» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 382 online users.
» 0 Member(s) | 362 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot, owler
kc868-a6 analog input
11 hours ago
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  B16M vS A16
Posted by: admin - 10-08-2024, 11:38 AM - Forum: KC868-A16 - No Replies
  A32 Pro ESPHome yaml include RS485 modbus temperature humidity sensor
Posted by: admin - 10-08-2024, 01:51 AM - Forum: KC868-A32/A32 Pro - Replies (23)
here we use RS485 long distance sensor connect with A32 Pro controller using A and B.
the sensor default setting is 9600bps, RS485 address is 1
we can use USB-RS485 adapter connect PC with sensor , monitor the sensor value, or maybe you want change the sensor address and baud rate, so just use PC software to set. Then we can let sensor connect to A32 Pro's RS485 port directly.
mainly add these code for modbus:
  - id: uart_modbus
    baud_rate: 9600
    tx_pin: 9
    rx_pin: 8
# Config Modbus
modbus:
  uart_id: uart_modbus
modbus_controller:
  - id: modbus_sensor
    address: 0x01  # device address
    modbus_id: modbus1
  - platform: modbus_controller
    modbus_controller_id: modbus_sensor
    name: "RS485 Temperature Sensor"
    address: 0x0000
    register_type: holding
    value_type: U_WORD
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    filters:
      - lambda: if (x < 10000) return x * 0.1; else return -1 * (x - 10000) * 0.1;
    name: "RS485 Humidity Sensor"
    address: 0x0001
    value_type: U_WORD
    unit_of_measurement: "%"
    filters:
      - multiply: 0.1
whole ESPHome ymal code:
  friendly_name: a32-Pro-arduino
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
  - source:
      type: git
      ref: v1.2.0
  board: esp32-s3-devkitc-1
# logger:
  encryption:
    key: "fBpihEYPVlfKaE4ZIcY0uRcJ134u7DBKzzskk994+Lw="
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO44
  miso_pin: GPIO40
  cs_pin: GPIO39
  interrupt_pin: GPIO41
  reset_pin: GPIO43
  - id: uart_modbus
    baud_rate: 9600
    tx_pin: 9
    rx_pin: 8
  - id: tuya_mcu_uart
    baud_rate: 9600
    tx_pin: 15
    rx_pin: 16
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: fwy7fk4mzay3kern
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 21
  wifi_led_pin: 45
# Config Modbus
modbus:
modbus_controller:
  - id: modbus_sensor
    modbus_id: modbus1
   - id: bus_a
     sda: 11
     scl: 10
     frequency: 400kHz
xl9535:
  - id: xl9535_hub_out1 # for output channel 1-16
    address: 0x21
  - id: xl9535_hub_out2 # for output channel 17-32
  - id: xl9535_hub_in1 # for input channel 1-16
  - id: xl9535_hub_in2 # for input channel 17-32
    address: 0x25
  - id: 'pcf8574_in_3'  # for input channel 33-40
    address: 0x23
    pin: 45
    name: A32 Pro Switch01
      xl9535: xl9535_hub_out1
  - platform: tuya_wifi_mcu
    name: A32 Pro Switch01 Tuya
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "a32_pro_switch01"
    name: A32 Pro Switch02
    name: A32 Pro Switch02 Tuya
    dp_id: 102
    internal: true
    bind_switch_id: "a32_pro_switch02"
    name: A32 Pro Switch03
    name: A32 Pro Switch03 Tuya
    dp_id: 103
    internal: true
    bind_switch_id: "a32_pro_switch03"
    name: A32 Pro Switch04
    name: A32 Pro Switch04 Tuya
    dp_id: 104
    internal: true
    bind_switch_id: "a32_pro_switch04"
    name: A32 Pro Switch05
    name: A32 Pro Switch05 Tuya
    dp_id: 105
    internal: true
    bind_switch_id: "a32_pro_switch05"
    name: A32 Pro Switch06
    name: A32 Pro Switch06 Tuya
    dp_id: 106
    internal: true
    bind_switch_id: "a32_pro_switch06"
    name: A32 Pro Switch07
    name: A32 Pro Switch07 Tuya
    dp_id: 107
    internal: true
    bind_switch_id: "a32_pro_switch07"
    name: A32 Pro Switch08
    name: A32 Pro Switch08 Tuya
    dp_id: 108
    internal: true
    bind_switch_id: "a32_pro_switch08"
    name: A32 Pro Switch09
      number: 10
    name: A32 Pro Switch09 Tuya
    dp_id: 109
    internal: true
    bind_switch_id: "a32_pro_switch09"
    name: A32 Pro Switch10
      number: 11
    name: A32 Pro Switch10 Tuya
    dp_id: 110
    internal: true
    bind_switch_id: "a32_pro_switch10"
    name: A32 Pro Switch11
      number: 12
    name: A32 Pro Switch11 Tuya
    dp_id: 111
    internal: true
    bind_switch_id: "a32_pro_switch11"
    name: A32 Pro Switch12
      number: 13
    name: A32 Pro Switch12 Tuya
    dp_id: 112
    internal: true
    bind_switch_id: "a32_pro_switch12"
    name: A32 Pro Switch13
      number: 14
    name: A32 Pro Switch13 Tuya
    dp_id: 113
    internal: true
    bind_switch_id: "a32_pro_switch13"
    name: A32 Pro Switch14
      number: 15
    name: A32 Pro Switch14 Tuya
    dp_id: 114
    internal: true
    bind_switch_id: "a32_pro_switch14"
    name: A32 Pro Switch15
      number: 16
    name: A32 Pro Switch15 Tuya
    dp_id: 115
    internal: true
    bind_switch_id: "a32_pro_switch15"
    name: A32 Pro Switch16
      number: 17
    name: A32 Pro Switch16 Tuya
    dp_id: 116
    internal: true
    bind_switch_id: "a32_pro_switch16"
    name: A32 Pro Switch17
      xl9535: xl9535_hub_out2
    name: A32 Pro Switch17 Tuya
    dp_id: 117
    internal: true
    bind_switch_id: "a32_pro_switch17"
    name: A32 Pro Switch18
    name: A32 Pro Switch18 Tuya
    dp_id: 118
    internal: true
    bind_switch_id: "a32_pro_switch18"
    name: A32 Pro Switch19
    name: A32 Pro Switch19 Tuya
    dp_id: 119
    internal: true
    bind_switch_id: "a32_pro_switch19"
    name: A32 Pro Switch20
    name: A32 Pro Switch20 Tuya
    dp_id: 120
    internal: true
    bind_switch_id: "a32_pro_switch20"
    name: A32 Pro Switch21
    name: A32 Pro Switch21 Tuya
    dp_id: 121
    internal: true
    bind_switch_id: "a32_pro_switch21"
    name: A32 Pro Switch22
    name: A32 Pro Switch22 Tuya
    dp_id: 122
    internal: true
    bind_switch_id: "a32_pro_switch22"
    name: A32 Pro Switch23
    name: A32 Pro Switch23 Tuya
    dp_id: 123
    internal: true
    bind_switch_id: "a32_pro_switch23"
    name: A32 Pro Switch24
    name: A32 Pro Switch24 Tuya
    dp_id: 124
    internal: true
    bind_switch_id: "a32_pro_switch24"
    name: A32 Pro Switch25
      number: 10
    name: A32 Pro Switch25 Tuya
    dp_id: 125
    internal: true
    bind_switch_id: "a32_pro_switch25"
    name: A32 Pro Switch26
      number: 11
    name: A32 Pro Switch26 Tuya
    dp_id: 126
    internal: true
    bind_switch_id: "a32_pro_switch26"
    name: A32 Pro Switch27
      number: 12
    name: A32 Pro Switch27 Tuya
    dp_id: 127
    internal: true
    bind_switch_id: "a32_pro_switch27"
    name: A32 Pro Switch28
      number: 13
    name: A32 Pro Switch28 Tuya
    dp_id: 128
    internal: true
    bind_switch_id: "a32_pro_switch28"
    name: A32 Pro Switch29
      number: 14
    name: A32 Pro Switch29 Tuya
    dp_id: 129
    internal: true
    bind_switch_id: "a32_pro_switch29"
    name: A32 Pro Switch30
      number: 15
    name: A32 Pro Switch30 Tuya
    dp_id: 130
    internal: true
    bind_switch_id: "a32_pro_switch30"
    name: A32 Pro Switch31
      number: 16
    name: A32 Pro Switch31 Tuya
    dp_id: 131
    internal: true
    bind_switch_id: "a32_pro_switch31"
    name: A32 Pro Switch32
      number: 17
    name: A32 Pro Switch32 Tuya
    dp_id: 132
    internal: true
    bind_switch_id: "a32_pro_switch32"
    name: A32 Pro DI01
    on_press:
      then:
        - switch.toggle: a32_pro_switch01
      xl9535: xl9535_hub_in1
    name: A32 Pro DI01 Tuya
    dp_id: 133
    bind_binary_sensor_id: a32_pro_di01
    internal: true
    name: A32 Pro DI02
    name: A32 Pro DI02 Tuya
    dp_id: 134
    bind_binary_sensor_id: a32_pro_di02
    internal: true
    name: A32 Pro DI03
    name: A32 Pro DI03 Tuya
    dp_id: 135
    bind_binary_sensor_id: a32_pro_di03
    internal: true
    name: A32 Pro DI04
    name: A32 Pro DI04 Tuya
    dp_id: 136
    bind_binary_sensor_id: a32_pro_di04
    internal: true
    name: A32 Pro DI05
    name: A32 Pro DI06
    name: A32 Pro DI07
    name: A32 Pro DI08
    name: A32 Pro DI09
      number: 10
    name: A32 Pro DI10
      number: 11
    name: A32 Pro DI11
      number: 12
    name: A32 Pro DI12
      number: 13
    name: A32 Pro DI13
      number: 14
    name: A32 Pro DI14
      number: 15
    name: A32 Pro DI15
      number: 16
    name: A32 Pro DI16
      number: 17
    name: "A32 Pro TMP1"
    name: "A32 Pro TMP2"
    name: "A32 Pro DL"
    name: "A32 Pro DTUYA"
      number: 21
    name: A32 Pro DI17
      xl9535: xl9535_hub_in2
    name: A32 Pro DI18
    name: A32 Pro DI19
    name: A32 Pro DI20
    name: A32 Pro DI21
    name: A32 Pro DI22
    name: A32 Pro DI23
    name: A32 Pro DI24
    name: A32 Pro DI25
      number: 10
    name: A32 Pro DI26
      number: 11
    name: A32 Pro DI27
      number: 12
    name: A32 Pro DI28
      number: 13
    name: A32 Pro DI29
      number: 14
    name: A32 Pro DI30
      number: 15
    name: A32 Pro DI31
      number: 16
    name: A32 Pro DI32
      number: 17
    name: A32 Pro DI33
      pcf8574: pcf8574_in_3
    name: A32 Pro DI34
    name: A32 Pro DI35
    name: A32 Pro DI36
    name: A32 Pro DI37
    name: A32 Pro DI38
    name: A32 Pro DI39
    name: A32 Pro DI40
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    name: "A32 Pro-DAC-0"
    output: gp8403_output_1
    gamma_correct: 1.0
    name: "Tuya A32 Pro-DAC-0"
    # bind other light, sync state
    bind_light_id: a32_pro_dac_0
    dp_id: 173
    internal: true
    gamma_correct: 1.0
    name: "A32 Pro-DAC-1"
    output: gp8403_output_2
    gamma_correct: 1.0
    name: "Tuya A32 Pro-DAC-1"
    bind_light_id: a32_pro_dac_1
    dp_id: 174
    internal: true
    gamma_correct: 1.0
  - platform: adc
    pin: 7
    name: "A32 Pro A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A32 Pro A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "A32 Pro A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "A32 Pro A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
    address: 0x0000
    value_type: U_WORD
    filters:
    address: 0x0001
    value_type: U_WORD
    filters:
      - multiply: 0.1
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "A32 Pro");
yaml file download:
.txt   A32_Pro-ESPHome_arduino_type_RS485_MODBUS_SENSOR.txt (Size: 23.44 KB / Downloads: 670)
RS485 sensor config PC software:
.zip   RS485-sensor-PC-tool.zip (Size: 4.08 MB / Downloads: 979)
  More then 3 DS18B20 sensors with KCS Firmware
Posted by: Jackson - 10-07-2024, 08:13 AM - Forum: KC868-A16 - Replies (3)
Hi! I want to know if it is possible to connect more than 3 DS18B20 sensors to the KC868-A16 board, using the KCS Firmware, not ESPHOME! Via ESPHOME, I can find the addresses, but is it possible to do it with KCS Firmware? Thanks!
  sesnors
Posted by: BaconRanch - 10-07-2024, 02:29 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (9)
On the Kincony server 16, are the sensors only binary?
If I want to display voltage of a vehicke do I have to use the native GPIO on the CM4?
Can I simply run a ground from the ground terminal to the metal frame?
  Send RF from MQTT
Posted by: charlesrg - 10-07-2024, 01:56 AM - Forum: "KCS" v2 firmware system - Replies (1)
How can I trigger an RF code to be sent from MQTT ?
I have automations on NodeRed that I would like to use to send MQTT message to A32M to transmitt and RF433mhz signal.
(10-07-2024, 01:56 AM)charlesrg Wrote: How can I trigger an RF code to be sent from MQTT ?
Found my answer at: https://youtu.be/k4iKJMzGIl0?t=901
Thank you for posting the video and instructions.
  How to setup S3 Core Board + DO8 + HAv2 with Physical Switch using ESPHome?
Posted by: weedtop - 10-06-2024, 06:59 AM - Forum: DIY Project - Replies (2)
Hi ,
Below is my product list
S3 core Board
DO8 relay board
HAv2
I have successfully config DO8 and HAv2 with ESPHome in Home Assistant , please see attached photos.
Please help me to modify my yaml to use HAv2 and Siemens to control the relay on DO8
attached is my yaml
.txt   s3-core.txt (Size: 4.02 KB / Downloads: 517)
Thanks,
  How to connect switch to A32Pro
Posted by: drazvan2003 - 10-05-2024, 02:44 PM - Forum: DIY Project - Replies (9)
Could you provide some info on how to connect https://shop.kincony.com/products/moment...ush-button to the A32Pro
What pin from A32 Pro goes to what pin on the switch ?
And do i need to change any code on the yaml file on esphome ?
I followed this document to get the firmware - https://www.kincony.com/esp32-kcsv2-firmware.html and after that i added it to ESPHome
Best regards
Razvan
  Firmware settings Backup
Posted by: charlesrg - 10-05-2024, 03:40 AM - Forum: "KCS" v2 firmware system - Replies (3)
How do I backup the firmware settings so I don't have to redo by hand after upgrade ?
  KinCony F16 ESP32-S3 16A Removable Relay Board released
Posted by: admin - 10-05-2024, 02:29 AM - Forum: News - No Replies
KinCony F16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. 16 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F16 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F16 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY.
[Image: ESP32-F16-1.jpg]
Model No. KinCony F16
Description: KinCony 16 Channel ESP32-S3 Removable Relay Controller – F16
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
16CH OMRON removable relay, every channel have "COM"(common) and "NO"(normal open) ports.
MAX load 250VAC/16A 30VDC/16A
Inputs:
[Image: ESP32-F16-6.jpg]
software solution:
1. download firmware by ESPHome, integrate to home assistant or use by web service.
2. download tasmota firmware.
3. write your own arudino code for your own requirements.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=6814
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=6815
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=63
Different views of the F16:
[Image: F16-view.jpg]
[Image: F16-size.jpg]
  PLC Modbus communication
Posted by: huntleight - 10-04-2024, 10:08 PM - Forum: KC868-A6 - Replies (7)
How can i communicate with plc (Plc as a master)? How plc can change my parameter ? For example plc wants to change or read my maxhumidity parameter, how can plc know maxhumidity modbus adress(for example 4x2002) ? Can you explain all phase communication, i dont know maybe assign modbus address, if plc change my parameter how can i catch and change parameter, ..? I hope it was understandable.
