» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 217 online users.
» 0 Member(s) | 205 Guest(s)
Amazonbot, Baidu, Crawl, Google, HeadlessChrome, PetalBot, bot, owler
kc868-a6 analog input
Today, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  ESPHome Modbus config for KC868-A6
Posted by: aucirc - 10-04-2024, 06:06 PM - Forum: KC868-A6 - Replies (4)
Is this the correct ESPHome configuration for RS-485 Modbus on KC-868 A6?
  tx_pin: GPIO12
  rx_pin: GPIO13
  baud_rate: 9600
modbus:
  uart_id: mbus
  send_wait_time: 500ms
modbus_controller:
- id: wp3082adam1
  address: 1
  modbus_id: modbus1
  update_interval: 5s
I'm trying to use this with WellPro WP3082ADAM:
text_sensor:
- name: "analoginputs"
  platform: modbus_controller
  modbus_controller_id: wp3082adam1
  # internal: true
  register_type: holding
  address: 0x0000
  register_count: 8
  raw_encode: HEXBYTES
  response_size: 10
This is sending correct command to the wp3082adam, but ESPHome it never receives a response:
Modbus command to device=1 register=0x00 no response received - removed from send queue
The frustrating this is I can see the holding register request from the A6 and the response from the WP3082ADAM when monitoring the wire, everything seems to be working perfectly, but A6 can't "hear" the modbus response.
sent from A6:
{01}{03}{00}{00}{00}{08}{44}{0C}
response from wp3082adam:
{01}{03}{10}{00}{00}{00}{00}{00}{00}{00}{00}{03}{34}{00}{00}{00}{00}{00}{00}{D1}{8F}
I would appreciate any suggestions
  Digital inputs not reacting on +24VDC
Posted by: xxpeta - 10-04-2024, 06:32 AM - Forum: KC868-AI - Replies (7)
Hi all,
my KC868-AI is not reacting (change from logical 0 to logical 1) on sending +24VDC to any of digital inputs.
Firmware version: 2.2.4
Thanks for your reaction.
  Kcs output off after x seconds
Posted by: stanchiam - 10-03-2024, 12:14 AM - Forum: "KCS" v2 firmware system - Replies (1)
How can we let kcs automatically off the output, example output 1, 10 seconds after it is triggered on through api (http://192.168.1.99/ctrl.cgi?secret=&set...=1&value=1)
  M30 - Jumpers for CT inputs (voltage/mA)
Posted by: raphaelcno - 10-02-2024, 03:52 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (6)
Hello Smile
I'm reading the description of the M30 board (https://www.kincony.com/esp32-energy-monitor-board.html).
I see that it's possible to use CT clamps with voltage or mA signal.
Can you tell me if the CT inputs on the M30 board are equipped with jumpers in order to choose between voltage and mA signal?
Thank you in advance for your help Smile
Raphaël
  NodeRed MQTT and Single output State
Posted by: charlesrg - 10-02-2024, 01:59 PM - Forum: "KCS" v2 firmware system - Replies (1)
I've a few KC868_A32M  and A16
I'm trying to subscribe to the state of a single output instead of the whole board.
On NodeREd I wanted to subscribe to a topiic like:
KC868_A32M/E05A1B5BE4C8/STATE/output1
So only changes to output1 would trigger an action. Is it possible or is this something for a future firmware update ?
  KinCony B16M ESP32-S3 Smart Controller released
Posted by: admin - 10-01-2024, 06:56 AM - Forum: News - No Replies
KinCony B16M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B16M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B16M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY.
[Image: ESP32-B16M-2.jpg]
Model No. KinCony B16M
Description: KinCony 16 Channel ESP32-S3 Smart Controller – B16M
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
16CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
[Image: ESP32-B16M-1.jpg]
software solution:
1. download firmware by ESPHome, integrate to home assistant or use by web service.
2. download tasmota firmware.
3. write your own arudino code for your own requirements.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=6781
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=6782
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=61
Different views of the B16M:
[Image: B16M-view.jpg]
[Image: B16M-size.jpg]
Here are the hardware design details:
[Image: ESP32-B16M-3.jpg]
[Image: ESP32-B16M-4.jpg]
[Image: ESP32-B16M-5.jpg]
[Image: ESP32-B16M-6.jpg]
B16M support install on DIN RAIL
[Image: ESP32-B16M-7.jpg]
As a standard size, it looks like it is installed in a distribution box.
[Image: ESP32-B16M-8.jpg]
[Image: ESP32-B16M-9.jpg]
  [arduino code examples for F16]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 10-01-2024, 04:55 AM - Forum: F16 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
void page1() {
  u8g2.begin();
  do {
    page1();
arduino ino file download:
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 821)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 198.96 KB / Downloads: 855)
  [arduino code examples for F4]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 10-01-2024, 04:55 AM - Forum: F4 - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 855)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 198.96 KB / Downloads: 853)
  [arduino code examples for F16]-09 how to communication with Tuya WiFi module
Posted by: admin - 10-01-2024, 04:53 AM - Forum: F16 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 39
#define RXD_PIN 38
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 881)
.zip   9-tuya-wifi-config.ino.merged.zip (Size: 182.83 KB / Downloads: 879)
  [arduino code examples for F4]-09 how to communication with Tuya WiFi module
Posted by: admin - 10-01-2024, 04:53 AM - Forum: F4 - No Replies
* Functionality:
#define TXD_PIN 39
#define RXD_PIN 38
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 863)
.zip   9-tuya-wifi-config.ino.merged.zip (Size: 182.83 KB / Downloads: 814)
