» Members: 10,453
» Latest member: 789kwiki
» Forum threads: 4,326
» Forum posts: 21,315
There are currently 381 online users.
» 0 Member(s) | 356 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, HeadlessChrome, PetalBot, bot
No AP appears
3 hours ago
» Replies: 8
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
  [arduino code examples for AS]-01 internet radio
Posted by: admin - 10-22-2024, 12:39 AM - Forum: KinCony AS - No Replies
  Simple Internet Radio Demo
  esp32-i2s-simple-radio.ino
  Simple ESP32 I2S radio
  Uses MAX98357 I2S Amplifier Module
  Uses ESP32-audioI2S Library - https://github.com/schreibfaul1/ESP32-audioI2S
// Include required libraries
#include "Arduino.h"
#include "WiFi.h"
#include "Audio.h"
// Define I2S connections AS
#define I2S_DOUT  8
#define I2S_BCLK  7
#define I2S_LRC   6
// Create audio object
Audio audio;
// Wifi Credentials
String ssid =    "KinCony";
String password = "a12345678";
  // Start Serial Monitor
  // Setup WiFi in Station mode
  WiFi.disconnect();
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid.c_str(), password.c_str());
    delay(500);
    Serial.print(".");
  // WiFi Connected, print IP to serial monitor
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("");
  // Connect MAX98357 I2S Amplifier Module
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  // Set thevolume (0-100)
  audio.setVolume(10);
  // Connect to an Internet radio station (select one as desired)
  audio.connecttohost("http://vis.media-ice.musicradio.com/CapitalMP3");
  //audio.connecttohost("mediaserv30.live-nect MAX98357 I2S Amplifier Module
  //audio.connecttohost("www.surfmusic.de/m3u/100-5-das-hitradio,4529.m3u");
  //audio.connecttohost("stream.1a-webradio.de/deutsch/mp3-128/vtuner-1a");
  //audio.connecttohost("www.antenne.de/webradio/antenne.m3u");
  //audio.connecttohost("0n-80s.radionetz.de:8000/0n-70s.mp3");
  // Run audio player
  audio.loop();
// Audio status functions
void audio_info(const char *info) {
  Serial.print("info        "); Serial.println(info);
void audio_id3data(const char *info) { //id3 metadata
  Serial.print("id3data     "); Serial.println(info);
void audio_eof_mp3(const char *info) { //end of file
  Serial.print("eof_mp3     "); Serial.println(info);
void audio_showstation(const char *info) {
  Serial.print("station     "); Serial.println(info);
void audio_showstreaminfo(const char *info) {
  Serial.print("streaminfo  "); Serial.println(info);
void audio_showstreamtitle(const char *info) {
  Serial.print("streamtitle "); Serial.println(info);
void audio_bitrate(const char *info) {
  Serial.print("bitrate     "); Serial.println(info);
void audio_commercial(const char *info) { //duration in sec
  Serial.print("commercial  "); Serial.println(info);
void audio_icyurl(const char *info) { //homepage
  Serial.print("icyurl      "); Serial.println(info);
void audio_lasthost(const char *info) { //stream URL played
  Serial.print("lasthost    "); Serial.println(info);
void audio_eof_speech(const char *info) {
  Serial.print("eof_speech  "); Serial.println(info);
arduino ino file download:
.zip   internet-radio.zip (Size: 1.15 KB / Downloads: 956)
.zip   internet-radio.ino.merged.zip (Size: 849.07 KB / Downloads: 927)
just make sure replace wifi router's ssid and password by yourself.
  Server16 raspberry pi
Posted by: Saif Kitany - 10-21-2024, 06:28 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (4)
Hello kincony technical team support ,
I Have H32b controller, my question is like this:
If I purchase server16 raspberry pi iot getway, then can i by node red to control h32b with a diagram that stand on my requirements?
For example:
My h32b is to control electrical windows in my home. So i want for example to open:
1. Window number 1at 5%
2. Window number 2 at 10%
3window number 3 at 100%
Etc…
  Like the A6 but more 0-10V outputs
Posted by: tarajas - 10-21-2024, 04:45 PM - Forum: Extender module - Replies (6)
Basically none of the dev boards offerred by Kincony have more 0-10V outputs than 2, while also having SSR digital outputs, instead of mechanical relays right?
So the only way is to buy at least minimum an A6 board (it has the I2C port needed for the extenders), then use an extender right? Which extender should I go for?
For the the SSR outputs are the main focus and multiple 0-10V outputs as well.
  How to control RGBW 5pin led strip with A16 controller
Posted by: Karnek - 10-21-2024, 08:12 AM - Forum: KC868-A16 - Replies (18)
Hi!
Can someone guide me how can I controll 5pin RGBW SMD 5050 led strip ( not addressable LEDs, total of ~25meters long, 5pcs x 5meters, 12v )
using A16 board & Home assistant ideally?
  Max PWM frequency
Posted by: kepten - 10-19-2024, 07:49 PM - Forum: B16M - Replies (16)
Hi, does the B16M board support dimming LEDs with 20kHz PWM (up to 10A/channel load)? If not, what is the maximum PWM frequency that can be used without overheating/burning the MOSFET/driver/microcontroller/etc?
Regards,
Robert
  AS ESPHome yaml for home assistant
Posted by: admin - 10-19-2024, 12:09 PM - Forum: KinCony AS - Replies (26)
  friendly_name: AS
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
  mode: octal  # quad for N8R2 and octal for N16R8
  speed: 80MHz
  encryption:
    key: "TFpb+pBAvQIS1MVwaA7EoJ2DkpWE+79UvVro7yMyGdU="
  on_client_connected:
        then:
          - delay: 50ms
          - light.turn_off: led_ww
          - micro_wake_word.start:
  on_client_disconnected:
        then:
          - voice_assistant.stop:
ota:
  - platform: esphome
    password: "1245211a05eef56614a2ef5a3f3e971c"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Esp32-S3-Wake-Word"
    password: "LJfUrdJk3svP"
captive_portal:
button:
  - platform: restart
  - platform: template
    optimistic: true
    on_turn_on:
      - micro_wake_word.stop:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
    rgb_order: GRB
    pin: GPIO16
    num_leds: 1
    rmt_channel: 0
    chipset: ws2812
    name: "on board light"
    effects:
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  #WS
    i2s_bclk_pin: GPIO2 #SCK
  - id: i2s_speaker
    i2s_lrclk_pin: GPIO6  #LRC
    i2s_bclk_pin: GPIO7 #BLCK
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO4 #SD pin on the INMP441
    channel: left
    pdm: false
    i2s_audio_id: i2s_in
    bits_per_sample: 32 bit
speaker:
    platform: i2s_audio
    i2s_audio_id: i2s_speaker
    dac_type: external
    i2s_dout_pin: GPIO8   #  DIN Pin of the MAX98357A Audio Amplifier
    channel: mono
micro_wake_word:
  on_wake_word_detected:
    # then:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
  models:
    - model: github://esphome/micro-wake-word-models/models/v2/hey_jarvis.json
voice_assistant:
  microphone: va_mic
  noise_suppression_level: 2.0
  volume_multiplier: 4.0
  speaker: va_speaker
  on_stt_end:
       then:
  on_error:
  on_end:
        then:
          - wait_until:
              not:
                voice_assistant.is_running:
yaml file download:
.txt   AS-HA.txt (Size: 3.94 KB / Downloads: 1647)
  AS ESP32-S3 IO pins define
Posted by: admin - 10-19-2024, 12:08 PM - Forum: KinCony AS - No Replies
433M receiver socket (reserved):GPIO18
IR receiver  GPIO1
WS2812B 3pcs bottom RGBW LEDs:GPIO15
WS2812B 1pc vertical bar RGBW LED:GPIO16
Microphone:
INMP441-WS:GPIO3
INMP441-SCK:GPIO2
INMP441-SD:GPIO4
Amplifier:
MAX98357A-LRC:GPIO6
MAX98357A-BLCK:GPIO7
MAX98357A-DIN:GPIO8
MAX98357A-SD MODE:GPIO5
SD Card (reserved on PCB)
SD_MISO:GPIO13
SD_SCK:GPIO12
SD_MOSI:GPIO11
SD_CS:GPIO10
free GPIO for DIY extend on PCB:
GPIO44,GPIO41,GPIO39,GPIO17,GPIO21,GPIO48
GPIO43,GPIO42,GPIO40,GPIO38,GPIO9,GPIO47,GPIO14
  KC868-H32B Pro relay positions
Posted by: lulu01 - 10-19-2024, 08:53 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (7)
I wanted to replace a few relays that are dead on the KC868-H32B Pro, but I can't find their physical location.
For instance the one with the arrow in my picture is the number 1, but it is marked K23 on the PCB.
Do you have a diagram showing the actual number of each relay on the board?
Thank you
  error on compling - ethenet
Posted by: DaddyLee76 - 10-17-2024, 04:49 PM - Forum: KC868-A2 - Replies (6)
hello,
in my home I have several problems with WiFi so I'd like to connect via ethernet port.
So I adapted the code at this link to my needs.
This is this part of code i'm using
  platform: ESP32
# ethernet configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.0.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
web_server:
  port: 80
captive_portal:
# Basic Config
  sda: 4
  scl: 5
when I try to compile, i receive the follow error:
C:\Users\Daddy>esphome compile c:/esphome/luci2_eth1.yaml
INFO ESPHome 2024.10.0
INFO Reading configuration c:/esphome/luci2_eth1.yaml...
INFO Unable to import component type: No module named 'esphome.components.type'
Failed config
type: [source c:/esphome/luci2_eth1.yaml:8]
  Component not found: type.
  LAN8720
Someone knows how I can solve this prolem?
many thanks
  server mini cm4 no don't boot
Posted by: Krishi00 - 10-16-2024, 08:39 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (4)
Hi there,
New server mini, new RASPBERRY-PI  CM4108032  Raspberry Pi 8GB Compute Module 4 with WiFi, 32GB eMMC, new 24v ps, when I power it up it does not even connect to my switch...
