(path);
  if(!file){
    return;
  while(file.available()){
  file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
  if(!file){
    return;
  if(file.print(message)){
  file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
  if(!file){
    return;
  file.close();
void deleteFile(fs::FS &fs, const char * path){
  if(fs.remove(path)){
void testFileIO(fs::FS &fs, const char * path){
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if(file){
    len = file.size();
    size_t flen = len;
    start = millis();
    while(len){
      size_t toRead = len;
      if(toRead > 512){
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if(!file){
    return;
  size_t i;
  start = millis();
  for(i=0; i<2048; i++){
    file.write(buf, 512);
  file.close();
void setup(){
  if (!SD.begin(CS,spi,80000000)) {
    return;
  if(cardType == CARD_NONE){
    return;
  if(cardType == CARD_MMC){
    Serial.println("MMC");
  } else if(cardType == CARD_SD){
    Serial.println("SDSC");
  } else if(cardType == CARD_SDHC){
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
void loop(){
make sure your SC Card is FAT32 format.
.zip   AS-SD.zip (Size: 1.1 KB / Downloads: 801)
.zip   AS-SD.ino.merged.zip (Size: 221.37 KB / Downloads: 860)
  [arduino code examples for AS]-04 how to output dynamic wave to speaker by MAX98357A
Posted by: admin - 10-22-2024, 12:57 AM - Forum: KinCony AS - No Replies
  ESP32 I2S Audio Test with Dynamic Frequency and Amplitude
  This code generates a sine wave with changing frequency and amplitude
  to test the MAX98357A amplifier output.
// Include I2S driver
#include <driver/i2s.h>
#include <math.h>
// Connections to MAX98357A amplifier
#define I2S_DOUT  8
#define I2S_BCLK  7
#define I2S_LRC   6
// Use I2S Processor 0
#define I2S_PORT I2S_NUM_0
// Sample rate and initial parameters
const int sampleRate = 44100;
const float baseFrequency = 440.0;  // Base frequency (A4 note)
const int baseAmplitude = 3000;     // Base amplitude
const float frequencyStep = 5.0;    // Frequency change rate
const int amplitudeStep = 50;       // Amplitude change rate
// Variables to control dynamic frequency and amplitude
float currentFrequency = baseFrequency;
int currentAmplitude = baseAmplitude;
int direction = 1;  // To control increase or decrease of frequency and amplitude
void i2s_install() {
  // Set up I2S Processor configuration for TX only
  const i2s_config_t i2s_config = {
    .mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_TX),
    .sample_rate = sampleRate,
    .bits_per_sample = i2s_bits_per_sample_t(16),
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
    .communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_STAND_I2S),
    .intr_alloc_flags = 0,
    .dma_buf_count = 8,
    .dma_buf_len = 64,
    .use_apll = false
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
void i2s_setpin() {
  // Set I2S pin configuration for output (amp)
  const i2s_pin_config_t pin_config = {
    .bck_io_num = I2S_BCLK,
    .ws_io_num = I2S_LRC,
    .data_out_num = I2S_DOUT,
    .data_in_num = I2S_PIN_NO_CHANGE
  i2s_set_pin(I2S_PORT, &pin_config);
  // Set up Serial Monitor
  Serial.println("Generating dynamic sine wave on MAX98357A amplifier");
  // Set up I2S
  i2s_install();
  i2s_setpin();
  i2s_start(I2S_PORT);
  // Buffer to hold the audio data
  int16_t buffer[64];
  // Generate dynamic sine wave (with changing frequency and amplitude)
  for (int i = 0; i < 64; i++) {
    // Generate sine wave with current frequency and amplitude
    float sample = sinf(2.0f * M_PI * currentFrequency * i / sampleRate);
    buffer[i] = (int16_t)(sample * currentAmplitude);  // Convert float to 16-bit integer
  // Send the buffer to the I2S amplifier
  size_t bytesWritten;
  i2s_write(I2S_PORT, &buffer, sizeof(buffer), &bytesWritten, portMAX_DELAY);
  // Adjust frequency and amplitude for the next loop iteration
  currentFrequency += frequencyStep * direction;
  currentAmplitude += amplitudeStep * direction;
  // Change direction of frequency and amplitude when reaching limits
  if (currentFrequency > 880.0 || currentFrequency < 220.0) {
    direction = -direction;  // Reverse direction when frequency reaches upper or lower limit
  if (currentAmplitude > 5000 || currentAmplitude < 1000) {
    direction = -direction;  // Reverse direction when amplitude reaches upper or lower limit
.zip   AS-Speaker-Dynamic-wave.zip (Size: 1.38 KB / Downloads: 874)
.zip   AS-Speaker-Dynamic-wave.ino.merged.zip (Size: 192.38 KB / Downloads: 796)
  [arduino code examples for AS]-03 how to output simple wave to speaker by MAX98357A
Posted by: admin - 10-22-2024, 12:54 AM - Forum: KinCony AS - No Replies
  This code generates a simple sine wave to test the MAX98357A amplifier output.
#include <math.h>
#define I2S_DOUT  8
#define I2S_BCLK  7
#define I2S_LRC   6
// Sample rate and wave parameters
const float frequency = 440.0; // Frequency of the sine wave (A4 note)
const int amplitude = 3000;    // Amplitude of the sine wave
    .dma_buf_count = 8,
    .dma_buf_len = 64,
    .use_apll = false
void i2s_setpin() {
  Serial.println("Generating sine wave on MAX98357A amplifier");
  // Set up I2S
  i2s_install();
  i2s_setpin();
  int16_t buffer[64];
  // Generate sine wave and write it to I2S buffer
    float sample = sinf(2.0f * M_PI * frequency * i / sampleRate);
    buffer[i] = (int16_t)(sample * amplitude); // Convert float to 16-bit integer
.zip   AS-Speaker-Simple-wave.zip (Size: 1.09 KB / Downloads: 945)
.zip   AS-Speaker-Simple-wave.ino.merged.zip (Size: 192.24 KB / Downloads: 877)
  [arduino code examples for AS]-02 how to use INMP441 Microphone
Posted by: admin - 10-22-2024, 12:50 AM - Forum: KinCony AS - No Replies
  ESP32 I2S Microphone Sample
  esp32-i2s-mic-sample.ino
  Sample sound from I2S microphone, display on Serial Plotter
  Requires INMP441 I2S microphone
// Connections to INMP441 I2S microphone
#define I2S_WS 3
#define I2S_SD 4
#define I2S_SCK 2
// Define input buffer length
#define bufferLen 64
int16_t sBuffer[bufferLen];
    .mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX),
    .sample_rate = 44100,
    .dma_buf_count = 8,
    .dma_buf_len = bufferLen,
    .use_apll = false
void i2s_setpin() {
    .bck_io_num = I2S_SCK,
    .ws_io_num = I2S_WS,
    .data_out_num = -1,
    .data_in_num = I2S_SD
  Serial.println(" ");
  // Set up I2S
  i2s_install();
  i2s_setpin();
  delay(500);
  // False print statements to "lock range" on serial plotter display
  // Change rangelimit value to adjust "sensitivity"
  int rangelimit = 3000;
  Serial.print(rangelimit * -1);
  Serial.print(" ");
  Serial.print(rangelimit);
  Serial.print(" ");
  // Get I2S data and place in data buffer
  size_t bytesIn = 0;
  esp_err_t result = i2s_read(I2S_PORT, &sBuffer, bufferLen, &bytesIn, portMAX_DELAY);
  if (result == ESP_OK)
    // Read I2S data buffer
    int16_t samples_read = bytesIn / 8;
    if (samples_read > 0) {
      float mean = 0;
      for (int16_t i = 0; i < samples_read; ++i) {
        mean += (sBuffer[i]);
      // Average the data reading
      mean /= samples_read;
      // Print to serial plotter
      Serial.println(mean);
.zip   INMP441.zip (Size: 1.1 KB / Downloads: 1057)
.zip   INMP441.ino.merged.zip (Size: 187.09 KB / Downloads: 1008)
demo use arduino serial plotter tool to detect microphone sound.
